Question about Kenmore 22422 Top Load Washer
Kenmore Elite Washer with Calypso Model # 110-22062100
A week ago, two pieces of clothing were stuck in the bottom of the tub, between the rubber gasket and the wall. Had to call a repair technician, who yanked it out and told me that my machine had too long of a "fluff" cycle (30 seconds) instead of the newer model fluff cycle of 8 seconds, and so this will continue to happen unless I replace the control board at a cost of $350.
Now, i did 4 loads of wash, as usual, and in the fourth load, I heard two beeps, and saw a message flash of "FL". The machine would not respond to a cancel, nor to my disconnecting it, nor to my resetting the circuit breaker.
Another call to the service people and they told me that based upon my first service call, I should order the new control board, and that may be the problem. If it is not, I am stuck with the cost for that plus whatever else to repair the machine. There is about 2 inches of water standing in the bottom of the tub. What should I do next? Help! Thank you. Pat L.
  • 413 Answers
The 'FL' is a flood code indicating there is too much water in the machine.
What has probably happened, is a small article of clothing has gone under the washplate and is now stuck somewhere it the drain system, most likely in the pump.
The control board change that was made may help a little, but not necessarily a cure all. If you are considering a new control, replace the washplate as well.
I don't know how long you have had this machine but I do know you paid alot for it. I purchased one of these machines about 6 years ago and about 2 years later began having problems you described. I found it best to cut my loses and get a new plain agitator type top loader. Best thing I ever did.
The Calypso was a great concept and does a great job when it works right. But this machine has been plagued with numerous issues from the beginning, causing may owners many sleepless nights not to mention laundry pile-ups..
Regards;
reg501
The FixYa Team
Posted on Jun 23, 2008
Kenmore elite top load washer will not drain and buzzes until unplugged
Hello there:
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
Nov 18, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Found broken part in my kenmore calypso washer
sorry any problem is a common problem on calypsos, its a techs nightmare. sounds like your better with new machine.
Mar 14, 2009 | Kenmore Elite 45986 Front Load Washer
Stops in the middle of rinsing...leaves some water at bottom-
Calypso...The pumps fail often. They have redisigned one that theres not as many problems with, but if you still have the original, this is deffinatly the problem. As far as clothes getting stuck, the U-Joints wear out and cause too much play allowing things to get stuck. Total for this repair parts + labor will usually run about 500-600. There was a class action lawsuit for this machine and they no longer make it.
Mar 08, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite calypso 21086 leaves dirt streaks on clothes
Run the hottest & fullest cycle possible - without a load - and add a grease remover - like goo-gone. Fatty tissues build up inside the tub - and can be released on hot cycles if HOT wasn't used very often.
It is recommended to run a HOT load every 2 weeks or so to avoid these buildups and staining of clothes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 20, 2009 | Kenmore Elite 21086
Calypso kenmore elite water level low sometimes
something is clogging recirculating pump inspected both pump that should fix
Nov 30, 2008 | Kenmore Elite 45986 Front Load Washer
Ld and ob error codes
hello.........
“LD” stands for “long drain,” meaning it took an excessively long time for water to drain out of the washer. Common causes for this are kinked drain hose or clothing, like panties or socks, caught in the pump suction hose. Why, I’ve even heard of bra wires coming loose and getting stuck in that hose, collecting all sorts of gookus and pinching off the flow of water to the pump. Can you imagine? Yea verily, as surely as the Sacred Suds doth eternally pass my lips, the “LD” error code springs forth from such anomalies.
Sep 07, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Elite Calypso washer won't fill with water!
i assume that the warer is turn on at the warer valves if so then do you have voltage at the water valve if not then water pressure switch could be bad or main control board could be bad
Apr 24, 2008 | Kenmore Elite HE4 Electric Dryer
Whirlpool calypso
Have you checked the agitator? There may be sharp edges on the agitator blades. OR the towels may be getting stuck under the agitator and tub bottom. The agitator is supposed to suck the clothing down in the center and forcibly throw the clothing outwards against the tub. The cycle then repeats.
Sep 09, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore 22422 Top Load Washer Logo
283 people viewed this question
Sal De
fordexpert
Robert Rankin
