Question about HP PSC 2210 All-In-One InkJet Printer
Cant print Sorry to ask such a basic question. The machine sends docs to print but then does nothing. If I press Start, it thinks I want to Copy something. I have reinstalled the Drivers. How do I tell it to print no to copy???
  • 234 Answers
First of all the basics to copy only you need to press the copy button in the printer itself, to print you will ot have to press any button in the printer.
Try the following Steps.
First if you have a windows operating system
Go to Start> Settings/Control Panel> Then Printers and other faxes and see how may printers icon do you see listed there, if you have multiple and unwanted icons then the printer you have delete all the icons there.
And insert the All-In-One Printer CD to the computer
Unplug the USB cable from the computers end and wait for a while until it says found new hardware and wait till all the drivers are installed
Then check in printers and faxes window there should be a new icon listed and it should say 0 Ready.
Now right click on the printers icon>Go to> Properties and click on Print test page.
And when ever you print any document make sure in the window you have the right printer listed
Posted on Aug 28, 2008
Printer is printing, but nothing shows up on paper.
Try to do test print directly from the printer
1. Press at the sane time for 10 sec, the photo and copy button.
2. Clean the printhead simple press the menu button > selet clean printhead > select basic/deep clean
3. If it print a test page using the scanner glass. Place a doc./picture on the glass and copy it
4. If it failed call 1 800 421 6699 for assistance replacing the printhead
Nov 26, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
MFC-490CW two ink colours just not printing, it still prints biut just with black and blue, tried cleaning them the normal way but they still wont print. Cant get into maintenence mode to try better...
Powerful cleaning is: Press menu, then start black copy, then four times arrow-up quickly after another.Machine will be in maintenance mode (all lights will flash).
press 7-6-4 and OK (or start-black-copy).
When finished press 7-6-3 then start black copy,
printer will do a power purge.
Leave maintenance mode by pressing 9-9.
If this not help better think about new printer, because cost of repairing this one is profitable.
Nov 10, 2009 | Brother MFC 210C All-In-One InkJet Printer
Copy Function not working
You need to reset the machine back to factory defaults
Turn machine off
lift up doc feeder and hold down the pointed switch by the scanner glass while turning the machine back on until it beeps.
Close doc feeder
scroll down to SHIPMENT SET
press SET
SET
wait for the machine to reboot.
Aug 04, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Able to receive fax but cant send
sleep mode is just a status of the machine when it is in idle mode.you cannot turn this off however you can delay the time before the unit goes into a sleep mode.it has nothing to do when you are sending out faxes.so here are a few things you need to check when sending a fax (1)dial tone by pressing hook/hold button (2) insert the doc into the adf, make sure it will change to "enter fax # and start,or copy press copy (3) dial the number (4) wait for fax tones of the receiving unit before you press start. now if you can hear an operator on the line,that has to be verified with your phone company since brother machine does not restrict incoming and outgoing faxes UNLESS that is restricted from your phone line.
Nov 18, 2008 | Brother IntelliFax-2820 Laser Fax
Canon jx200 fax machine
The fax automatically turns off Auto Print and stores faxes in memory when either ink or paper is low. The memory will store up to 30 transmissions or 60 pages maximum, so it is important not to leave this too long if you have heavy transmission volume.
Faxes can be retrieved as follows.
If you want to choose only certain faxes to print:
1. Print a list of documents in memory for reference:
Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Doc Memory List, and again press Start/Copy.
2. Print a document from memory (using the list printed in #1):
Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Print Document, and again press Start/Copy. The LCD will show the first number in memory (e.g., TX/RX NO. 0001).
Use the arrows to choose the document you want to print, and press Start/Copy. The LCD will then toggle between "1st page only?" and "Yes=(*) No=(#)". Press * to print only the first page, or # to print all pages.
3. Delete selected document(s) from memory:
Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Delete Doc, and again press Start/Copy. The LCD will show the first number in memory (e.g., TX/RX NO. 0001).
Use the arrows to choose the document you want to delete, and press Start/Copy. [Note - if the arrows do not result in another number displaying, there is only one document in memory.] The LCD will show "Yes=(*) No=(#)". Press * to delete the document. Continue to select documents until each document you want to delete has been handled.
If you want to print all unprinted documents in memory:
1. If you want to have a list of documents in memory for reference before performing this procedure, to be sure you have them all, follow step 1 from the above procedure for printing selected documents.]
2. Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Print All New RX, and again press Start/Copy.
3. Delete all printed docs from memory:
Immediately after printing all documents, you will have the choice of deleting all documents. The LCD will display "Yes=(*) No=(#)". Press * delete all, or # to retain in memory.
To delete all documents at a later time:
Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Delete Printed RX, and again press Start/Copy. The LCD will display "Yes=(*) No=(#)". Press * delete all, or # to retain in memory. To finish then, press Stop.
If you need further assistance, please post back. Otherwise, thank you for using and rating FixYa!
Jun 06, 2008 | Canon FAX-JX200
Problem with sending faxes
change a paper size in the fax setup
Feb 04, 2008 | Office Equipment & Supplies
Prints header and footer but nothing in between
Make sure that the carts are FULL, placed well and are secured!
press menu then start bk copy then fourtimes arrow-up-button.
machine will be in maintenance mode. press 7 then 6 then 4 then start bk copy. machine will initialize the carts and refresh ink in tubes and the ph. leave the maintenance mode when finished by pressing 9 then 9.
Run a quality test print.
If you still cant see any bk this might be because of generic ink which had clogged the bk channel. this cant be fixed anymore!
Jan 03, 2008 | Brother MFC 420CN All-In-One InkJet...
Will not print black
The ph will be cleaned by pressing ink thru the system (tubes and ph). Do use only dye-ink for this procedure. The best way is to use original brother ink.
place a new cart into position and make sure that they are secured.
press menu then start bk copy then fortimes arrow up. machine will be in maintenance mode. press 7 then 6 then 4 then start bk copy. machine will refresh ink and do some cleaning. afterwards press 7 then 6 then 3 then start bk copy. machine will do a power purge. when finished press 9 then 9 to leave the maintenance mode. do run a test quality print by pressing ink etc.. If you cant see any bk the ph is defenetly clogged and cant be fixed anymore. It needs replacing.
Dec 14, 2007 | Brother MFC 420CN All-In-One InkJet...
Printer will not print- blank returns
make sure carts are placed well and secured.
press menu then start bk copy then four times arrow-up (tel. index). machine switches to maintenance mode. press 7 then 6 then 4 then start bk copy. machine will refresh ink in tubes and ph and do some cleaning. after that press 7 then 6 then 3 then start bk copy. machine will do a power purge. after that leave mode by pressing 9 then 9. Run a quality test print by pressing ink etc.
If you still cant see any colors the ph has dryed out. If you see some blocks try a manual cleaning (pressing ink shift to cleaning etc.). If the next test print out still is bad the ph is clogged due to generic ink and cant be cleaned anymore. In both way ph needs replacement.
Dec 08, 2007 | Brother MFC 420CN All-In-One InkJet...
Colors not print well
This could be because of a defective valve.
DO NOT CLEAN THE PIEZO PH WITH ANY SOLUTION EXCEPT ORINIGNAL BROTHER INK!!!! OTHERWISE YOU WILL DEFENETLY DESTROY THE PH!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Try this:
Place new carts into machine and make sure thy are secured.
Press menu then start bk copy then fourtimes arrow up. machine will be in maintenance mode and lights will flash. press 7 then 6 then 4 then start bk copy. machine will refresh ink within tubes and ph and do some cleaning. when done press 7 then 6 then 3 then start bk copy. machine will do a power purge.
Leave maintenance afterwards by pressing 9 then 9. Do run a test print by pressing ink etc.
If you still cant see any yellow and/or magenta the ph is defective and needs replacement.
Oct 25, 2007 | Brother MFC 420CN All-In-One InkJet...
HP PSC 2210 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
