1997 BMW Z3 Roadster Logo
Posted on Nov 24, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to remove the harmonice balancer on a bmw 1.9 liter 4 cylinder engine. I can not turn the large bolt on the end of the crankshaft. Is it a left hand thread?
Auto Repair Help
Level 3:
  • BMW Master 1,420 Answers
  • Posted on Nov 24, 2010
Auto Repair Help
BMW Master
Level 3:
Answers
1420
Questions
0
Helped
667074
Points
4361
Welcome to FIxYa.com
Remove Harmonic Pulley
If necessary, remove drive belt and belt pulley for the air
conditioning compressor.
Remove drive Belt or alternator, refer to Drive Belts, Mounts,
Brackets and Accessories.
Attach Special Tool II 2 150 in conjunction with Special Tool il
2410.
Note:
Protect engine bracket from damage.
Insert wood between engine support and Special Tool 11 2
150.
Unscrew central bolt.
Replace crankshaft radial sealing ring, refer to Front Crankshaft
Seal, Service and Repair.
Installation:
Position the vibration damper in such a way that groove and
Woodruff key are aligned.
Replace central screw.
Tightening torque, refer to Engine. Specifications.
Thank you for using FixYa.com
Regards, Lee Davidian
Please can you help with all the torque settings for the cylinder head on Hyundai Accent 1.5 1995"
Nissan Frontier, Xterra 1998-05
Torque Specifications
Fig.
TORQUE SPECIFICATIONS
all readings in ft. lbs. Year Engine Displacement Liters (cc) Engine ID/VIN Cylinder Head Bolts Main Bearing Bolts Rod Brearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Lug Nuts Intake Exhaust 1998 2.4 (2389) KA24DE
1A Step 1: 22 ft. lbs.
2B 10-12 ft. lbs. plus 60-65 degrees or 28-33 ft. lbs.
4C The cylinder heads and the lower intake manifold are installed together
all readings in ft. lbs. Year Engine Displacement Liters (cc) Engine ID/VIN Cylinder Head Bolts Main Bearing Bolts Rod Brearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Lug Nuts Intake Exhaust 1999 2.4 (2389) KA24DE 3.3 (3277) VG33E
all readings in ft. lbs. Year Engine Displacement Liters (cc) Engine ID/VIN Cylinder Head Bolts Main Bearing Bolts Rod Brearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Lug Nuts Intake Exhaust 2000 2.4 (2389) KA24DE 3.3 (3277) VG33E
all readings in ft. lbs. Year Engine Displacement Liters (cc) Engine ID/VIN Cylinder Head Bolts Main Bearing Bolts Rod Brearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Lug Nuts Intake Exhaust 2000 3.3 (3277) VG33E
1A The cylinder heads and the lower intake manifold are installed together
3C Step 1: Tighten the cylinder head bolts to 22 ft. lbs.
4D Step 1: Tighten the connecting rod bearing bolts to 10-12 ft. lbs.
all readings in ft. lbs. Year Engine ID Engine Displacement Liters Cylinder Head Bolts Main Bearing Bolts Rod Bearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Oil Pan Drain Plug Intake Exhaust 1998 KA24DE
1- Step 1: 22 ft. lbs.
2- 10-12 ft. lbs. plus 60-65 degrees or 28-33 ft. lbs.
3- The cylinder heads and the lower intake manifold are installed together
4- 10-12 ft. lbs. +60-65 degrees
5- Step 1: 72 ft. lbs.
6- Step 1: bolts 11-22 19 ft. lbs.
7- Step 1: 20 ft. lbs.
8- Step 1: 31 ft. lbs.
9- 83 inch lbs.
10- Stud bolt: 11 ft. lbs.
11- Step 1: 72 ft. lbs.
12- Bolts: 17-24 (M8) 16 ft. lbs.
13- Step 1: 33 ft. lbs.
14- Intake manifold collector:
15- Intake manifold:
all readings in ft. lbs. Year Engine ID Engine Displacement Liters Cylinder Head Bolts Main Bearing Bolts Rod Bearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Oil Pan Drain Plug Intake Exhaust 1999 KA24DE VG33E
9- 83 inch lbs.
all readings in ft. lbs. Year Engine ID Engine Displacement Liters Cylinder Head Bolts Main Bearing Bolts Rod Bearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Oil Pan Drain Plug Intake Exhaust 2000 KA24DE VG33E
9- 83 inch lbs.
all readings in ft. lbs. Year Engine ID Engine Displacement Liters Cylinder Head Bolts Main Bearing Bolts Rod Bearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Oil Pan Drain Plug Intake Exhaust 2001 KA24DE VG33E
9- 83 inch lbs.
all readings in ft. lbs. Year Engine ID Engine Displacement Liters Cylinder Head Bolts Main Bearing Bolts Rod Bearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Oil Pan Drain Plug Intake Exhaust 2002 KA24DE VG33E VG33ER
9- 83 inch lbs.
all readings in ft. lbs. Year Engine ID Engine Displacement Liters Cylinder Head Bolts Main Bearing Bolts Rod Bearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Oil Pan Drain Plug Intake Exhaust 2003 KA24DE VG33E VG33ER
9- 83 inch lbs.
all readings in ft. lbs. Year Engine ID Engine Displacement Liters Cylinder Head Bolts Main Bearing Bolts Rod Bearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Oil Pan Drain Plug Intake Exhaust 2004 KA24DE VG33E VG33ER
9- 83 inch lbs.
all readings in ft. lbs. Year Engine ID Engine Displacement Liters Cylinder Head Bolts Main Bearing Bolts Rod Bearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Oil Pan Drain Plug Intake Exhaust 2005 QR25DE VQ40DE
9- 83 inch lbs.
Main Bearing Torque Sequence
Fig. Main bearing torque sequence-2.4L engine
Fig. Main bearing torque sequence-2.5L engine
Fig. Main bearing torque sequence-3.3L engine
Fig. Main bearing torque sequence-4.0L engine
What is the torque spec for a 2003 jeep wrangler 2.4 connecting rods
  • ENGINE 2.4L
DESCRIPTION
N·m
Ft. Lbs.
In. Lbs.
Balance Shaft Carrier to Block-Bolts
54
40
Balance Shaft Gear Cover-Double Ended Fastener
12
105
Balance Shaft Sprocket- Bolt
28
250
Balance Shaft Chain Tensioner-Bolts
12
105
Balance Shaft Carrier Cover-Bolts
12
105
Camshaft Sprocket-Bolt
101
75
Connecting Rod Cap-Bolts
54 +1/4 turn
40 +1/4 turn
Crankshaft Main Bearing Cap/Bedplate - M8 Bolts
34
250
M11 Bolts
41 +1/4 Turn
30 +1/4 Turn
Crankshaft Damper
136
100
Cylinder Head Cover- Bolts
12
105
Flex Plate to Crankshaft
95
70
Flywheel Mounting Bolts
81
60
Engine Mount Bracket Right-Bolts
61
45
Exhaust Manifold to Cylinder Head-Bolts
23
200
Exhaust Manifold Heat Shield-Bolts
12
105
Intake Manifold - Lower -Bolts
28
250
Oil Filter
20
15
Oil Pan-Bolts
12
105
Oil Pan Drain-Plug
27
20
Oil Pump to Block-Bolts
28
250
Oil Pump Cover Plate-Bolts
12
105
Oil Pump Pick-up Tube-Bolt
28
20
Oil Pump Relief Valve-Cap
41
30
Spark Plugs
28
Timing Belt Covers - Front Covers to Rear Cover-Bolts
12
105
- Rear Cover-Bolts
12
105
Timing Belt Tensioner Assembly-Bolts
61
45
3helpful
2answers
Where is the crankshaft sensor on a 3.8L in a 97 buick lesaber
The sensor is located to the right of the crankshaft behind the vibration dampner (harmonic balancer). You will need a balancer puller and a special tool to space the new sensor correctly.
(can be done also with eye spacing, but the tool is recommended to ensure proper spacing as to prevent damage to new sensor and / or harmonic balancer.) You will also need a strap wrench to hold balancer pulley in place while removing and re-installing balancer to crankshaft bolt. (helper required)
Procedure for replacement:
Remove negative battery cable.
Set parking (emergency) brake.
Release tension on serpentine drive belt and remove belt from harmonic balancer pulley. ( large pulley at bottom of engine)
Break loose lug nuts on passenger side front tire, do not remove bolts yet.
Raise and support vehicle on passenger side, remove wheel.
Remove plastic splash guard (cover) from passenger side wheel well.
Remove dampner / balancer center retaining bolt (counterclockwise, it is torqued very tight.) Use a strap wrench around pulley and have a helper hold that in place while using a 1/2" breaker bar and socket to turn pulley bolt out of crankshaft. Be careful not to rotate engine in a counterclockwise direction while breaking the bolt loose.
Using balancer puller, remove dampner / balancer pulley from engine.
You will now see the crank sensor to the right of the crankshaft bolted to the timing cover.
Disconnect sensor wiring and remove retaining bolts, remove sensor.
Put new sensor in place and screw in bolts, do not tighten them yet.
Reconnect wiring to sensor.
Now use special tool to properly space sensor. If you cannot find one at the parts store, you can space the sensor with the balancer pully held in place (not installed yet) and space the sensor evenly with the veins on the hub of the balancer pulley. Take your time and be sure it is as evenly spaced as possible.
Tighten sensor bolts.
Clean balancer hub free of any oil and dirt deposits using brake or carbeurator cleaner.
Reinstall balancer to crankshaft by tapping around the inner surface of pulley with a rubber hammer.
It is a press fit, so be sure you have it started evenly and progress slowly in a circular motion to ensure you are keeping it aligned straight with the crankshaft.
Reinstall balancer bolt using the same method as removal, torque bolt to 110 foot pounds, then tap around balancer again twice with rubber hammer, turn the engine 2 full revolutions clockwise using the balancer to crankshaft bolt, then tighten bolt an additional 1/4 turn.
Replace splash guard, put wheel on tightening lugs to finger tight and then wrench tight in a star pattern.
Lower vehicle until wheel makes contact with floor, tighten lug nuts to 115 foot pounds in a star pattern using a torque wrench.
Fully lower vehicle, remove jack.
Re-install serpentine drive belt
Re-connect negative battery cable.
End of procedure....Hope that helps!.....Mike
4cyl 2000 honda accord engine stalls while idling, recently died and will only start for short periods... possible problems/solutions?
check for spark and fuel after it dies.
If there is spark but no fuel, then the fuel pump may be bad or a clogged fuel filter.
If there is fuel but not spark, then the ignition control module or the ignition coil could be bad.
Also, check that the timing belt is timing the engine correctly.
Timing Belt & Balancer Belt
Removal & Installation
2.3L Engine
To Remove:
  1. Record anti-theft code for radio.
  2. Disconnect battery negative cable then positive cable.
  3. Turn crankshaft pulley until TDC is achieved.
  4. Raise and safely support vehicle.
  5. Remove front tire assembly.
  6. Remove splash shield.
  7. Remove power steering belt.
  8. Remove alternator and alternator bracket.
  9. Safely support engine under oil pan.
    Upper bracket removal
  10. Remove stop, detach ground cable and remove upper bracket.
  11. Remove cylinder head cover.
  12. Remove upper cover.
  13. Remove dipstick and tube assembly.
  14. Remove crankshaft pulley.
  15. Remove adjusting nut rubber seal and remove lower cover.
    Timing belt/balancer belt removal
  16. Loosen adjusting nut 1 turn.
  17. Push up on balancer belt tensioner to relieve belt tension.
  18. Push down on timing belt tensioner to relieve belt tension.
  19. Tighten adjusting nut 1 turn.
  20. Remove balancer belt and timing belt.
To Install:
NOTE: Clean balancer belt drive pulley, timing belt pulleys and
upper/lower timing cover prior to belt installation.
  1. Set timing belt drive pulley to TDC by aligning dimple on pulley with dimple
    on oil pump.
  2. Set camshaft pulley to TDC so that "UP" mark is at top and grooves align
    with top of cylinder head.
    Timing belt installation
  3. Starting with driver pulley, install timing belt in a counterclockwise
    sequence.
  4. Loosen and ten retighten adjusting nut.
  5. Install balancer belt drive pulley.
    NOTE: Inspect rubber seal on lower cover and replace as necessary.
  6. Install lower cover.
  7. Install crankshaft pulley and bolt.
  8. Rotate crankshaft pulley counterclockwise several times to seat belt.
  9. Loosen adjusting nut 1 turn.
  10. Rotate crankshaft counterclockwise 3 teeth on camshaft pulley.
  11. Tighten adjusting nut to 33 ft lb (44 Nm).
  12. Turn crankshaft pulley until TDC is achieved.
  13. Ensure that camshaft pulley "UP" mark is at top and grooves align with top
    of cylinder head.
  14. Remove crankshaft pulley and lower cover.
  15. Rotate crankshaft to TDC again and lock timing belt adjuster arm with a 6 mm
    timing cover bolt.
  16. Loosen adjuster nut 1 turn and ensure that belt tensioner freely moves.
  17. Push tensioner up and tighten adjusting nut.
    Balancer shaft alignment
  18. Remove bolt and washer from maintenance hole.
  19. Using a 6 X 100 mm bolt, scribe a mark 2.9 in (74 mm) from end.
  20. Insert bolt into maintenance hole and hole in balancer shaft.
  21. Install bolt up to scribed line.
  22. Align groove on balancer shaft with pointer on oil pump housing.
  23. Install balancer belt and loosen adjusting nut 1 turn to tension.
  24. Retighten bolt.
  25. Remove bolt from maintenance hole and install bolt and washer. Tighten to
    22 ft lb (29 Nm).
  26. Reinstall crankshaft pulley.
  27. Loosen adjusting nut 1 turn.
  28. Rotate crankshaft pulley counterclockwise 1 turn and tighten adjusting nut.
  29. Remove bolt from timing belt adjuster arm.
  30. Remove crankshaft pulley.
  31. Install lower cover.
  32. Install seal at adjusting nut.
    NOTE: Crankshaft pulley, bolt and washer must be cleaned prior to
    installation.
  33. Lubricate crankshaft pulley bolt between head and washer and bolt threads
    with clean engine oil.
    CAUTION
    Do not use impact wrench to perform
    following step.
  34. Install crankshaft pulley and tighten bolt using special tools to 181 ft
    lb (245 Nm)
  35. Install dipstick/tube assembly.
  36. Install upper cover. Tighten bolts to 9 ft lb (12 Nm).
  37. Install cylinder head cover.
  38. Install alternator bracket and alternator.
  39. Install power steering pump belt and alternator belt.
    Upper bracket installation
  40. Install upper bracket and tighten fasteners in proper numbered sequence.
  41. Install stop.
  42. Install battery and enter radio anti-theft code.
Hiwich timing mark I used to time the balancer shaft on a 99 honda accord with a 2.3L
To Install:
NOTE: Clean balancer belt drive pulley, timing belt pulleys and upper/lower timing cover prior to belt installation.
  1. Set timing belt drive pulley to TDC by aligning dimple on pulley with dimple on oil pump. honda-03-23-3426.gif
  2. Set camshaft pulley to TDC so that "UP" mark is at top and grooves align with top of cylinder head. Timing belt installation honda-03-23-3549.gif
  3. Starting with driver pulley, install timing belt in a counterclockwise sequence.
  5. Install balancer belt drive pulley. NOTE: Inspect rubber seal on lower cover and replace as necessary.
  13. Ensure that camshaft pulley "UP" mark is at top and grooves align with top of cylinder head.
  15. Rotate crankshaft to TDC again and lock timing belt adjuster arm with a 6 mm timing cover bolt.
  17. Push tensioner up and tighten adjusting nut. Balancer shaft alignment honda-03-23-3556.gif
  21. Install bolt up to scribed line. Balancer shaft alignment honda-03-23-3557.gif
  25. Remove bolt from maintenance hole and install bolt and washer. Tighten to 22 ft lb (29 Nm).
  29. Remove bolt from timing belt adjuster arm. NOTE: Inspect rubber seal on lower cover and replace as necessary.
  32. Install seal at adjusting nut. NOTE: Crankshaft pulley, bolt and washer must be cleaned prior to installation.
  33. Lubricate crankshaft pulley bolt between head and washer and bolt threads with clean engine oil. honda-03-23-3537.gif
    CAUTION
    Do not use impact wrench to perform following step.
  34. Install crankshaft pulley and tighten bolt using special tools to 181 ft lb (245 Nm).
  39. Install power steering pump belt and alternator belt. Upper bracket installation honda-03-23-3420.gif
  41. Install stop.
I am having troubles locating the cam shaft timing marks on my 1999 VW passat VR6 engine. any ideas
hi, here is a guide i have come across on this site written by another expert it should be the one for your engine but always double check.
If you are unsure what you are doing then please go out and buy a haines workshop manual as these tell you every detail you need to know so that would be your best solution.
Please dont do this work if your unsure what you are doing as you could damage the engine beyond repair so you have been warned;
it covers single cam and if you scroll down it shows double cam ok
Sep 14, 2009 - VW Passat & Audi A4 1990-2000 Repair Guide
Timing Belt - REMOVAL & INSTALLATION
2.8L SOHC (AFC) V6 Engine
  1. Note the radio security code and disconnect the negative battery cable.
  2. Place the (hood) lock carrier in the service position. For additional information, please refer to the following topic(s): Body And Trim, Service Position, Front Bumper, Hood Lock Carrier.
  3. Remove the engine accessory drive belt. For additional information, please refer to the following topic(s): General Information And Maintenance, Routing Maintenance And Tune-up.
  4. Turn the engine by hand to Top Dead Center (TDC) on the firing stroke for cylinder No. 1.
NOTE The large holes in the camshaft sprocket lock plates should be on the inside facing one another.
  1. Remove the Crankshaft Position (CKP) sensor from the lower left side of the engine block. Make sure the engine is at TDC and install the threaded crankshaft holding pin Tool No. 3242 and lightly tighten.
  2. Remove the upper timing belt covers, the crankshaft vibration damper and then the lower timing belt cover.
  3. Loosen the camshaft sprocket bolts slightly and use a suitable pulley to release the sprockets from the tapered ends of the camshafts.
  4. Loosen the tensioner roller and remove the drive belt.
To install :
  1. Install the timing belt over the sprockets, then the idler rollers and lastly over the tensioner.
  2. Install camshaft alignment tool holder Tool No. 3243 into the camshaft alignment flanges.
  3. Check and adjust the cam belt tension such that the upper left portion of the belt between the tensioner and the left cam gear can just be twisted 90° ( 1 / 4 turn).
  4. Tighten the cam belt tensioning roller to 33 ft. lbs. (45 Nm), and the camshaft sprocket bolts.
  5. The balance of the installation is in reverse order of removal.
2.8L DOHC 5V (AHA) V6 Engine
  1. On the cylinder block near the crankshaft, remove the sealing plug from the lower left side of the engine block. Make sure the engine is at TDC and install the threaded crankshaft holding pin Tool No. 3242 and lightly tighten.
  4. Using a 8mm Allen® wrench, rotate the timing belt tensioner roller clockwise until the tensioner is compressed; then, insert a 2mm spring pin through the tensioner housing and tensioner plunger to secure it in place. When the plunger is secure, release the wrench tension.
  5. Remove the damper-to-crankshaft bolts and the damper.
NOTE It is not necessary to remove the center bolt when removing the crankshaft damper.
  1. Remove the serpentine belt idler and the crankshaft damper guard.
  2. Mark the running direction of the timing belt and remove it from the pulleys.
Fig. Crankshaft pulley alignment location for TDC-Audi 2.8L V6 engines
Fig. Left camshaft sprocket alignment position for TDC; right camshaft position is similar-Audi 2.8L V6 engines
Fig. View of crankshaft holding tool installed-Audi 2.8L V6 engines
Fig. View of camshaft locator bar installed-Audi 2.8L V6 engines
To install:
  1. Make sure that the camshaft pulleys and the crankshaft pulley are in alignment with TDC of the No. 1 cylinder's compression stroke.
  2. Install the timing belt; make sure the timing belt is installed in the correct running direction from which it was removed.
  3. Using a 8mm Allen® wrench, rotate the timing belt tensioner roller clockwise until the tensioner is compressed; then, remove the 2mm spring pin from the tensioner housing. Slowly, release the tensioner spring pressure to put pressure on the timing belt.
  4. Install the crankshaft damper guard and the serpentine belt idler pulley; torque the idler pulley bolts to 33 ft. lbs. (45 Nm).
  5. Install the crankshaft damper and torque the damper-to-crankshaft bolts to 15 ft. lbs. If the damper-to-crankshaft center bolt was removed, torque it to 147 ft. lbs. (200 Nm) plus 180° 1 / 2 turn).
  6. Remove the Crankshaft Holder tool No. 3242 and install the sealing plug.
  7. Replace the remaining components by reversing the removal procedures.
  8. Refill the cooling system and the automatic transaxle. Connect the electrical connectors. Install the negative battery cable last.
  9. Test drive the vehicle.
2helpful
How i fix timing of lantra 1600 cc 95
Disconnect battery earth lead. Do not turn crankshaft or camshaft when timing belt removed. Remove spark plugs to ease turning engine. Turn engine in normal direction of ratation unless otherwise stated, Support engine. Remove, engine mounting, auxilliaty drive belts. Water pump pulley 1. Crankshaft pulley bolts 21. crankshaft pully 2. timing belt covers 3. Turn crankshaft to TDC on No 1 cyclinder. Ensure crankshaft sprocket, camshaft sprocket, oil pump sprocket and balancer shaft sprocket timing marks aligned. Timing marks on camshaft sprockets should align with cylinder head upper face. Dowel pins on camshaft sprockets should face upwards. Slacken tensioner bolt. Move tensioner away from belt and lightly tighten bolt. Remove, automatic tensioner unit bolts. Automatic tensioner unit. Timing belt, crankshaft centre bolt, crankshaft sprocket. Crankshaft sprocket guide washer. Slacken blancer shaft belt tensioner bolt. Move tensioner away from belt and lightly tighten bolt. Remove balancer shaft belt.
Installation
Ensuring timing marks arligned. Note timing marks on camshaft sprockets should align with cylinder head upper face. Exhaust sprocket mark is on recess, but inlet sprocket mark is on tooth. Note: to check oil pump sprocket positioned correctly, removing blanking plug from cylinder block. Insert 8mm diameter Phillips srcrewdriver in hole. Ensure screwdriver is inserted 60mm from face of cylinder block. if screwdriver can only be inserted 20mm: turn oil pump sprocket 360°. Insert screwdriver again. Fit balancer shaft belt in anti-clockwise direction, starting at crankshaft sprocket. Slacken balancer shaft belt tensioner bolt. Turn tensioner clockwise to tension belt. Tighten bolt to 15-22Nm. Apply thumb pressure to belt. Belt should deflect 5-7 mm. If not repeat tensioning procedure. Install crankshaft sprocket guide washer, crnakshaft sprocket. Tighten crankshaft cente bolt. Tighten torque:110-130 Nm. Note ensure crankshaft sprocket guide washer is fitted correclty. Oil treads and contact face of crankshaft body before fitting. Check tensioner body for leakage or damage replace if necessary. Check pushrod protrusion is 12mm. If not replace automatic tensioner unit. Slowly compress pushrod into tensioner body until holes aligned. Resistance should be felt. Place flat washer under tnesioner body to avoid damage to body end plugs. Retain pushrod with suitable pin through hole in tensioner body. install automatic tensioner unit to cylinder block. Tighten bolts to 22-27Nm. Fit timing belt in anti-clockwise direction, starting at the tensioner pulley. Slacken tensioner pulley bolt. Turn tensioner pully clockwise to temporarily tension belt. Tighten bolts to 43-45Nm. Turn crankshaft slowly 1/4 turn anti-cockwise. Turn crankshaft clockwise until timing marks alligned. Slacken tensioner pully bolt. Fit tool to tensioner pulley. Tool No 09244 28100. Apply clockwise torque of 2,6-2,8 Nm to tensioner pulley. Tighten bolt to 43-45Nm. Insert special tool in timing belt rear casing. Tool no 09244-28000. Screw in tool until pin can be removed from automatic tensioner unit. Remove special tool. Tool nr 09244-28000. turn crankshaft two turns clockwise. Wait 15 minutes. Ensure timing marks aligned. Check extended length of pushrod is 3,8-4,5mm. Install components in reverse order of removal. Tighten crankshaft pulley bolts, Tighten torque 20-30Nm
I need to replace my timing belt on my hyundia elantra 2003 with 1997 cc engine
Dear Friend
Removal: Support engine: remove -engine mounting, auxiliary drive belt, water pump pulley, crankshaft pully bots & crankshaft pully, timing belt covers....turn crankshaft to TDC on No 1 cylinder, ensure crankshaft sprocket, camshaft sprocket, oil pump sprocket & balancer shaft sprocket timing marks lighned. Pls note: Timing marks on camshaft sprockets should align with cylinder head uppter face, dowl pins on camshaft sprockets should face downwards....Slacken tensioner botl. Move tensioner away from belt & tighten bolt.
Remove: automatic tensioner unit bolts, automatic tensioner unit, timing belt, crankshaft bolt, crankshaft sprocket, crankshaft sprocket guide washer...slacken balancer shaft belt rensioner bolt, move tensioner away from belt & lightly tighten bolt...Remove balancer shaft belt.
Installation:
ensure timeing marks aligned.Note: Timing marks on camshaft sprockets ahould align with cylinder head upper face, exhaust sprocket mark is on recess but inlet sprocket mark is on tooth. To check oil pump sprocket positionded sorrectly: remove blanking plug from cylinder block, insert 8mm diameter Phillips screwdriver in hole. ensure screwdriver is inserded 60mm from face of cylinder block. If screwdriveer can only be inserted 20mm-turn oil pump sprocket 360". Inset screwdiver again.
Fit balancer shaft delt in anti-clockwise direction starting at crandkshaft sprocket....Slacken balancer shaft belt tensioner notl, turn tensioner clockwise to tension belt. Tighten bolt to 15-22 Nm... Applu thump pressure to belt at tentioner, belt should deflect 5-7mm. If not: Repeat tensioning procedure.... Install - chankshaft sprocket guide washer & crankshaft sprocket.
Thighten crankshaft centre bolt, tightening torque:110-130Nm. Please note, ensure crankshaft sprocket guide washer is fittet correctly. oil threads & contact face crankshaft botl before fitting.
3helpful
I need a how to to change harmonic balancer for 1995 nissan maxima. step by step
First remove right front tire and support vehicle with a jack stand. Remove splash guard lower portion near the harmonic balancer. Remove all drive belts. First remove the A/C alternator belt. Loosen the 14mm bolt at the front of the belt tenioner and then loosen the tensioner bolt (it is the one that stands out, you use a socket on it.). The power steering adjuster bolt with be gained from the bottom. It has a 12mm bolt head on it. You will break the jamb bolt loose first and then loosen the adjusting bolt. Pull down on the belt the help move it after you've loosened it some.Then remove harmonic balancer bolt (19mm).If the harmonic balancer will not slide off the crankshaft then use a two finger gear puller. Place the harmonic balancer bolt back in the crankshaft but do not tighten it. Leave it about a half inch from being all the way in. Next place the puller onto the harmonic balancer (one finger on each side securely press into the belt groove. The center puller bolt will rest against the harmonic balancer bolt head. Tighten the puller bolt and make sure the harmonice balancer bolt does not turn. The balancer should come off at this point.
What is the procedure on removing an alternator from a 2001 Taurus with a duratec engine?
Okay, on your engine, the alternator is mounted below the rear cylinder bank of the engine, at the rear of the engine compartment. It'll be easier to access it from the driver's side front fenderwell (take off the right front tire then the plastic lining) or under the car. You might want to go ahead and remove both the liner and work from underneath as you'll need to remove your crankshaft pulley.
1: Disconnect the negative batery cable.
2: Disconnect the electrical connections from the alternator. The output wire is secured by a nut on the output terminal.
3: Revove the serpentine/drive belt.
4: Remove two bolts and one stud bolt that secure the alternator to it's bracket. Remove the crankshaft pulley.
Installation is reverse of removal.
After installing the alternator, reinstall the drivebelt and reconnect the negative battery cable.
To remove the crank-shaft pulley
1: As you'll aready have the wheel, liner, negative battery cable, and serpentine/drivebelt removed, as well as the car on jackstands, I'll omit those steps.
2: Remove the driveplate access cover and hold the ring gear teeth with a large scredriver or pry bar to prevent the crankshaft from turning.
3: Remove the nuts that secure the pullley bracket to the engine front cover. Remove the pulley and bracket.
4: The crankshaft pulley screws into the harmonic balancer with a left hand thread (reverse threaded so rightly loosey lefty tighty). Trun the crankshaft pulley clockwise to loosen and remove it.
5: Hopefully this is where you'll end with the pulley. The harmonic balancer is no fun to remove, but let me know if you need to know this too. After you have your alternator installed, put the pulley back onto the harmonic balancer before installing the serpentine/ drive belt.
Hope this info helps.
Top BMW Experts
vince
Steve Sweetleaf
Steve Sweetleaf
old marine
old marine
Are you a BMW Expert? Answer questions, earn points and help others
