Question about IBM (3582L23QC1HVD) Ultrium Tape Drive
Backup problem the backup is complete, but it showing red c signal in the front panel
  • 2,567 Answers
This means that the drive's head needs cleaning. So, load the cleaning tape into the drive to start the cleaning function.
Posted on Jul 22, 2009
Signal lights not working in my car in front and back. backup lights work.
Signal lights and backup lights are generally on two completely different circuits. Check your fuses first.
Sep 16, 2016 | Cars & Trucks
I have sky tv and a marantz system, marantz system flashes pcm dig and tv loose signal intermittently, help
Your Sky box might need a firmware refresh. Switch it off at the mains socket. Press and hold down the BACKUP key on the SKY BOX (not the remote). Switch on at the mains and keep the backup key pressed down until the TV shows an info screen that the box is updating.
Allow the box to complete the cycle.
Try your system again.
Sep 02, 2014 | Marantz Audio Players & Recorders
2003 Yukon XL Denali Trailer Light Problems
Lighting control module ? ?????? Hazard / flasher module ! Now ( there''s not even an electrical signal where the fuse plugs into the interior fuse panel.) What FUSE ??????
Stop Lamps
The STOP LP 25 A fuse in the underhood fuse block supplies battery positive voltage to the normally open stop lamp switch. When the driver presses the brake pedal, the switch contacts close and battery positive voltage is supplied to both the STOP 15 A fuse and the CHMSL 10 A fuse in the I/P fuse block, and to the turn signal/hazard module. The turn signal/hazard module then supplies voltage to both of the trailer rear turn/stop lamp supply voltage circuits. The voltage from the CHMSL 10 A fuse is to the center high mounted stop lamp (CHMSL) and the trailer jumper harness. The voltage from the STOP 15 A fuse is to the stop lamps, throttle actuator control (TAC) module, and the cruise control.
Backup Lamps
The backup lamp request signal is sent from the powertrain control module (PCM) to the body control module (BCM) on the Class 2 message system. This signal is based on the park neutral position (PNP) switch signal. The BCM supplies voltage on the backup lamp supply voltage circuit to the backup lamps and to the automatic day/night mirror. Voltage for the courtesy lamp supply voltage circuit and backup lamp supply voltage circuit is from the TBC B fuse in the instrument panel fuse block directly through the BCM to these circuits. A short to ground on either of these circuits will open the fuse. The backup lamps are grounded at G401.
For trailer wiring, a separate backup lamp circuit is connected through the underhood fuse block from the TRLR B/U 10 A fuse to the trailer wiring harness.
Turn Signal/Hazard Lamps
The IGN E 10 A fuse in the underhood fuse block supplies battery positive voltage to the turn signal/hazard switch assembly. The FLASH 25 A fuse in the I/P fuse block supplies battery positive voltage to the turn signal/flasher module and ground is supplied at G200. When the turn signal switch is placed in either the left or right position, a voltage signal is completed from the turn signal switch to the turn sign/flasher module. When the hazard flasher switch is activated, a ground signal is completed from the turn signal/hazard switch to the turn sign/flasher module. The turn sign/flasher module then sends an on-off voltage signal through the LT TRLR, RT TRLR, LT TURN or RT TURN 10 A fuses in the I/P fuse block to the appropriate turn signal or to all 4 fuses for hazard operation. The instrument panel cluster (IPC) indicators receive voltage from the LT TURN and RT TURN fuses as well as the DDM/PDM for the mirror turn signals. The DDM/PDM has no function or control of the mirror turn signals other that a pass through connection for the circuits. The audio chime is also activated when the turn signals are on. When the hazard switch is pressed, all turn signal lamps will flash including both IPC turn indicators. The front turn signals are grounded at G100. The rear turn signals are grounded at G401. The Mirror turn signals are grounded by the DDM/PDM.
Do you know how to do automotive electrical circuit testing with a test light or volt meter ? How to read an use a wiring diagram to pin point testing points . ( connectors , fuse locations etc... ) How to use a power flow chart ? Here is a site for just such info .
http://www.bbbind.com/free_tsb.html Enter vehicle info . year , make , model an engine size . System click lighting , subsystem exterior lighting . Second diagram shows trailer wiring .
Electric Testing Techniques You Need to Know
Mastering Voltage Drop Testing with Pete Meier and Jerry Truglia
CHEVROLET 2007 SILVERADO TRAILER LIGHT TROUBLESHOOTING
Apr 07, 2017 | 2003 GMC Yukon Denali
Red vertical lines on right side of LED TV set
It is likely the main board that processes all signal to and from the display panel (entire front screen unit).
It is also possible it is the display panel itself which is fatal.
May 16, 2012 | LG 55LX9500 55 in. 3D HD-Ready LCD TV
Blinking red light. power off power on no success
May I suggest, you have a bad power supply. I did repair this model once, in that case it was a bad signal board. I would certainly think that the power supply is at fault in this case. This would be more common than a signal board. I wish I could provide with a complete repair. I would investigate with my first option. Thanks for asking and show all hands of support!
Sep 01, 2011 | Sony BRAVIA KDL-52S4100 52 in. HDTV LCD
I have sound but no picture
there are several things it could be. if connected to stereo and tv is turned off, will still get audio but no video. also check cabling, if have a different set of cabling, try that. if you have a satellite box, the signal may need refreshed. you would contact your satellite provider to refresh the signal (something that has to be done on their end) or also if you have a satellite box, try resetting (some models have door you can open on front panel red reset on inside) others require hard reset (by unplugging for 15 seconds)
Apr 04, 2009 | Televison & Video
How do you do a hard reset on a treo 650
1. Backup your data first.
2. While holding the red hang-up key, click the reset button. Keep holding the red key until after the progress bar completes and the Palm logo shows.
3. You are then asked if you are really sure - Pressing the up key at this point completes the hard reset.
Dec 18, 2008 | Palm Treo 650 Handheld
IBM (3582L23QC1HVD) Ultrium Tape Drive Logo
307 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
