Question about Relisys RLT1720 17" LCD Monitor
HP W22 monitor
Screen goes blank after one second I've changed the capacitors today but, still have the same problem. The new capacitors are the exact brand and size of the old ones. Is there any other repair for this problem that I can do before sending monitor off to HP.
    President:
  • 1,257 Answers
Sounds like you've got the refresh rate set too high. Do you get something onscreen reliably in safe mode?
or
That sounds like an issue with power convertor in the monitor. That is what changes the 110v current from the wall outlet to the voltage the monitor needs for its different components.
The reason it keeps going out is that it is getting too much power and flipping the "circut breaker" (best analogue I can think of) in the monitor.
Posted on Jun 23, 2008
  • 426 Answers
Check the temp sensors, and power supply, if you have opened it you might not be able to get it under warranty let me know if u need more info
does the whole screen turn off or just the picture? you might have a bad illuminative tube
    Master:
  • 638 Answers
This is the way how to examine what's wrong with your LCD monitors. After you turned it on and the screen went blank, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
feel free 4 further assistance .rate the particular experts solution as fixya that helps u understand n solve ur problem
Question about Computer Monitors A friend of mine was getting ready to throw away a monitor that he thought was junk, so I took it off his hands. It's a HP 24 inch LCD color monitor the model number is HP...
Your capacitors are damaged. You will need to check the capacitors (the most common fault) or alternately check for internal power supply.
The capacitors can be seen in the internal power module, once you open the case you will those little cylinders. Check for leaks and replace as necessary. Cost will range from 6 to 16 usd.
Feb 15, 2015 | HP Computers & Internet
Losing TV picture, screen goes blank,
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 21, 2014 | Televison & Video
When i turned on my monitor it stays on for a couple of seconds and goes blank (dark screen). But also has error message stating no DVI input?
here the solution to ur question.. made simple its from HP..
http://tinyurl.com/3xt5wwb
let me know if this was helpful regards, guru
Apr 24, 2010 | HP 2009M Monitor
Samsung 913v Self Test fine but screen goes blank in seconds
Its your VGA cable that runs from the monitor to the computer and u may also have a bad power chord
Jan 25, 2010 | Samsung SyncMaster 913V 19" LCD Monitor
Laptop display goes blank after a second, not lcd inverter
I have had a similar issue with an LCD monitor and the issue was not with the inverter itself but the backlights. They can go bad and short (which is where my issue was. Once they were removed the screen was working again (the lights needed replaced).
Hope this helps!
Nov 08, 2009 | HP Pavilion tx2500z Notebook
I'm getting a message on my HP w22 (about 2 years old) that there is no input signal. i have checked the vga cable and even tried a new one. the screen comes on when it's first turned on, and when i...
You might wanna check your HP w22 system
Try replacing your ram with a new one or any working one
if your ram is in good condition then check your motherboard if you dont know how to trouble shoot a mother the best way to go about is to use a new one or any working one compatible to your system
Jun 23, 2009 | Computers & Internet
Screen flashes "on" and then goes black on start up...
This is usually a bad capacitor problem. They would need to be replaced, or get a new monitor. Some shops will work on them, but you have to weigh the cost vs buying a new monitor for almost the same price.
There are some websites on repairing your own, but you need to know a bit about soldering and such.
Mar 28, 2009 | ViewSonic VA912 19" Flat Panel LCD Monitor
Screen image appears fuzzy, jumpy and broken up into lines.
gardenman13, I would certainly complain to HP about their w22 monitor!! Find out if the units warranty is still valid and can be swapped-out for a REFURBISHED unit. Your w22 shouldn't be hazy, distorted, or flicker for any reason. My best guess is that it (w22) has problems inside with it's "cold-cathode-fluorescent-lamps" and electronic ballast circuit called an INVERTER circuit, which could also cause the main "switch-mode-power-supply" to go a little NUTS upon STARTUP!! FYI you are dealing with a technology similar to the curlie-Q CFL screw-in light bulbs. Their ballast's are called CONVERTERs (ac to ac) and are cheaper. Your lanps are thinner and straight, hung on rear of your LCD panel. I hope this was informative. Please rate this on fixya. 12fixlouie
Dec 11, 2008 | HP W22 LCD Monitor
Relisys RLT1720 17" LCD Monitor Logo
90 people viewed this question
Top Relisys Computers & Internet Experts
Samuel Konger
Samuel Konger
giarcnameloc
Level 1 Expert
Are you a Relisys Computer and Internet Expert? Answer questions, earn points and help others
