Question about Belkin (F5D7230-4) Router (587009)
Connecting my router
I have a Belkin Wireless G Router.and need step by step on how to reconnect it...I try myself and I kept getting a weak signal..Is there something wrong..I have Windows vista.if that helps!!!!
    Problem Solver:
  • 7 Answers
Windows vista is probably too new for the belkin wireless g router u bought. did u see if the logo on the box is compatible with the windows? 2nd if its a weak signal then you might have to buy a N1 router member it depends how much the signal can spread
Posted on Jul 16, 2008
Router must be restarted every 10 to 15 minuts to work and it works after that after 15 or 20 minuts internet is not working so i have to restarted again
There are many reasons why this might be happening.. You could try the following steps..
1) Disconnect the power from router for a minute and reconnect and check.
2) Try changing the wireless channel and Network name and try re-connecting.
3) Check if there is an firmware update for your product and update if any update is available. You can check this by visiting http://en-us-support.belkin.com/app/product/list/q/routers/ and enter your product details.
4) If none of the above steps work you will need to reset and re-config your router. ( For that you need the CD given with the router and you will need the ISP settings.)
Hope this helped
Mar 09, 2011 | Paradyne (6218-A1-200) Wireless Router...
Tip
What i have to do if its asking for a PIN Number when connecting a Belkin...
Hi Friends,
When you are connecting the Belkin router in Wireless,if it asks for PIN Number then please follow the below mentioned standard steps,
Step 1:Connect the belkin router to any one of your computer with an enternet cable.
Step 2:Open Internet Explorer and type 192.168.2.1 and click on Enter button in the keyboard.
Step 3:Now you will be able to see the belkin router page
Step 4:On your left side click on Wifi Protected Setup (WPS),now it will ask for password leave it blank and click on Submit.
Stpe 5:Now Change the WPS (Wifi Protected setup) to disable and click on Apply Changes.
Step 6:Now Try to connect the Wireless Networks in your wireless computer,it wont ask for PIN Number.
The above mentioned steps are the standard steps for the this problem.This is done because by default the belkin router's will be enabled with 2 security features so we have to disable any one of this feature.If you disable this then you wont have any Problem in the belkin router.
on Mar 16, 2010 | Computers & Internet
Wireless not working
1) Disconnect the power from router for a minute and reconnect and check. 2) Try changing the wireless channel and Network name and try re-connecting. 3) Check if there is an firmware update for your product and update if any update is available. 4) If none of the above steps work you will need to reset and re-config your router. ( For that you need the CD given with the router and you will need the ISP settings.)
Hope this helped
Feb 15, 2011 | Belkin (F5D7633UK4A) Wireless Router
Hi have belkin n150 and we keep getting chucked off the internet , what could the proplem be?
2) Try changing the wireless channel and Network name and try re-connecting and try changing the LAN slots at the back of the router if you facing the same issue even in wired connection.
Hope this helped
Feb 13, 2011 | Belkin F5D7234-4 Router
Wireless Internet is failing.
Hope this helped
Feb 13, 2011 | Belkin F5D8236-4 Router
I can't get my Belkin router to accept WPA in security.
Reset the router then try it.:
Step 1 Locate the reset pinhole on the back of the unit.
Step 2 With the unit powered on, press and hold the Reset button.
Step 3 Hold the Reset button for about 10 seconds.
Step 4 Release the Reset button.
Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting.
Step 6 The device is now at factory defaults.
Jul 29, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Cannot connect
If you're trying to connect wirelessly, you probably need to disconnect from the wireless network in the wireless network manager and reconnect. This will force you to re-type the wireless access key. If you have the correct wireless key, it should connect and give you an IP.
If you're connecting using a network cable, your network connection settings may need to be change so that your computer will get an IP address automatically.
Jan 31, 2009 | Belkin (F5D7230-4) Router (587009)
How to reconnect my belkin router
Need clarification:
1. Is this a wireless connection.
2. Broadband Internet? Your router is the only way to get to your Broadband connection?
3. What operating system do you have.
4. Did you ever have a connection in the past or is this a new router on your network?
Jul 02, 2008 | Belkin (F5D7230-4) Router (587009)
Sprint aircard 595U to belkin router model no# F5D7230-4
Try connecting the sprint card to your router's internet port. You will need a usb-to-ethernet adaptor, along with a networking patch cable, to connect the sprint card to the router.
Then either connect to the router with your two computers using cables, or wireless. If using wireless, you will need wireless adaptors for each of your computers, preferrably Belkin brand to ensure compatibity.
Apr 10, 2008 | Belkin (F5D7230-4) Router (587009)
Belkin (F5D7230-4) Router (587009) Logo
137 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
steve morris
steve morris
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
