Question about RIM BlackBerry Pearl 8100
Nintendo ds lite cover (top half) loose, ds doesn't work. Have used it 3 times, it fell down. what to do?
    Problem Solver:
  • 3 Answers
I know that nintendo has great support. Try Contacting them about your quiry. I would think its wires are not connected well, and I would just leave it to the pros to handle it
Posted on Jun 23, 2008
Taking cover off nintendo ds lite
Are you talking about the back cover or front cover?
Either way, before starting you are going to need two things: A tri-wing screwdriver and a Philips screwdriver.
To remove the BOTTOM COVER, you must take off the stickers covering the screws and remove the screws. 001e10e1-317e-4bb5-97cd-230a82f77aaf.jpg
Then, carefully pry the back off, revealing the motherboard inside.
To remove the TOP COVER, you must take off the stickers covering the four screws in the corners of the INSIDE top screen. Unscrew them and gently push the inside top screen down until its about half a centimeter apart from it's backside. Then pull the backside off and you have it open.
If you wanted to open the DS completely, like have it in half, you should first open the BOTTOM COVER and remove the motherboard after disconnecting it from everything attached to it. Then follow the steps given for removing the TOP COVER and slide the ribbon and cables sticking through from the TOP to the BOTTOM back to the TOP so that they are not sticking through and won't be damaged when you take the DS apart. Then unscrew the power light and voila! The DS should be separated.
May 31, 2014 | Nintendo DS Lite
Looking at DS Lite for granddaughter and this granny doesn't know squat about these systems
As far as i know ds lites will play ds games (in the back) and gameboy advance games (in the front) the gameboy advance slot usually has a cover on it you pull off.....If its not working all the time buy some compressed air in a can and blow out where the games go....hope this helps.
Mar 27, 2012 | Nintendo DS Lite
DS Lite Console: My nintendo ds lite top screen is black. I can mo...
If you want to buy a Nintendo screwdriver and work patiently, this is an easy fix.
One of your ribbon cables is being pulled out or is not connecting when you open your DS.
If you go to www.powergamingparts.com you can find manuals to assist you in opening the DS and where to locate the "clips" that you will need to tighten.
If you need any further assistance contact me.
May 17, 2010 | Nintendo DS Lite Console
My nintendo doesnt work right
Sounds to me like the ribbon cable that connects your top screen to the motherboard is loose.
Open it up with a screwdriver and reattach the cable. Be sure and remove your battery first!
Nov 18, 2009 | Nintendo DS Lite Console
My DS has fell into the tolit.
DO NOT try to turn it back on or charge it. Instead do the following:
- Shake out as much water as you can and dry it off as best you can.
- Get a tupperware or other sealing container at least three times the size of your DS and fill it about half-full with rice.
- Put the DS in the rice. Might be an idea to wrap it loosely in paper towel to avoid getting rice dust in it.
- Leave it for a few days to dry out. Every 12hr or so, remove the DS and shake the rice around a bit.
Works for cell phones and other gear too.
Nov 05, 2009 | Nintendo DS Lite Console
DS lite only playing one type of game
Reset Factory Settings for Nintendo DS 1. Use a small screwdriver to unscrew the back cover.
2. Remove the battery.
3. Wait a few seconds.
4. Replace battery.
5. Turn on DS.
6a. If you have to re-enter your nick-name/time and date etc, it has worked! Go to 7.
6b. If not, remove the battery again and wait longer.
7. Replace cover and screw back in place.
Jul 31, 2009 | Nintendo DS Lite Console
Nintendo DS Lite Top Screen works at certain angle
my mates ds lite happened the same too. the only thing you can do is...
1. send it back to nintendo if its insuared
2. buy a new one
3. try and fix it yourself (mate used sellotape)
Jul 07, 2009 | Nintendo DS Lite Console
I`ve had my ds for about 3 yrs now, and my mic
you can fix it just replace it but it means nearly completely stripping down your ds as the mic is fitted in the top part and plugs into the motherboard in the bottom part.
Jun 26, 2009 | Nintendo DS Lite Console
Nintendo DS Lite top screen broke on one side
The only way you can repair this properly is to replace the casing with a new one... the hinge is a common problem and over 90% of my customers on the DS and DS Lite need a new case due to broken hinges. Once the plastic bit has broken then it will only get worse. The small bit that you say fell out was the actual hinge itself (a small black part with a silver end that twists and locks your console into place when open). Hope that helps!
Aug 21, 2007 | Nintendo DS Console
NINTENDO DS FELL 2 FEET AND WHEN I CHECKED IT THE TOP SCREEN WAS CRACKED IN THE BACK AND CANT SEE HALF THE SCREEN CAUSE OF THE CRACKS SO I NEED TO NOW IF YOU GUYS CAN FIX THE SCREEN OR KNOW A PLACE THAT...
DONT ATTEMPT TO REPLACE THE TOP SCREEN ON THE DS LITE. It is easy to replace it on the original ds, But the ds lite requires you to re-soilder the 4 speaker cables into the top screen's video ribbon cable.
Aug 03, 2007 | Nintendo DS Lite Console
RIM BlackBerry  Pearl  8100 Logo
29 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
David
Martin Murray
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
