Question about Microsoft Xbox 360 Console
2 red lights
I dont get how my xbox 360 over heats in 5- 10 minutes
  • 45 Answers
I suggest you to try DIY Guidethat wil explain solving the 2 red lights along with someother common problems of Xbox like Disc Read Error, No Video Problemand most famous RROD. Even a novice can solve the problem with the helpof step by step process given at the guide. I think it's worth trying.If you try this method, you won't have to wait for 3-4 weeks and youcan enjoy your gaming experience within 2 hours, once you try thisguide.
Posted on Feb 21, 2009
What's the difference between a xbox 360 over heating and the rrod
There are 4 different kinds of RROD on a xbox 360. When the ring of light shows 1 red light, it means there is a minor hardware issue. If it shows 2 red lights, it means it over heated. If it shows 3, it has a major hardware failure and 4 red lights means that you dont have your A/V cables plugged in. Hope this helps.
Aug 04, 2010 | Microsoft Xbox 360 Console
After playing 15 minutes two red lights flash and xbox shuts down
the xbox 360 is overheating. Try to clean the vents and have it elevated off carpet or anyhtign that will not allow it to get a airflow.
Check the fans in the back of the 360 to be sure they are running ok and not blocked up.
May 16, 2010 | Microsoft Xbox 360 Console
My xbox 360 is showing one red light flashing and the message E74
sorry man ur xbox 360 i done for its ur video chip that has gone. u can try this but if it dont work than thats it for ur xbox 360. disconect the xbox 360 fans. let it heat up a little than if u see two red lights disconnected for 20 minutes than try it if it dont work ur xbox is done for.
Jul 09, 2009 | Microsoft Xbox 360 Console
Xbox 360 e74 error
Having the e-74 code is when the video chip on the 360 over heats and becomes un soldered your best bet is to turn the 360 on with a towel over it and wait for 3 red lights the call microsoft and tell them the 3 lights issue dont mention the 1 light or it will cost you dearly around 150$
Mar 17, 2009 | Microsoft Xbox 360 Console
I have 2 red rings on my xbox 360 but i dont understand what they mean...
The 2 flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. The main thing that causes the 2 red lights to start flashing is because of overheating and as the motherboard within the console takes more heat it actually warps and bends until the solders become loose.
Once this happens you will receive the 2 red lights. Even before you get the 2 red lights you may have noticed your games freezing and this is caused in the same way, by overheating. As the chips take more heat they shut off to prevent lasting damage, although they can only do this a number of times until you get the Xbox 360 2 Red Lights.
To fix the problem you need to stop the level of heat the motherboard takes and you can do this in a number of ways, but it will involve opening up your Xbox and working on it. In addition, you could always send your Xbox back to Microsoft as they are offering free repair for this error, you will just need to wait 3-4 weeks that's all.
There is one more option available in the form of DIY Video Guide, that will explain you step by step approach to fix red ring of death within one hour without any technical knowledge.
Jan 13, 2009 | Microsoft Xbox 360 Console
Help.. My xbox has 3 reds lights
This is a common problem from the Xbox 360.
The only way to fix this problem is to call Microsoft or email them. Its something to do with the hardware failure. Its over heated. Their is one way to fix it but temporary.
Its called the towel trick.
First, Unplug your xbox.
Then wrap it around with Heavy towels dont expose anything on the xbox 360. Cover everything.
Then plug in the xbox 360 while the towels are around it. After you do all that you wait 15 minutes. Then unwrap the towel from the xbox 360. It should be very hot. Let it cool down for 2 minutes then plug everything in and it should work.
But I hope this helps you.
Dec 30, 2008 | Microsoft Xbox 360 Console
Do Not Use A Heat Gun On Your Xbox 360! Send It In To Microsoft! Find Out Why Here!
If you are looking for an Xbox 360 3 Red Lights Fix do not use any guide that suggest a heat gun fix!
Although a heat gun is used sometimes you are better sending it in to Microsoft to do the work!
If you buy any guide with the heat gun fix ask for a full refund you will need it!
If you still want to fix it yourself then click the link below and get a FREE preview of an easy 30 minute fix that does not use a heat gun:
Xbox 360 Repair
Mar 15, 2008 | Microsoft Xbox 360 Console
3 red lights
Over heating wont turn on
Mar 13, 2008 | Microsoft Xbox 360 Console
3 red light's
Error Codes XBOX360
Jan 24, 2008 | Microsoft Xbox 360 Console
Xbox360 3 flashing red lights
Google up the red ring of death. Its a common over-heating problem on Xbox 360s. There are various solutions to this problem. The most recommended one is to take your console to Microsoft to get it checked. If you dont have an xbox 360 representative in your country as is my case, the second best solution is to buy a new 360 which comes more "prepared" for this issue. If you dont feel like spending 400 dolars on a newer model of the 360 then you should try some of the alternative temporary fixes. Most fixes have been reported as temporary, although if you are lucky maybe your Xbox 360 will last a long time fixed.
Basically solutions require to void your guarantee. Any fix which requires you to open your Xbox (the thermal-paste and the rubber fixes, etc (i will post link at end of comment)) will automatically void the guarantee. Theres a temporary solution which almost always works which is to wrap your xbox into towels without the hard drive and cables, only the power cable pluged in, and the console turned on. It will heat up and after 10 or 15 minutes unwrap it, let it cool down and you'll be playing in no time. Although this is definitely not recommended as you will be over-heating lots of components which are working well and could damage them. Well, hope this link works and saves you money.
Nov 03, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
24 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
