Question about Frigidaire Dryers
This is the 2nd time my dryer in 1 year just stopped working and last time it cost me $100
  • 525 Answers
Http://www.repairclinic.com/0088_8_1.asp#Level1_1
If your dryer doesn't work at all, it could be because of problems with:
Power from the house
Door switch
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
There's no heat If your dryer doesn't heat, check these:
Heating element
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 23, 2008
How to calculate the cost of equity
final value = principal value x (1+I)^n
I= interest rate for n say 10% it would be 0.10
if n= 1 year then interest rate if
one year interest rate so if 5 years n= 5
if interest rate is monthly then divide year int rate by 12
and increase n by 12 so 5 years equals 60 terms of interest calculation.
cost of equity would be pv + pv * CPI
if CPi was 2.5% as an example
cost of equity for year one= PV + (PV * 2.5/100)
fv = pv*(1+2.5/100)^1
if cpi is different each year then
fv= pv1(1+2.5/100)^1 + pv1(1+cpi2/100)^1 + pv1(1+cpi3/100)^1
If CPI is same for each year then FV = PV (1+0.025)^number of years.
^ 2 is like squared
Jul 20, 2016 | Furniture
Toshiba 52hm95 lamp breaks after only weeks of use
It is as far as the set is concerned, it sees the lamp not on.
Most likely cause would be the lamp ballast that drives the lamp.
Dec 20, 2012 | Toshiba 52HM95 52" HDTV Projection...
My gas dryer started beeping intermittantly while not in use. When I went to check on it, the lights for the towel setting were on (which was not even the last setting used). When I pushed the...
I say it depends what its going to cost to repair. I had a dryer that worked twenty years and when I replaced it they told me I would be lucky to get eight to ten years out of a new one. Its a throw away society now days.
Mar 03, 2017 | Whirlpool GGW9868K Gas Dryer
Dryer won't start-Get a buzzing sound when pressing Start
Sounds like motor cost any where from $100 to $150
maybe a little cheaper if find the right place
Apr 24, 2010 | Dryers
Goes on works about 10 minutes. stop.try to turn
Problem is the motor is going bad. Sometimes the motor can almost cost as much as a new dryer. An excellent little dryer that will last and work ghood for you is Roper, made by whirlpool. Any Lowes store has these. Hope this helps.
Mar 19, 2010 | Frigidaire Dryers
I have to push the on and off button about 30 to 80 times till it turns on it is a 220- dryer
Your problem may be the council the part your finger actually touches or it may be the board behind the council. Something is not connecting. Either part will cost well over $100. The warranty is one year parts and labor The Average life of any appliance is 7-10 years. 1-800-688-9900 is customer service. It may be Whirlpool who answers they now own Maytag. Good Luck.
Dec 30, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Dryer stopped 1/2 way through cycle-hit start, drum won't turn
if the unit is sounding like it is struggling to start then you most likely have a bad bearing in the motor. they will usually get noisy and the become worse and louder. the unit also will run for awhile and then stop with the clothes not dry, if you try to start it it will go but will stop again shortly later.
if this unit is fairly old, like more then 10 years, you might want to look at the price of a new unit versus replacing the motor. the motor could cost you about 100-120 bucks if you put it in yourself and another 100 bucks if you pay someone to put it in for you. most new dryers will cost about 250-300 bucks, so the choice is up to you.
Dec 27, 2008 | Kenmore 63942 Dryer
Asko T701 Dryer - Dryer Start Button
This would have to be your door latch, in my opinion. The door simply is not holding in the button.
Dec 07, 2008 | Asko T701 Electric Dryer
Dryers Logo
114 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
