Question about Onkyo Audio Players & Recorders
I have the Onkyo TX-DS656. The problem is that the power is on, but I get no sound. House was struck by lightning and had a bit of a surge. All other functions seem to work just fine. Rumor has it that the protection device was activated. I am an electrician and somewhat mechanically inclined. If the rumor is true, is there some way I can de-activate the safety device on my own? I need advice from the experts. Thanks
  • 4,234 Answers
The unit is in protect mode because a problem was detected in the output section. In all likelyhood, the output transistors have failed or a secondary power supply hs failed. Because this was the result of a power surge, I would suggest that you take this to a sericer and request a detailed repair estimate. This could be as simple as a voltage regulator gone bad to the microprocessor being fried. This is not a problem that can be diagnosed remotely.
Dan
Posted on Jun 23, 2008
I have a Vizio model E601I-A3, lightning struck outside my house and fried some of my electronics, despite everything being plugged into a surge protector, anyway it's getting power but I have no picture...
Replace the TV as it has been damaged by a power surge and the faults will be recurring.
A home surge protector will do nothing to break the power of lightning.
Oct 26, 2017 | Vizio Televison & Video
Onkyo tx-ds656 stand by power light comes on volume control knob rotates to max but display or unit wont start
Try factory reset: while holding the(CD) button on front panel,press (POWER) button.
After "Clear" is displayed the unit should be back to its factory default. :) If this dont work for you take the unit to be checked by service . :)
Jan 24, 2014 | Onkyo TX-DS656 Receiver
Lightning struck my Bravia
your tv is shot ,im sorry to say that but its burnt
Jul 29, 2012 | Sony BRAVIA KDL-52S5100 52 in. LCD HDTV
How do I hook up my blue tooth headphones to my onkyo SR 605
You cannot rig up a blue tooth headphones to this receiver with out a blue tooth transmitter ( the Onkyo does not have one built in ). If you have a transmitter it can be plugged into the headphone out socket of the Onkyo ( in front ), just remember that it will cut out the sound from all your speakers when you insert the headphone jack . The advantage though with this connection is you can control the headphone volume using the Onkyo remote.
Mar 12, 2011 | Onkyo TX-DS656 Receiver
I have my Onkyo tx ds656 hooked up to my HDTV via the cable box. Everything works fine, except that there is a noticible delay in the syncronozation of the sound and the video. Is there any way to correct...
It's the nature of the beast. The TV has to process the digital video bitstream more than the receiver has to process the audio so the result can be a gradual lagging of the video behind the sound...
http://en.wikipedia.org/wiki/Lip_sync
Some receivers have a sound delay control which you can use to try to sync them up. I didn
Jan 24, 2011 | Onkyo TX-DS656 Receiver
My onkyo reciever (tx-ds656) powers on, then after a couple seconds says "protect" and powers down. why is this happening? rmill24@yahoo.com
"protect" comes on for 4 reasons.
1. crossed or damaged speaker wires- make sure that the positive and negative is not crossed at all. inspect the wiring for any loose strands of wire that might be crossed, touching the speaker frame or touching the metal case of the amp. look for any damage to the wires. use new speaker wires, if you need to.
2. improper speaker ohmage- verify that your speakers are 8 ohms or greater. ohmage is usually labeled on the back of the speaker, and will have the greek letter "Omega" ω next to the ohmage rating. example: 8ω or 16ω.
3. blown speaker- push in on the woofers, it should move freely for an inch or 2 before bottoming out. if it feels like its scratchy or rubbing or there is any resistance before it bottoms out, then the speaker's voice coil is melted.
4. blown amp.
Nov 07, 2010 | Onkyo TX-DS656 Receiver
TX-DS656 - No display, still works.
Mine goes out sometimes, if I go to the reciever and hit the "Display" butoon, the display lights up dim, at same time, I hit the " Dimmer" botton on remote and display works for about 1-2 weeks. Don't know what is cuasing it, but that got the dispaly to work. Can deal with that I guess.
Sep 02, 2010 | Onkyo TX-DS656 Receiver
After my house was it by lightning my Onkyo
If your receiver was connected to any power source and that power source was not a surge protector strip there may be damage to the receiver as lighting travels. Another thing to consider is the fact that many people will put their equipment on surge protectors but the cable is still connected to the TV etc...This is just another avenue for the lightning to get into the home and blow up your system. I always disconnect any cable from my computer and TV. The power source from the wall is also unplugged when there is a storm just to be sure. Surge protectors are limited in their use as well. I don't believe they can take too many lightning hits. It is best to change them out.
Jul 18, 2009 | Onkyo HTR500 Receiver
TX-SR803 with no sound or popping hissing on any input
It is common for a short term power surge to open up the internal fuse in the main power transformer. Without testing some components inside the unit, I really can't say for sure whether or not the unit is worth repair. I would suggest that you invest in a detailed repair estimate at an authorized Onkyo service center.
Keep us posted.
Dan
May 26, 2009 | Onkyo TX-SR803 Receiver
149 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
