Cant receive faxes
We can send faxes and we can also print out on the machie but it will not recieve faxes. We have reset the machine and the fax button is highlighted but it will still not recieve.
  • TimothyLewis Jun 23, 2008
    On the scrren it states telephone and not fax. The fax rang then stated receieving then stopped. Will replacing the NCU board still help
Yes, this will fix your problem
theprinterman
Posted on Jun 30, 2008
    Problem Solver:
  • 5 Answers
YOU MAY NEED A NCU BOARD RPLCMNT
Posted on Jun 23, 2008
Cant send fax out. getting a message exceeded job memory. How do I clear this
Dear
As the model is not mentioned its difficult to right solution. But in general when a document sent from memory some times this happen. This is frequent if memory recieved is more and not printed.
Its cleared on printing all memory recieved or memory cleared(all received fax will deleted).
Also sending fax manually may be done.I.e.Dial the fax no.get the fax tone load the document press start or send. Also in setting the scanning resolution may be minimised up to150/200dpi for less memory.
Thanks.
Feb 04, 2015 | Office Equipment & Supplies
Cant send or recieve fax
Might be silly question but is it setup to auto transmit and receive? And have you tried to operate it manually? + take out the inline filter fax machines operate on volume'db' to soft and it can't hear, to loud and it can distort sound.
Dec 28, 2013 | HP Office Equipment & Supplies
I would like to have the device print a Fax Confirmation for all fax sent and received. HP Officejet J4680 All-In-One
Follow the steps below to enable the Fax confirmation on Sent and recieved.
On the printer :
  1. Press Setup (c01461502.gif ).
  2. Press the right arrow button (c01185072.jpg ) to select Print Report , and then press OK .
  3. Press the right arrow button (c01185072.jpg ) to select one of the following options:
    • On Fax Send: Print a confirmation page every time you send a fax.
    • On Fax Receive: Print a confirmation page every time you receive a fax.
    • Send & Receive: Print a confirmation page every time you send or receive a fax.
  4. Press OK .
Thank you for contacting FixYa
*Please rate this solution with Thumbs Up
Nov 24, 2010 | HP J4680 Office Jet All-In-One Printer
I cant receive fax
Is there a dial tone if you pick up the reciever ? Can you send faxes or use the machine to make a phone call ? If you can make calls or send faxes the machine probably needs to be set to the auto recieve mode so that it automatically answers when a fax is being recieved. If no dial tone you may have a loose connection to your phone jack.
Oct 15, 2010 | Kodak 6150 AllInOne InkJet Printer
My fax machine is in auto print off mode how do i switch it to auto recieve mode
Hi; Receiving to Memory Temporarily You can enable memory receiving feature temporarily. Received faxes will not be printed automatically.
  1. Press [ON/OFF] to select <AUTO PRINT OFF>.
  2. ??? The fax starts receiving documents in memory.
  3. ??? To cancel, press [ON/OFF] again.
  4. ??? When <AUTO PRINT OFF> is cancelled, received faxes will be printed automatically.
good luck
Oct 15, 2010 | Canon FAX-JX200
Fax can not recieve. It sends okay. Hp fax 1010
Most likely the machine has been set to "manual receive" from either "fax/tel" or "automatic" receive. check your manual to check/ change the setting.
May 26, 2009 | HP 1010 Plain Paper Inkjet Fax
Cant recieve fax
please help me how to switch my machine Brother MFC440cn to fax/tel mode.
Oct 26, 2008 | Brother MFC 420CN All-In-One InkJet...
Hp-laser jet 3055
hi, just try to reset the memory the of fax. i think that's the cause that's you cant send and recieved fax..i hope it would help you...
Oct 20, 2008 | HP LaserJet 3055 All-In-One Printer
Cant receive faxes
First make sure your line cable is plugged into the correct place. Most Brother machines have a plug for Line and a plug for Extension (EXT), make sure it's plugged into "Line".
Go into the menu on your Brother machine and select Fax, then Setup Receive and then select Easy Receive. This will usually solve most recieve problems.
Brother machines come with s default of 4 rings before they will answer, make sure none of your other devices (such as an answering machine) are set to a lower number of rings or the fax machine will never grab the line.
If you have distinctive ring, make sure you have it set up in the machine. There is a section in the owners manual for setting up discinctive ring.
If the machine grabs the line and goes through the motions but nothing comes out on the page (no black print) then make sure you are using a Brother ink cartridge (not refilled or generic) and print out the test page using the "ink" button. Allow the machine to clean a few times and see if the test page prints out correctly. If you are using refills or a generic black, you might have premanently damaged the print head. In this case take it to a service centre to have the head tested.
Sep 10, 2008 | Brother IntelliFAX 4100 Laser Fax
Will not receive or send faxes
WHEN FAXING BOTH MACHINES NEED TO RECOGNISE EACH OTHERS NUMBERS (NO NUMBERS CAN BE BLOCKED) AND YOU HAVE TO PROGRAM YOUR NUMBER INTO YOUR FAX MACHIE BY RUNNING THE INITIAL SETUP
May 11, 2008 | Brother MFC 240C All-In-One InkJet Printer
102 people viewed this question
jasbo
jasbo
