Question about Alesis 16 Bit Stereo Drum Machine System
No power-up on Sr-16!!!
Hey, i've had an old sr16 for about 10 years. About 6 months ago, upon trying to power it up, I got nothing! I have no idea why this would be occurring, but I should mention that I'm not much of a tech guy. Any ideas?
  • Anonymous Jul 08, 2008
    Did you get a solution for this? Mine on for 0.5 a second and shuts
    off, but if you tilt it you can see that the LCD screen is very dimly
    lit. VR1 gets a bit hot, but I'm thinking that's normal for a
    non-sunken VR. Help?
  • Muzikmama Sep 14, 2008
    Volume don't work. How can I fix this...
Hi,in the manual it explains somewhere how to reset the unit. I think you hold down the play button and the erase button at the same time while powering up the unit.
Posted on Mar 05, 2010
The battery is available from your local lowes walmart and is easy to change. However! Did you back up your machine to tape? You'll loose anything you programmed in with a battery change and possibly pre canned patterns.
Posted on Oct 02, 2008
Hi they have a battery replace the battery
can anyone tell me where to get mine repaired regards Ray
Posted on Aug 03, 2008
My kitchen aid kebc208kss0 is getting the PF error in cool down mode.
\I am not sure y it is giving the PF code because that code is saying there has been a power failure. U could be right in the direction you are thinking.
Apr 26, 2014 | KitchenAid Ovens
I have an LG model 37lc2d the screen is black but has illumination and no sound at all and the green power light flashes 16 times upon powering up?
Things to check: Make sure your TV is set to the correct input.
I DK about the light flashing 16 times but that could be a stuck key on your remote control. If you can, urn off your remote and try turning on by hand and going through the "INPUT" choices to make sure you have it on the correct setting. BTW, if your TV is 5 years old, you'll make the money back in no tie if you get a new "Energy Star" TV. The new Energy Star TVs run on very little electricity compared to 5 years ago.
Jul 03, 2012 | LG 37LC2D Television
My Alesis Sr 16 was working fine a month ago, I pulled it out again, and it just wont turn on. The adapter works fine (I tried powering a guitar pedal with it). Is there a battery or some easy fix I could...
While your test running a guitar pedal is a partial test, the SR16 takes more current than a guitar pedal so the test may NOT be conclusive. When troubleshooting, always check all possibiliities as one can be led on a merry chase and spend a lot of money.
First thing is to check the input power connection. Many of these don't get fully seated and fail to connect.
The most common thing is to use the wrong adapter. ALWAYS make sure the brand on the adapter MATCHES the device manufacturer OR verify the POLARITY voltage and current rating against that marked on the device. Unfortunately most of the power connectors seem to fit even though they are wrong ones and some have larger hole in the fitting than the pin and fail to contact.
There is likely a battery backup within that PROBABLY requires soldering to change. It should be good for at least 5 years. Usually it will NOT prevent the power from turning on.
Aug 30, 2010 | Alesis Sr 16 Stereo Drum Machine
The sr-16 powers up briefly then shuts off, I'm using a new AC adaptor ,music store repairman say it's unrepairable ,it's only 2 years old,what gives?
There has to be a component inside that is faulty. That causes the power supply to quit. If the repairman said it is not able to be repaired it means that the part can't be replaced due to unavailability or the cost. You could try taking it to another repairman at a music store that sells Alesis products if you aren't satisfied with his his answer. SR-16 s are pretty reliable and it takes a lot to damage them to the point where they can't be repaired. If you can't get it repaired locally and you think it can be repaired contact Alesis at http://www.alesis.com/content1024 to find out the closest place to ship it to and get it repaired.
Jul 09, 2009 | Alesis Sr 16 Stereo Drum Machine
Bought 6 months ago and will not boot up, with battrey out it will attempt to start for a couple of secs and then nothing
After 8 days of no life at all in the laptop , having 2 computer technicians around saying it was probably the motherboard and just about to send to Sony I pressed the power button and hey presto it worked again..Guess it was just sleeping or hibernating...after all it is spring now....Actually one guy of the many forums I have visited advised just to leave the Laptop alone and perhaps it would mend itself..and hey presto he was right, although having said that I have yet to turn the laptop off and startup again..HMMMMMMM...
Apr 14, 2009 | Sony VAIO VGN-FS630/W Notebook
Motorola Motorokr Z6M will not turn on
Hello everyone, I also have the same phone, and the same is happening to me, I've changed the phone 4 times in less than 3 months (Metro PCS carrier). My 16-year-old brother had almost the same problem with his RAZR 2 years ago, but he knew ho to fix it, so I gave him my phone everytime it freezed up. It seems the only way to fix this is:
take out memory card (if applicable)
take out the battery and put it on constantly.
If it doesn't work leave it charging for at least 1 hr. Then do all over again
you have to be real patient, it will take a while till it actually comes on.
UPDATE: I just fix my 4 and last phone, as of yesterday, while my cell was broken I switched to Sprint, and got me the new Samgsung Instinct S30
Motorola R.I.P
Dec 29, 2008 | Motorola Mobility ROKR E6 Smartphone
Where can i buy the proper volume pot for my alesis sr 16?
If you are willing to pay actual cost for shipping, I have an SR-16 with a broken screen that i could send you to salvage parts from. I bought it, I believe in December of 07 & other than the squished screen, I believe it to be in great shape. I just bought another one instead of fixing this one, so I certainly don't need it. Email me if you are interested. My guess is that USPS shipping would be like 2 or 3 bucks,as long as you are in the states.
Dec 03, 2008 | Alesis Sr 16 Stereo Drum Machine
Power problem
If you bought it brand new and is only 6 months old, I would suggest to contact the manufacturers to get repaired under warranty since most electronics devices carry one year warranty.
Good Luck.
Oct 03, 2008 | Behringer EUROPOWER EP2500 Amplifier
Alesis 16 Bit Stereo Drum Machine System Logo
320 people viewed this question
Top Alesis Audio Players & Recorders Experts
 Grubhead
Grubhead
shaqsatin
Level 1 Expert
Ben Armstrong
Are you an Alesis Audio Player and Recorder Expert? Answer questions, earn points and help others
