Problem for In Dash Receivers
Generic problem for all In Dash Receivers
Pioneer Super Tuner III DEH-45DH
How to program station memory? Display is very dim. Is there a control to brighten it? This unit is installed in a 97 Pontiac GRand Am I just received. Any advise greatly appreciated.
Same Problem
Mar 30, 2009
-   Thanks you guys, this is exactly what I needed! I am ever grateful for the info, cause I have been searching and searching and couldn't find any help whatsoever, so kudos to y'all for printing this info!
Have a blessed day and may God always smile upon you and your families! -   Guest Jan 24, 2009
-   Display is very dim.-
johnmortin
Best Solution
posted on Jul 11, 2008
Rank: Apprentice
Rating: 100%, 2 votes
I just bought a Ranger with the same problem... been surfing the internet and these are some of the answers.. I haven't tried any of them but I hope this helps:
<b>
Try pressing and holding the CLOCK button
while pressing the first
FM Preset button to change the hours
and the second FM Preset for the minutes!
We hope this helps!
turn the system off. Now hold down the function or audio button. It should light up the display with the time blinking. use the tuning and/or volume button to adjust hr/min, The rest is straightforward....
I just had to set mine and yes you turn the power off. Then you hold in the "F" button (just below "eject")" for 2-3 seconds. The time will display and the hour will blink. Use the up down arrows to change the hour then use the right arrow to switch to the minutes and again use the up or down arrows to change the minutes
Turn system on with only clock showing Press and hold "A" audio button till hour starts blinking the rest is easy too work out
Was this helpful?1 person thought this was helpful
Solution #2
posted on Mar 25, 2009
Rank: Apprentice
Rating: 100%, 1 votes
****How to change the TIME on a Pioneer Super Tuner III DEH-45DH car stereo with CD and detachable face.****
Thanks Megan! You were right on!!!! I have taken the liberty to add to your description a little more for those of us who are a little slower at catching on to this. I recently bought a 1994 Z-28 and this stereo is what came with with no owners manual.
Turn off the power by holding in the SOURCE button
Press and hold the CLOCK button (do not let off it while changing the time!)
Press the first (the button labeled with a "1") FM Preset button to change the hours (it only goes up in increments of one)
Press the second (the button label with a "2") FM Preset button to change the minutes (it only goes up in increments of one)
When finished, release the CLOCK button.
Please post this for all to find because it is a little tricky and other than what Megan posted, there is nothing else on the web that accurately explains how to successfully do it.
Shadow
Popular Solutions for In Dash Receivers
Questions and Unsolved Problems for In Dash Receivers
wont stay on.movies music and pictures wont show
know where I can find a volume knob for sony xplode car stereo
Hi there, I have a RCA DRC8052N and I did get the stuck on "Hello" message and was able to...
(More)
Hi there, I have a RCA DRC8052N and I did get the stuck on "Hello" message and was able to reset by pressing the power button for 10 Secs. I was just wondering which Capacitors are responsible for this? All the Capacitors look good on the power board, no bulges. I saw the 1000uf ones and the smaller 680uf ones and I was thinking if I should just replace all with a higher voltage just to be safe and prevent power up glitches.
Also I have the RCA DRC8060 and it never gave me any power ups until recently. It actually just didn't power on. I was able to reset it, and it seems to be working well now. But just to be safe I would also like to put in a higher voltage Capacitor. I think the Capacitor is 2200uf, but I don't know which one for sure.
Do you know which Capacitor is the one to replace?
Any feedback greatly appreciated
Thanks
i purchased the above model I left it to be cleaned and now it keeps coming up the screen PROTECTED....
(More)
i purchased the above model I left it to be cleaned and now it keeps coming up the screen PROTECTED. i there a keycode i can put in so i can use it again
i have a nissan pathfinder 01, and im trying to install a pioneer deh-p6000ub reciever. i need to...
(More)
i have a nissan pathfinder 01, and im trying to install a pioneer deh-p6000ub reciever. i need to figure out what color wires go to the factory wire harness
