Question about Motorola Cell Phones
Unable to call phone, regularly goes to inoperative mode. Can only be remedied by removing battery for 30 secs and then logging on again and calls can be made. Arnold Russell
I went to Motorola webb site and downloaded a software update
Thank you for your interest
Posted on Jun 26, 2008
Please help me. my camera is showing error occurred please turn unit off then turn on again
If your camera is a Canon camera 'Google' 'Canon camera error codes' and select the one you are seeing to check if there is a remedy for the problem. You can also try this action - Switch on your camera while the camera is still switched on remove the battery - leave it out for about 2 mins, put the battery back in (still with the camera in the on mode) close the battery door- switch the camera off leave for about 30 secs then switch it on again. Hopefully that may clear things. Still go on line and check the Canon error codes.
Sep 02, 2015 | Cameras
Whays the problem
Hi Al
Most computers these days do not use a regular switch to supply power from the battery. The computer is basically in a standby mode and the switch discharges an electrolytic capacitor in the power supply to change the logic 1 to 0 to activate the machine.
These Electro Cap's get damaged over time (they leak or short) and don't store the required charge.
So... if your technically inclined then you could open the machine and look for swollen or leaky Electrolytic Capacitors in the power supply section then unsolder & replace with similar values.
Jan 26, 2015 | HP Pavilion dv6000z Notebook
Err99 when taking pics in sun. Taking in side with flash fine, pics outside at night are fine?
Error code 99 indicates detection of a system malfunction. Try switching on the camera and while it is still switched on remove the battery. Leave it for about 30 secs then re-insert the battery once powered up switch the camera off wait 30 secs then switch it on again. This action sometimes will remedy this problem but failing that it may need a visit to the repair shop.
Sep 20, 2014 | Canon EOS-20D Digital Camera
Star up retailer
remove the battery for 30 sec to 1 min then reinstall the battery and try it again if it doesn't work then contact your carrier's call center and ask the IT rep for further instructions i sometimes have this problem with my ZTE Android Smartphone
May 10, 2012 | Nokia N70 Cellular Phone
My htc g2 says unable to scan for network
Try turning of the phone and removing the battery, then taking out the micro sd card and removing the sim card as well. Wait about 30 secs and then put everything back together and try it again.
Mar 06, 2011 | HTC Cell Phones
I am unable to sent sms, however i am receiving messages sent to me.
first do a soft reset on your phone ( pull the battery for 30 secs)........otherwise call your carrier and make sure you have the correct message center number
Mar 08, 2010 | Nokia Classic 2330 Cell Phone
When I try to call from the address book or speed dial it brings up my call log and won't call the number i am trying to call. I have a blackberry pearl 8110
I solved the problem by doing a Hard reset, this means taking the battery out while the phone is still on, leaving it out for 30 seconds, replace the battery, the phone will then turn on, it resets itself and it worked just fine. But I would suggest removing your memory card or saving the pics on it because I think it deleted some pictures on it. But I still don't know what caused it to have this problem in the 1st place, it was like it froze up in the call log mode. Removing the battery did fix it.
Jan 17, 2010 | RIM BlackBerry Pearl 8100
I have a locked radio for a 2000 pontiac grand prix thanks to a battery exchange...can anyone help ...the 6 dig code is 292298
Hello! You have done half of the work already! You can take the code, and the VIN to your vehicle; and call your local GM dealership. Tell them that you need the unlock code for the radio, and they will ask you for that information.
Also - there are 2 modes to the TheftLock - "LOC" or "SEC" and "INOP". Once the anti-theft is activated, the radio display will show "LOC" or "SEC" - you then have 8 attempts to enter your code. If after 8 attempts you don't enter the correct code, the display will change to "INOP". It is only at this time that you will need to wait one hour, with the ignition ON; before you can retry. After that - you will have only 3 attempts before the radio enters "INOP" mode again.
Hope this helps and good luck!
Sep 25, 2009 | 2000 Pontiac Grand Prix
Razor v3i dolche&gabbana
Try tehse steps
1. Switch off and switch it back on , leave it switched on for 2-3 hrs and then check
2. Switch off and take out battery , when battery is out , press power on button for 30 secs and then out battery back again and switch on the mobile. This process is known as releasing flee power.
3. If still does not work, Then try to do a reset for the phone .
4. If still does not work , try to send a text message or a SMS and check whether it works or not.
5. If still does not work , then contact the people whom u pay for the phone bills and check with them whether there is any proble from their end or not.
6. If still problem no resolved, check whether accidently you have barred all outgoings from ur phone and do check the network selceted mode should be automatic , by mistake no other network should be selected
7. Check whether phone is range of signals and signal strength is excellent.
8. If still does not work then contact , the phone manufacturer, phone antenna might not be working and is unable to receive any signals....
Feb 21, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Cell Phones Logo
97 people viewed this question
Top Motorola Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Motorola Cell Phone Expert? Answer questions, earn points and help others
