Question about Husqvarna Huskylock Computerized 910
Husqvarna huskylock 910 wont form chain while sewing
My serger will not form a chain while I am sewing, I have rethreaded it several times and this does not solve the problem. I know that I am threading the machine right so I don't understand what the problem is HELP!!
Are you sure the tension is right? You might need to push the thread hard against the track after leaving spool going into the machine (until it clicks). I had that problem also. Hope that helps.
Posted on Jun 27, 2008
Thread coming out of eye of right needle on huskylock 910
Hi:
Are you sure it's coming out? Or is it breaking at the needle?
Try replacing the right needle and do a test stitch. If it still comes out of the needle... loosen that threads tension a little.
Aug 01, 2012 | Husqvarna Huskylock Computerized 910
Huskylock 910 starts to serge normal and then begins to take extra thread and make a mess. what can I do to fix this?
try changing the needles
make sure the serger is threaded correctly
check for any burrs in the needle plate area, or on the loopers
also make sure the tension is adjusted correctly for the fabric
May 15, 2012 | Husqvarna Huskylock Computerized 910
Won't form a chain stitch
You 910 serger doesn't have the option for a Chain Stitch. It is a 2, 3, or 4 thread serger. You can do a good number of different stitches but a chain stich is not one of them.
If what you mean it that it won't "chain off", meaning sew with no fabric beneath the foot as you gently pull the thread towards the rear of the machine, that could be for a number of different reasons. First, change the needles and unthread the machine and start over. If the threads are not exactly where they should be, your serger won't sew correctly. A great video on threading your machine can be seen at:http://www.husqvarnaviking.com/mediafiles/huskylock/index_en.html
Sep 12, 2009 | Husqvarna Sewing Machines
I need an instruction manual for a Husquvarna 910
https://www.2instructions.com/search.php?...HUSQVARNA...HUSKYLOCK%20SERGER%20910
copy and paste this link in your address bar to bring you to your manual site.
Let me know if you need more info
Sep 03, 2009 | Sewing Machines
Huskylock 910
Always turn the handwheel towards you. There may be an arrow on the side. (Looking from the right it should go counter-clockwise)
Unthread the needles.
Make sure that the needles are new or good (not old or bent).
Make sure that the needles are inserted with the flat side to the back and all of the way up. The left needle will be higher than the right.
Make sure that the loopers are correctly threaded and under the foot.
Place the needles in the highest position and rethread the needles.
The loopers MUST be threaded before the needles in order for it to sew.
Make sure that the threads are pulled fully down into the tensions.
Jul 26, 2009 | Husqvarna Huskylock Computerized 910
LCD Screen doesn't work
the ribbon cable may have wiggled loose. It plugs in right behind the tension assemblies on top from back to the front. It's a wide ribbon cable. you have to remove the back cover to get it though
Mar 05, 2009 | Husqvarna Huskylock Computerized 910
I would like to know where I could find a serving & repair shop
Use the dealer locator:
http://webservices.us.vsmgroup.com/DealerLocator.aspx?Brand=Viking
Sep 25, 2008 | Husqvarna Huskylock Computerized 910
Husqvarna 910 won't create a chain.
You may have knocked the machine out of time if the machine does not pick up stitches.
Jan 21, 2008 | Husqvarna Huskylock Computerized 910
Sewing Machines Logo
336 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
