Question about Kenmore 73503 Stainless Steel Bottom Freezer Refrigerator
Freezer problem (icing behind cover inside of freezer)
Kenmore 73503 Stainless Elite Trio (freezer bottom) 4-5 years old
Over a period of a month, large amounts of ice forms over condenser grill and freezer fan.  Needs defrosting once a month.
Freezer during this period very wet with like **** frost over all items inside.
Seal is good and checked.
Fridge above okay.
Have had it serviced once, but problem still the same.  Not going back to them again.
Have read your links, can you pin point the problem?
Thanks for your time
Paul
  • DJJJJJJJJ Jul 22, 2008
    Same issue -- freezer needs to be defrosted often. Large amounts of frost and ice cake all the contents of the freexer and now the ice make stopped working.
  • 93 Answers
Several things to check. Refrigerator needs to be put in manual defrost mode, then check defrost heater and defrost thermostat.
Posted on Jul 23, 2008
How do I find out the model number of my Kenmore elite Fridge
Since the freezer is icing up there could be many different problems a blockage or a problem with the defrost or timer of the unit if u greeting unit number is should be on inside of the door or back by the condenser best bet from what I see is get a tech to fix it they will find all those numbers that u need
Dec 11, 2013 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I opened freezer on my Kenmore elite model #596 73503203 and everything was melting, ice had started to turn to water. The refrigerator is only 7 years old, is it worth fixing? The freezer does not seem...
It could need refrigerant...I'd try to possibly get a quote on that.
BUT FIRST,
I'd ensure the coils were cleaned of all dust and dirt...either by vacuum or blow it with compressed air.
I'd also check to make sure the light goes out when the door is closed. Sounds crazy but I had a bad switch once that allowed the bulb to stay on constantly...makes everything warm.
Jul 17, 2011 | Kenmore 73503 Stainless Steel Bottom...
Refer not cold, freezer is?
http://www.managemylife.com/mmh/owner_manuals/16224/KENMORE-Bottom-Mount-Refrigerator-L0306154?brand_name_search=73503
go to the troubleshooting operation food temperture appears too warm. if follow step by step no work. please check the evaporator coil. if it cover by frost or ice. i am sure the heat element or defrost thermostat is bad
Jan 10, 2011 | Kenmore 73503 Stainless Steel Bottom...
My refrigerator is set to #1 and I am having problems with items freezing in the refrigerator section, most notably the vegie bins as well as the top shelf. We have a stainless trio that is about five...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 09, 2010 | Kenmore 73503 Stainless Steel Bottom...
Kenmore Elite Trio Fridge Not Cooling
check the over-load/contactor on the side of the compressor,remove it and shake it if it rattles,replace it
Nov 01, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
1 year old Kenmore Elite Trio Refridgerator not cooling
There are a lot of things that could be the source of the problem... is there no cooling at all going on in the freezer? Is the back wall of the freezer cold? It could be anything from a fan, to the compressor, to the control board... you need a technician.
I would get on the phone with Sears, and explain the continuing problems you have been having, and they may agree to cover service.
Jul 26, 2009 | Kenmore 73503 Stainless Steel Bottom...
Kenmore Elite Trio 596.76529500 It makes a
It is the Freezer Fan, he ice maker fan. I experienced the same conditions of a two year period. The tech allows said either unplug overnight. I as you couldn't take the noise. Oh by the way it will be getting worse!!! The solution replace the Freezer Fan motor.it cost about $78.00 plus shipping. they are located behind the freezer rear wall. They are very labor intensive to replace because the electrical leads are attached just out of reach. I have a 33" arm and I had to act like a contortionist to unplug them.
Jul 24, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Looking for the manual for a kenmore elite 73503
Head over to the manufacture's website. www.searspartsdirect.com
You enter your full model number in, and you can see parts and expanded diagrams of your unit.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 31, 2009 | Kenmore 73503 Stainless Steel Bottom...
Kenmore elite 77573600
one of the switches are bad if you have a multimeter check them for resistance
Dec 12, 2008 | Kenmore 73503 Stainless Steel Bottom...
Kenmore 73503 Stainless Steel Bottom Freezer Refrigerator Logo
188 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
