Question about Frigidaire FTF2140E 3.5 Cu. Ft. Front Loading Washer
Will not work
When you close the door it will not lock and therefore it will not run.
Please help
  • rsl042 Jul 19, 2008
    My FTF2140E Locks for about 5 seconds and then unlocks.
  • soxxs Aug 08, 2008
    my problem is the same other then we had a lighting storm the night it stop working. my machine beeps three times when any button is pushed.i read some of the other models problems and tried to reset using the pause and start buttons , unplugging for five minutes then holding option button for five sec.also checked door switch it does not click when pushed i don't know if it should. thank you
  • 487 Answers
You might have to replace the doorlock switch assy. N#7 on DRAWING here you also can buy the parts you need
Posted on Jun 23, 2008
The front door won't close, due to washer lock mechanism restricting door close.
Thank you for your inquiry, kh57ca!
From what you are describing it sounds like the door latch assembly needs to be replaced. This is not a simple DIY job though. I would recommend seeking guidance from a professional technician to properly replace the door latch to avoid any future issues. Some of these intricate parts require precision and patience, therefore when replacing such components or removing them from your appliance, I would suggest seeking professional assistance. I hope this has been beneficial. -Matt
Oct 12, 2014 | Electrolux EWFLW65H 4.7 Cu. Ft. Washer
Door does not latch closed
latch on door is locked by old food or the latch spring is broken
Sep 16, 2014 | Samsung SMH9187B 1.8 Cu. Ft....
Bosche front loader de error message help
dE is a door error, check switch, door alignment and wiring harness
May 28, 2014 | LG WM-2277HW Front Load Washer
Driver door won't close 1999 ford contour
Drivers side door will not close because, it might have dropped out of alignment and is sagging down slightly!!! or if it has electric door locks, and someone in the family has failed to mention door locks were activated while that one door was still open!!! now lock mechanism has passed it's normal stopping place and is now stuck, therefore already locked and not allowing door to close all the way!! you might try disconnecting battery then try jiggling the lock, and hope silenoid didn't get burned out, open passenger door and look at lock latch, then check drivers side lock latch!!! if your lucky lock latch should unlock when battery is hooked back up. i have seen this problems happen often on older vehicles!!! especially on cars or trucks that have been in fender benders.........body shops know what to check for, they fix problems like this often!!!!! Good luck!!
Dec 13, 2010 | 1999 Ford Contour
Power window open partially with inside or outside
inside the mechanical lock (The part that actualy holds the door shut when you close it) there is a switch that informs the control unit that the lock is either locked or unlocked.
These switches fail sometimes, when this happens the control unit is not aware that you have opened the door, and therefor will not wind the window down slightly.
The switch is integral with the lock unit, and they are not easy things to replace either.
Feb 20, 2010 | 2003 Volkswagen New Beetle Convertible
Our Bosch SHY66C05 door latch is stuck in locked position
you have to pull back the spring or replace the lock. the repair is pretty easy.let me know what happen.
Nov 07, 2009 | Bosch 24 in. SHY66C05 Stainless Steel...
There is a small door that covers the area where the dishwasher tablet goes and this is not locking - therefore the dishwasher is not running properly (no water).
if you are not getting water into the machine you will likely need to replace the water inlet valve. if the soap/rinse dispenser door is not closing properly, make sure it is clean from built up soap etc. if it still doesn't close you will likely have to replace it as well.
Oct 16, 2009 | GE Dishwashers
Hello. I have an HP 2610xi. I opened to replace
There is no lock open postion, therefore no release button is provided.
Take the toner out that you just put in, then try to close door gently.
If the door closes ok the problem is with the toner. Check you have removed shipping pull tabs (Usually Orange) on new toner. Next, on one end of the drum shutter there should be a small point which the machine uses to open the shutter when you close the door. If the shutter won't open or the point is missing (Broken off) the printer door witll not close.
Cheers
DeJudge
Aug 05, 2009 | HP Color LaserJet 2600n Printer
Washer stops
Initially, pls open the lower access panel (bottom of your washer) by removing the 3 torx screws. There would be a sheet that lists the error codes. The panel pulls forward and down, inside mounted on the right side taped to that inner panel would be the above described sheet. Additionally, to my knowledge, this indicates a door latch fault, the machine cannot activate the lock or senses that the door is not closed or the door is not locked.
In some instances, the error code F/DL could be triggered be a loose component. This could be that the plastic fitting on the door is loose and therefore will not latch on the locking assembly or the locking assembly itself is loose. You could then try opening and closing the door a couple of times.
Should this be not corrective, then the logic controller board may require close checking.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 31, 2008 | Maytag Neptune MAH5500B Front Load Washer
Frigidaire Dishw. Error code CL
this just happened to ours and it turned out to be the gasket that seals the door.
when you see the CL error and the door is indeed shut, pull gently back on the door. if you hear a click and the unit starts running again, it may be the gasket.
ours lost it's ability to keep the seal, allowing enough 'play' in the locking mechanism for it to think the door was not closed.
Mar 14, 2008 | Dishwashers
Frigidaire FTF2140E 3.5 Cu. Ft. Front Loading Washer Logo
49 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
