Question about Toshiba Satellite A205-S4617 Notebook
Battery not charging...
This morning  was using my less than two year old Toshiba A205-s4617 (it may be even less than one year old) and the battery stopped charging even though it was plugged in.  I tried unplugging and replugging in and finally I got it to charge a little.  Then it stopped at about 32%.  I tried taking out the battery and putting it back in, I tried re-booting. The ac plug is in and it shows it is charging, but the battery life never moves off 33%.  I had another Toshiba laptop that actually quit charging due to the pin breaking (coming loose) inside after about two years of use.  I am told the motherboard would have to be replaced to fix this issue.  Is this what is happening with this laptop?  It gets very hot, but does not shut down in the middle of operating like my old one did.
Do I have a bad battery, bad cord or bad dc jack?
  • johns484 Oct 07, 2008
    my battery stopped charging completely after about a yr of use. First, it was charging my computer sporadically and then it stopped charging it completely?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 126 Answers
My impression is that you might have a defective cord if you still have your old adapter and has the same power specification try this first.
If the battery is hot and does not charge you might have a defective battery . Better have it checked at the service center before buying a brand new battery
Posted on Jun 23, 2008
Toshiba a205 s7466 will not turn on replaced cmos battery what next?
use old battery first try to boot
if your system is boot run bios update from intel.com
then change new battery
else run bios flash from chip level service provider
Feb 14, 2014 | Toshiba Satellite A205-S4617 Notebook
My battery charges but only lasts about 20 minutes once it says it is fully charged. Just purchsed a new battery thinking it was old (laptop is about 3 years old) and the same thing happens.
From what you describe and assuming the new battery was "new", I'd say you have an internal short which is draining the battery over a short period of time. I'd also investigate the accuracy of the battery charge indicator. Download this free utility which will give you a more accurate picture of your battery:
http://www.mioplanet.com/products/batterymeter/
I'm assuming you gave the battery a "commissioning charge" when you bought and used it?
If not, this is something you should do with all new LI batteries. This bit is reproduced from a website that sells batteries for the Toshiba satellite series:
"2. The new Toshiba Satellite a205-s4777 battery pack needs to be circled (fully discharged and recharged) three to five times to reach its optimum performance.
3. Toshiba Satellite a205-s4777 battery will undergo self-discharging when left unused for a long period of time. Thus, it should always be stored in a fully charged state and kept in a cool, dry and clean place.
4. It is normal if the new Toshiba Satellite a205-s4777 battery gets warm when being charged or used. However, please pay special attention if the battery pack becomes excessively hot. This may indicate there is a problem with the charging circuit of the electronic device. Please consult a qualified technician if necessary.
5. To maintain the optimum performance of Toshiba Satellite a205-s4777 battery pack, it is highly recommended to circle (fully discharging and recharging) it at least once a month.
6. New batteries are hard to be charged. Sometimes, your electronic device may indicate a fully charged condition about 10 to 15 minutes when Toshiba Satellite a205-s4777 battery pack is being charged for the first time. When this happens, remove the battery pack and let it cool down for about 10 to 15 minutes then repeat the charging procedure. Sometimes, the new Satellite a205-s4777 battery will suddenly refuse to be charged. If this happens, a suggested solution is trying to remove the battery from the device and insert it again. "
Jul 21, 2011 | Toshiba Satellite A205-S4777 Notebook
Toshiba SATELLITE A205-S4577 CORE 2 DUO INTEL. When conected to the external power supply the notebook suddenly interrupts its functioning and it is necessary to do a hard power off, becouse nothing more...
- possible problem with the AC power supply
- try using a different AC adapter. if issue persist try flashing the BIOS. if issue still persist then have the motherboard checked out.
Mar 29, 2011 | Toshiba A205-S4577 Notebook
My Toshiba laptop battery light flashes 6 times but wont turn on? Dead battery?
Most laptop battery can be normal used in 400-500 charge and discharge cycles, in another word, a laptop battery should be normal in 2 year.
maybe your laptop battery is dead....
you should buy a new one.
here is the replacement toshiba laptop battery online shop for you to consider to buy one there:)
May 23, 2010 | Toshiba Satellite A205-S4617 Notebook
Satellite A205-S4617 15.4" Notebook PC (Intel Core 2 Duo Processor T5500, 2 GB RAM, 250 GB H... PC Notebook: laptop is not starting...what should i do?...
First check wheather battery is dead . Charge it completely and also check the lights while charging.
If you think its battery issue try the following remove the battery and then press the power on button, it help release and electricity left then place the batter back . and Power it on.
If the lights just blink then...press and hold the battery button for force a shut down then power it back on.
=======================MENTOR======================
May 17, 2010 | Toshiba Satellite A205-S4617 Notebook
Satellite A205 hang on AC power in Vista, Win7 but not XP?
Probably you will have to upgrade your drivers, specially power management.
Mar 12, 2010 | Toshiba Satellite A205-S4617 Notebook
Suddenly my Toshiba Satellite A205 laptop died. No power.
First, check your power supply (the adapter). Is it putting out the required voltage to charge the battery?
If not, then you might have a dead battery and no way to charge it.
If the power supply is working and when you turn on the computer you get no lights, then you're probably looking at a new motherboard.
If you get startup lights and hear the fan, then it's getting power and you might have a video problem. But it sounds like, from what you wrote, there is no activity at all when you try to start it. That would be the power circuit on the motherboard, most likely.
Jan 09, 2010 | Toshiba Satellite A205-S4617 Notebook
Satellite a205 died. will not power up at all. 2
Go to the Toshiba web site. They often extend the warranty on laptops with common problems.
Problem with my laptop battery
the cells of battery had dead, you need to replae the cells or battery.
Nov 24, 2008 | Toshiba Satellite A205-S4617 Notebook
Toshiba Satellite A205-S4617 Notebook Logo
188 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
