Adding a 400gb h/d to a SL-75LIV main board
To ever can ans this
i need to add a biger h/d to my system.
my main board is a SL-75LIV.
can this main board support a 400gb h/d
tnx
greg
  • vk2kgh Jun 23, 2008
    yes thanks for that......i was wondering if the bios supports the bigger drives (i suppose i should of asked that in the begining)
    greg
  • vk2kgh Jun 26, 2008
    SORRY........ boringlarry i ment no offence to you, perhaps 'thanks for trying' would of been better. can 'inappropriate' be removed from the comments for this????
    I'm new to this type of question thing. i posted an addition to this forum which i believed better described my question.
    hope I've not blown my chances of getting an answer????
    Don't know what else info is needed, please ask
    greg
  • 99 Answers
I would think it would support it....you have to make sure that the jumper on the back of the hard drive is set to master, if it is the main hard drive, or slave, if it is a secondary one...also, make sure you have the right cable to connect it with...if it is a SATA drive, you'll need an adapter to fit an IDE ribbon cable...if that is what your motherboard uses.
Posted on Jun 23, 2008
  • Larry Miller Jun 26, 2008
    I fail to see why this has been rated inappropriate
How to Add a Board on the MA5600?
You can add a board on Huawei MA5600 in the following two ways:
· Adding a board offline: Run the board add command to add a board to an vacant slot (in this case, the system generates the "Board Fault" alarm). Then, insert a board to the slot (in this case, if the type of the inserted board is the same as the type of the board added offline, the system generates the "Board Recovery" alarm; if the type of the inserted board is different from the type of the board added offline, the system generates the "Type Mismatch" alarm).
· Automatically discovering a board: Insert a board to an vacant slot (in this case, the system displays a message indicating that a board is automatically discovered, and the board is in the auto-find state). Then, run the board confirmcommand to confirm the board that is automatically discovered.
This way is also can be adopted by Huawei MA5616 equipment.
Apr 27, 2017 | The Computers & Internet
I need to find the hard drive power connector forHP Xb3000 Notebook Expansion Base And 400gb Kit 400 GB Hard Drive, where can I find it.
HP XB3000 Docking Station HDD Hard Drive Tray
I just received an XB3000 expansion base and I've found an opening for an expansion hard drive, but it needs a special tray. Ebay has a seller who is pricing them at $119. Less the drive itself. I payed a total of $36 for my docking station and I'm not sure what magic the extra drive would bring about. So if I find out that adding a hard drive inside my fancy docking station works magic I'll purchase the tray, but if it doesn't do anything special I'll skip the waste of money.
Jun 22, 2012 | HP Xb3000 Notebook Expansion Base And...
Hi,I've an external case (diamondmax 11 Model:6H500F0)--500GB SATA 3.0GB HDD. And I wanna to activate it,but I Dont have the Installation CD,plz I need your help URGENTLY. (I've an widows XP for my...
Maxtor DiamondMax 11 is a SATA Hardisk and you need SATA External Case. After adding the Harddisk, all you have to do is connect it to the system via the cable of the external case. There is no need for additional drivers/ CD as all the external harddisks are 'plug and play'and the Operating System detects them automatically.
Hope it helps! Good Luck!
CreativeTECH
Apr 09, 2011 | Maxtor DiamondMax 11 400GB 7200rpm 133MBps...
Runnin thru antifreeze. is there a certain kind of antifreezze to use on yhe saturn sl
The 2000 Saturn SL came from the factory with Dex-Cool antifreeze (The Pink stuff) I don't know what your engine has in it now...it may have been changed.
If your car is "runnin thru antifreeze", the thing you should be concerned the most with is WHERE is the antifreeze going? If your engine and cooling system is working properly, you should not have to add any antifreeze at all. Adding antifreeze and not finding out and repairing the reason it was low, is a good way to totally destroy an engine.
Mar 06, 2011 | 2000 Saturn SL
Due to power variation my display suddenly goes blank, then i powered off my system. again restarting there is no display on monitor only monitor light blinks.cpu is working properly ,hard disk, ram ,heat...
if it is an on board video sound like it got damaged by power failure,try adding on a video board and disable on board video in bios,make sure you have an avalible slot to add board
Feb 02, 2011 | Intel Motherboard
Keeps tellin me install rtl 100 bpl howe do i do this
There are several reasons why that file might corrupt, an
add-on of some kind being the main suspect. Go to start/run, and type:
iexplore -extoff
to see it that stops the error.
If not, try refreshing all system files with :
sfc /scannow
Feb 17, 2010 | Packard Bell iMedia SL 9553 (P660401806)...
My ac blow out hot air and i want to put freon in my self and want to know how
Adding freon will not correct the problem. If you need to add freon, you have a leak, and you have moisture in the system, the leak should be located, mositure removed, then freon added. But to answer your question. Open the hood on, the left side you will see a round object called a dryer, you will see two pipes coming from it, one at the top and one at the bottom. The smaller is the high side, the larger is the low side. Obtain a can of freon either R-22 or 134a with an adapter for installing the freon. Turn the engine on, turn the AC to high. Add the freon to the ac using the low side.
Jun 30, 2009 | 1999 Saturn SL
Hard drive
jamesroland1,
You have a computer with a 40GB hard drive and you want to add another hard drive (150GB), is that correct? Not knowing the rest of your system age, setup and configuration makes it hard to know what you may encounter. If you can add more memory (RAM) it is always helpful to make applications work faster and multiple ones as well. You may want to add an external hard drive if you don't have the room or don't feel comfortable with opening the computer and installing an internal hard drive. If you want to replace the lower capacity drive, you need to reinstall the operating system on the drive and start from scratch.
randy320sgi
Jan 18, 2009 | Western Digital (WD1500ADFD) 150 GB Hard...
LG LM190E05 (SL)(01)
Gateway has multiple part numbers for the LCD inverter board. Part numbers V01216400103, V01216400104, and V01216400105 are for the Profile 5 and 5.5 series with a 15" monitor. Part number V01316500104 and maybe others are installed in Profile 5 and 5.5 with 17" and 19" monitors. Also the LG part number for the 19" monitor provided in Gateway literature is LM190E02-A4. There is no mention of the LM190E05 SL in the product specs I have seen. Gateway does make special purpose runs and does change components without much much notice though. The definitive source of exact information is Gateway Tech Support. It may cost you a couple of bucks to get answers, but the value added to your system with a 19" vs. 15" screen to say nothing of the viewing comfort should far outweigh the cost of accurate information. Good luck with your upgrade. Please keep me posted on whatever you try be it successful or not. I too have a Profile 5.5 with 15" and have been considering the larger screen upgrade. BillyB.
Oct 07, 2006 | Acer AL1916S (Silver, Black) (Black,...
Computers & Internet Logo
129 people viewed this question
David Payne
David Payne
