Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Capacitor locations Where are they located exactly? Are they inside the electrical chassis that has to be removed, and if so, how do you remove the chassis.??? I have it loose, but will not come all the way out. Do all the wires need to be disconnected to the front of the TV.???
  • Mitsubishi Master
  • 8,617 Answers
Yes all wires need to be removed that run from the metal encased chassis the four boards that have bad caps are all located in that metal encased chassis. The FMT, DM, Singal and Power PCBs
Posted on Jun 24, 2008
I installed a new lamp lamp starts to lite for 4 ot 5 seconds and goes out ,then lamp lite comes on
Most of the time it is bad capacitors in the power supply. These will be obvious from the tops of the capacitors being bulged up. The power supply is located on the front of the chassis cluster and is the only easy to get to board. You will have to remove a shield cover to get access to it. Getting the chassis cluster out is a major job by it's self. After removing the screws from the back, you need to remove the secondary back shield. The chassis cluster is on you left side. You will need to take the mounting screws out. There are 3 on the left on the bottom side and getting to them may require a stubby phillips screw driver. There are 2 at the bottom facing the back of the set and there is one at the top facing the back of the set. next you need to remove the the black data cables from the top of the chassis at the back of the set on the left near the fan. Next you need to loosen the wire harness wire assembly thar goes to the optical block. There is also a power wire cable that goes to the fan that is mounted to the secondary back shield. This needs to be disconnected. The chassis cluster should be able to be removed by pulling lightly making sure that no wire harness gets stressed. There should be 5 or 6 screws securing the power supply shield. Once the shield is remove, it is pretty easy to remove the power supply. It is mounted on it's side and should have 5 or 6 screws holing it in place. I would replace any capacitor that has a bulging top. The values are important and should be matched accordingly. Make sure you replace the capacitors in the correct position noting the dot indicates the negative leg position. Reinstall the board, chassis, and all plug connectors before applying power and turning on.
I hope this helps,
Skyassoc
Dec 09, 2010 | Mitsubishi WD-52525 52" Rear Projection...
The audio on my Samsung HL-S6188W DLP TV is completely out--no sound from TV speakers in any input mode (ATSC built-in tuner, component-in, etc.). Furthermore, the optical-digital audio out does not...
Check your mute on /off status through your remote. If it is changing status & no sound,
It looks like sound circuit problem.Contact service center for assistance.
Apr 21, 2010 | Samsung HL-S6188W 61" HDTV
Set turned off by itself, power light flashes, and then I smelled something electrical. It will not turn on with remote or manually.
HI, thank you for visit fixya.
Two possibles solutions:
1.--Horizontal capacitor is burn or blown.
Need be replace, located beside horizontal transistor ( .0082uf 2kv ).
Clean the aarea on the chassis.
2.-- Transformer fly back is burn, need be replace.
If you will work on this tv or any special technician will work on this tv, request for replace capacitor on power supply. Common problem too.
Any question. let me know ,please.
Thank you.
Dec 04, 2009 | RCA HD56W58 56" HDTV
Same problem, green falshing light
no the boards are located inside the metal chassis block which is located on the left side looking in from the rear. You can get the service manual at the following link which will help you get the chassis out and help you identify the circuit board locations. Its under the mitsubishi category.
http://servicemanuals.vstore.ca/
Sep 08, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Wd52725 cap replacement
The power pwb is on the opposite end of the chassis opposite the Input locations. I believe on tha model the plu assembly gets removed from the case and stays with the chassis block. I believe CN1 and CN2 are the ballast connections you need to remove a metal shield on the ballast Circuit to see the connections.
Jul 14, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi wd52525 capacitors
well capacitors are located on the chassis but only the high voltage capacitor can cause electric shock,dont be afraid,u can discharge the current on it.
Jun 23, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Sony HS30 Convergance Issue
The STK ICs are located on the D board their locations are IC801 and IC 802 they are both STK392-560 and you will only have to remove the D board. Usually only 1 or 2 resistors go bad right next to the ICs heatsink. You can get replacements at the following link and they include installation instruction plus free tech support heres the link.
Apr 07, 2008 | Sony KP-46WT500 46" Rear Projection...
RCA 52 INCH D52W20B WON'T COME ON
Just fixed it!!! Remove the back panel from the television, you will see a board where the input jacks are located. To the left you will notice a red power wire. Just up and to the right approx 7" or so you will see a [_] shaped metal shield surrounding a capacitor in the middle of it. The part # on the board is CP150. It is a green/gold 16v 2200uF capacitor. More than likely this capacitor is faulty. Run your finger over the top of the capacitor, if it is beveled rather than smooth you have a definite solution to your problem. You may need to remove the plastic piece that covers the transformer to the left of the capacitor to gain easy access. Good luck!!
Dec 09, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
The red portion of the image jumps away from the other two colors
1)The correct solution is (a)....
2)Concerning pulling the chassis on a 46" Mits...
due to compact size,your set has a higher degree of difficulty.
The 73", 65" and 55" are easier to do the same repair.
3)Begin by removing lower front cabinet,then remove front access
panel.Next provide yourself with plenty of light to see inside....
Remove chassis bolts (3) in rear',unplug as needed,noting location
and routing.Next,locate snap clips on front of circuit tray-Release.
Gently pull back on chassis until clear to remove center board.
Almost must pull all the way.Remove & rebuild center PCB.
Re-assemble,test.
Oct 22, 2007 | Mitsubishi WT-46807 46" Rear Projection...
Removing chassis for carry to repair shop
its called the light box and it secured by 4-6 screws from front and rear of the chassis frame assy./when you locate these screws that secure the frame it will pull out from the rear,caution don't break the front harness to the control panel assy. pull off the front and you will see how the chassis is supported to the tv frame and also remove the rear panel ,look at the metal frame as a box.
Sep 24, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
62 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
