Question about Acer Computers & Internet
Have an acer aspire 3680 bent dc adapter the cord goes into and due the prong being bent the cord does not work. Where can I get this part to replace dc adapter in my notebook?
    Genius:
  • 1,689 Answers
You can either use this:
http://www.amazon.com/Acer-3680-2574-3681NWXCi-3682NWLMi-3682NWXCi/dp/B000OL7T9A
or a universal PA that has the same specs.
good luck
Posted on Jun 23, 2008
I used it the night before it was fine i plugged in the charge and it wont turn on at all
laptop charger for acer aspire 3600 3680 series 3650 3610
www.amazon.com/LAPTOP-CHARGER-ACER-ASPI...
Amazon.com, Inc.Amazon.com: LAPTOP CHARGER FOR ACER ASPIRE 3600 3680 SERIES 3650 ...When I was looking for a charger cable for my laptop, i was not sure whether I ... it was really good and worked, it heats up a little bit but for now its working ...
When your acer aspire 5738 z laptop adapter is not working ...
docslide.us > Business
Aug 18, 2015 - When Your Acer Aspire 5738Z Laptop Adapter is Not WorkingA ...Quicker Charging of Laptop Battery with an Acer Aspire 3600 AC Adapter ...
batteries-store.pblogs.gr/.../when-your-acer-aspire-5738z-laptop-adapter-...
Jan 14, 2016 | Acer Aspire 3600 Laptop Charger...
The adapter light is on when first plugged in but then when I connect the adapter to my laptop the light goes off and it doesnt supply any power
I suggest check out the AC adapter first.
1) When plugged into power, and plugged into the laptop, gently wiggle the cable from the AC adapter TO laptop.
Any change?
Do the same on the power cord TO AC adapter.
NO?
Go on.
2) The port on the laptop that the plug from the AC adapter plugs into, is the DC Power Jack.
If we are discussing an Acer Aspire 5738Z Notebook PC, the DC Power Jack resembles this one, (Not installed),
http://www.batterysupport.com/acer-aspire-5738-jack-p-302046.html
(When I note the DC Power Jack, it is this link I will be referring to )
As you can see there is a Center Pin. All power removed from the laptop, use a small wooden, or plastic object, and see if this pin moves around.
ANY perceptible movement means a bad DC Power Jack.
DC Power Jack checks out it's back to the AC adapter.
Wanted to perform the easy diagnosis first.
This will require a multimeter. An economical, yet fine for this test multimeter, can be purchased for as little as $8 to $12.
Available in a multitude of stores. An auto parts store is but one example.
Analog or digital is fine.
http://www.youtube.com/watch?v=bF3OyQ3HwfU
(Analog is fine. Some of us still like 'em)
DC Voltage is what you are going to check.
Black probe lead (Negative) goes in the Common port on the multimeter. (COM)
Red probe lead (Positive) goes in the Voltage port on the multimeter. (V)
If the multimeter just has symbols around the Function Knob, set it to the dotted line over a solid line, symbol.
The plug on the end of the AC adapter, that plugs into the laptop, has a center hole, and a cylindrical metal shield surrounding it.
The Center Hole of the plug is where the red Positive lead, of the multimeter goes.
The outside cylindrical metal shell is where the black Negative lead of the multimeter goes.
Hold the AC adapter plug in one hand, and at the same time hold the red Positive multimeter probe in the center hole.
With the other hand touch the black Negative lead of the multimeter, to the cylindrical metal shield on the outside of the plug.
You should read 19 Volts (DC), or VERY close to it,
http://www.cellularfactory.com/laptop/ACER/3/305268/
I believe the AC adapter is the problem. Post back in a Comment as to your findings.
Regards,
joecoolvette
Apr 29, 2012 | Acer Aspire 5738Z-423G32Mn Notebook
I have an Acer Aspire one NAV50 travelmate adapter but I don't have a plug. Is there anyway I can get the plug separately?
Are you talking about the cord that goes from the adapter to the wall? If so, any electronics supply store like Radio Shack should be able to source it. If not you can try DIGIKEY.com.
Mar 15, 2011 | Acer Aspire One 521 532H 533 D260 NAV50...
Laptop won't a hold charge when plugged in
Remove the Laptops Battery, Plug in AC Adapter... Is it able to Stay Powered On?? Slightly wiggle the Cord Near the plug end while plugged in... Does it still receive true power??? If So, Its Not Your AC Adapter Or Your DC Jack And You should Look into Replacing Your Laptops Battery...
If You Are Not Able To Power THe Laptop Using Just The AC Adapter When The Battery Is Removed, Then You First Need To Check/Test The AC Adapter using A Multimeter To See If You Have A Faulty Cord... If Cord Is Still Getting Correct Power Through To The Plug Tip .. Then You Will Need To Replace The DC Jack (the port where your AC Adapter Plug Plugs into on the laptop)
Nov 16, 2009 | Acer Aspire 3680 Laptop
My cord to my adapter got bent. I bought a new
Full breakdown and replacement of the power jack should be no more than $125 - you can find places on eBay for that.
Nov 12, 2009 | Acer Aspire 3680 Laptop
ACER 3680 battery does not recharge. I have replaced it twice. Can you help?
A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective.
Nov 07, 2009 | Acer Aspire 3680 Laptop
Battery will not charge nor is able to use AC power to stay on.
Hi everyone it seems to me that the DC connector is loose inside your laptops,try wiggling it about gently at the charger to laptop cord nearer to the dc socket to verify this.Only solution is resolder or new dc socket.
Dec 27, 2008 | Acer Aspire 3680 Laptop
Acer Aspire 3680 Laptop Can't Power Up
acer aspire 3680 no power on, found 2 short circuited surface mount capacitors on motherboard replaced lapton power on works fine. Edward
Jan 19, 2008 | Acer Aspire 3680 Laptop
My charger won't work so now my computer wont turn on
Unplug you ac adapter from the wall and plug a lamp in to verify that the wall plug is working correctly. Pick up the adapter to see if it feels warm. Most adapters will feel warmer than room temperature if they are working,
If the cords on your adapter can be unplugged from the adapter, reseat them. Try the ac adapter in another wall plug to see if it comes on. The adapter may have an LED on it that indicates whether or not it is on. If it doesn't, about the only way to check it is to use a multimeter to see if there is any voltage on the plug that goes into the back of the laptop. If something else will work in the original wall plug and the adapter won't work in another wall plug, you will need to obtain another ac adapter.
Once you've tried these things, let me know and we'll go from there.
Thanks!
Ron-
Nov 11, 2007 | Acer Aspire 3680 Laptop
Computers & Internet Logo
66 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
