Back to:
Tags:
Sony RDR-VX525 DVD Recorder / VCR Combo
Remote is Stuck in DVD 1 mode
posted by bluecaboose on Jun 23, 2008
The remote is stuck! Any Button that I press shows DVD 1. I have done everything that it says to do in the manual with NO results. I know that I have to get the remote to align with DVD 3. I am stumped on this one.
johnb
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jul 14, 2008
FixYa! (100)
garyw412
Rank:Apprentice Apprentice
Rating: 100%, 1 votes
try to reset the remote,,,,press the enter key and the #3 key down together for about 10 seconds while remote is pointing at dvr....the remote should reset and in setup you should be able to change to dv3
Rating Locked! (?) bluecaboose has rated this solution as FixYa!
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Remote is Stuck in DVD 1 mode:
I don't want to Accept this solution
Solution #2
posted on Oct 05, 2008
Not Rated (0)
pinocho811
Rating: 0%, 0 votes
solution to the problem is as follow:
1. press down the "ENTER" buttom and then press the "1" number buttom for about 5 seconds
2. press down the "ENTER" buttom and the "3" number for aboput 5 seconds.
This should reset the recorder to the DVD3 mode
Good luck.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Solution #3
posted on Aug 03, 2008
Not Rated (0)
trayj57
Does not work have any other solutions ?
thanks Tony
Thank You!
Can you Help with these DVD Players problems?
remote is stuck in dvd 3 mode
Burned DVDs play fine on the VX525 but are not recognized...
I have tried to unplug the vx525 but it will not go back...
Any DVD (movie, music) intermittently start/stops... like...
Hi, I hooked everything up from dvr to dvd and turned the...
Loading problems.
Repair Service
Find DVD Player Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
