When the disc player is turne on it says welcome and the it goes to init then please wait. ..then nothing
  • Anonymous Oct 17, 2008
    re: SA-HT670 system - When powered on I get the 'initializing..please wait' indefinitely. I tried re-aligning the trays with the spare gear but did not seem to help. I notice that the only function working now on the remote is the tuner button and none on the front panel with the exception of the SFC(heavy, soft, etc.). this does not make sense to a geek like myself.
OK, I am not a computer geek at all. . . and it was not me that found the solution. But I will describe it the best I can, which may be even better if I get my point across for anyone else that is as inept as I.
There is a hole on the bottom on the left of the unit. If you look in it, there is a gear that you can turn. Basically the housing of the cd's is stuck and if you move the gear this housing will rise when looking at the whole unit with the top off. You move the gear till the housing can go no higher and it is fixed!!!! Make sense? I really hope this helps. . .We almost had to buy another cd player. . . . Hopefully this one will last a few more months or even years.
Posted on Jun 24, 2008
My VL-875 MP3 player will not load past the "Please wait" welcome screen. It also will not turn off without having to press the "reset" button on the side.
Jan 31, 2010 | Visual Land V-Touch Digital Media Player
Freezes at welcome screen
Try to scan for viruses , if nothing happened , then try to update firmware !
good luck .
Jan 22, 2010 | Coby MP-C858 MP3 Player
Problem with my vtouch frozen on welcome screen
return it that is a well known problem and that happens to every 4 out of 10 vtouches just send a note explaining the situation and that you want a new one
May 29, 2009 | Visual Land V-Touch Digital Media Player
Tray won't open!
Hi, not being too familiar with this model ( i.e. whether a single disc or 5 disc changer). it sounds like the CD player section is trying to find home position and will not continue until it has done so. It is very likely that there is a disc in the mechanism and depending how competent you are with a screwdriver, you may be able to release the disc either by removing the top cover or check on the underside of the machineto see if there is a hole in the bottom where you can wind the cd mechanism to the eject position.
Dec 29, 2008 | Panasonic SC-HT940 System
Panasonic SA-HT692
that just happened to me last night. do you know if there is a disc inside the player? it's possible it is stuck and preventing the tray from opening.
Jan 04, 2008 | Panasonic Home Theater System System
Unit says Init Please Wait
I've just spent the last 3 nights trying to fix that same issue with my player. I ended up pulling out the dvd tray assembly, and making sure there wasn't anything broken inside or obstructing other pieces. Come to find out, my 1 year old had pulled on one of the trays and it pulled the tray off it's tracks. After that, it would just go to "init please wait" forever. I pulled the side track cover off and aligned the tracks manually. Everything had to be absolutely perfect or else you'd get nothing. After the fact, I realized that there were two holes in the bottom of the player that you can take a spare small gear (which is attached to the plastic cover on top of the dvd tray assembly) and stick it in there and manually adjust the tray positions to make sure everything is aligned properly. After messing with it three days, it ended up being quite simple to fix. Everything works like a charm now. If you need details, feel free to email me.
seeyouatthetop06@gmail.com
Oct 31, 2007 | Panasonic SC-HT670 System
Init please wait
I've just spent the last 3 nights trying to fix that same issue with my sa-ht670 player. I ended up pulling out the dvd tray assembly, and making sure there wasn't anything broken inside or obstructing other pieces. Come to find out, my 1 year old had pulled on one of the trays and it pulled the tray off it's tracks. After that, it would just go to "init please wait" forever. I pulled the side track cover off and aligned the tracks manually. Everything had to be absolutely perfect or else you'd get nothing. After the fact, I realized that there were two holes in the bottom of the player that you can take a spare small gear (which is attached to the plastic cover on top of the dvd tray assembly) and stick it in there and manually adjust the tray positions to make sure everything is aligned properly. After messing with it three days, it ended up being quite simple to fix. Everything works like a charm now. If you need details, feel free to email me.
Sep 01, 2007 | Panasonic SC-HT670 System
Disc tray 1 is blinking with 2 ovals around it, tray not in right Panasonic SA-HT680
I had a jammed disc that was causing this same error message. To remove the jammed disc, remove the top by removing the screws and then you can remove the stuck/jammed discs. For the Panasonic SC-PT750 there are 7 screws, three small silver ones on the back, then 4 black ones, two on each side, all philips head. Once you have that off, gently pry it off starting from the back, the cover is actually hinged into the front plastic piece of the player.
Nov 19, 2006 | Panasonic SC-HT680 System
Televison & Video Logo
63 people viewed this question
Top Televison & Video Experts
Electro Med Services...
