Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Icemaker is not working
My fridge does not make ice
  • 481 Answers
The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser (if equipped). The valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees. In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering. The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
Posted on Jul 06, 2008
Ice Maker is not working?
Make sure the arm is DOWN. If up, it is signalling the icemaker that the bin is full - and NOT to make any more ice.
If you have water service at the fridge - has it failed too? If it doesn't work - look at the water supply line to the fridge. It may be valved off (under sink), crushed, clogged, etc. Once that is working allow time for the icemaker to make ice.
If still no ice - it may be the solenoid or wiring from the icemaker that allows the tray to be filled. In this case, you'll need tools, testers and how to read schematics. If these are not available - you should call an appliance repair shop. Otherwise, you may end up replacing perfectly good parts and still not be able to get it working.
Apr 14, 2015 | Refrigerators
Tip
How to install/replace Icemaker in top bottom fridge
Start by unplugging fridge. Take 1/4 inch nut drive ( sometimes phillips ) remove bottom screw from under ice maker. Next loosen top to screws mostly out. The screws are located in brackets near the ice tray behind the front cover. Ice maker has brakets that the top screws slide into. Lift the icemaker up and out off the screws. Next disconnect the quick connect that is on the back wall of the freezer. Some models are hard wired into the icebox. If this is like yours than disconnect the quick connect from the icemaker itself. Take icemaker out of freezer and connect quick connect into or from new ice maker. Slide the new icemaker onto screws and into place. Screw bottom screw in and than tighten the top two screws. Place ice maker arm down so it can make ice. Give it 24 hours to cycle before it starts producing ice. Most of the time icemaker starts making ice within a couple hours. Plug in fridge.
on Aug 01, 2011 | Refrigerators
Jfd2589kes
Locate and check the valve that feeds water to the icemaker.
Jul 04, 2017 | Refrigerators
My icemaker is not dumping the ice when it's frozen.
Replacing the icemaker is neither expensive nor hard. Order a replacement on the Internet.
Sounds like a malfunction in the icemaker itself.
May 27, 2017 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool IceMagic Plus not working.
Pour about 2/3 cup of water into the ice maker . If it dumps the ice but doesn't refill , replace the ice maker . If it doesn't dump , and the cubes stay in the ice maker , replace the ice maker .
The switch on the icemaker for normal , runs the icemaker normaly . In the ice plus , a small fan comes on , blowing the inside air , over the ice maker mold , to help it freeze faster .
Sep 14, 2009 | Refrigerators
I have a PSS26 ge profile fridge and it quit making ice
The icemaker is bad . You have an electronic icemaker and the internal boards cannot take the freezing and the heat (freezing moisture) . Just replace the icemaker .
Jul 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
ICE MAKER QUIT MAKING ICE ON MY WHIRLPOOL FRIDGE
I had a Whirlpool Model GD5SHAXNS in which the icemaker quit working about the same time (3 years old). I had water out the dispenser, I found that it was the icemaker itself failed not calling for water to fill it. I replaced it with a icemaker on-line for about $100 and problem fixed. I have been told his is a common problem with the icemaker in this model ref.
Mar 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
No ice production
Chances are the fill valve at the bottom back of the refrigerator is clogged or failed. This valve opens to allow water to fill into the icemaker.
It could also be that the fill switch in the icemaker has failed, or depending on type of icemaker, the ice level bar is flipped up, or the mold heater sensor has failed.
Please provide the refrigerator P/N for more information.
Jan 15, 2009 | KitchenAid Refrigerators
Icemaker Not working
No it should take about 24 hrs to get a full bin of ice. The most common problems with this style icemaker is the fill tube freezes which they have a replacement heated fill tube or the board on your freezer wall that pass a light through your ice bin to tell if its full or not stops working
Dec 05, 2007 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
