Question about Sony FD Trinitron KD-34XBR960 34" TV
Electromagnetic device or leaser device turn off a tv
Is there such device will kill a tv from 10 to 18 feet away
i suspect a neighbour does that to me
just he wants bug me
and is it legal
the tv just goes back no sound no picture
then i turned on again
and how iprotect my tv
thanks for input
  • 76 Answers
Y do you think it is you neighbour is there any reason
Posted on Jun 23, 2008
My rca tablet usually works with my internet. Now today different story. My internet is fully operating with all my other devices but won't hold signal with my tablet why?
OK, this is a common issue with Android, even with the Nexus line.
Try to connect again, if it does, check for how long it holds. Usually you can see if it drops by just rolling down from the top.
If there is still issues with it, tap the Airplane mode and leave it on for some 10 seconds, tap it again to turn it off, test the wifi connection again.
Also, you can forget the network, reboot the device and search for wifi. (This means that you have to type the network's password again, as if it was for the first time).
If nothing works, then you will have to factory reset your device. But unfortunately this is a common issue in Android.
Jun 06, 2016 | Tablets & eReaders
Tv has a pink/magenta shimmering when the tv screen has a light coloured backgroung
Shimmering can be caused by a number of things.
The first that springs to mind is electromagnetic interference. Speakers, amplifiers, florescent lights in close proximity can cause this. I even saw a TV that had been fixed to a wall adjoining the next door neighbours who had put his TV in exactly the same position and the interference passed through the wall.
Try moving the TV location away from all sources of interference (including Cable boxes, Video recorders, etc.) Does the problem change or go away?
Is the TV grounded properly? Interference needs to be siphoned off to a ground. if you put your hand around the cable that feeds the TV a video signal does the problem change or reduce?
Another issue may be some form of video post-processing going on causing the shimmering. Some forms of image smoothing software built into the TV can cause this. So try shutting down any features on the TV, does the problem go away?
On a big TV that is fed a low resolution video stream you will always see what the industry calls "artefacts". These are distortions caused by the transport compression of the video signal. there is no way around these except for receiving a better resolution picture stream.
Mar 13, 2015 | Panasonic TCP42C1 Plasma TV
Prints blank page first then freezes on the second page.
Blank or partial page printed
1. Clean the ink cartridge. (a) Complete the ink cartridge cleaning procedure.
2. Check the media settings. (a) Make sure you select the correct print quality settings in the printer driver for the media loaded in the trays. (b) Make sure the page settings in the printer driver match the page size of media loaded in the tray.
3. There is a blank page in the file. (a) Check the file to make sure there is no blank page. Something on the page is missing or incorrect (b) Check the margin settings Make sure the margin settings for the document do not exceed the printable area of the device.
4. Check the color print settings. (a) Make sure Print in Grayscale is not selected in the print driver.
5. Check the device location and length of USB cable. (a) High electromagnetic fields (such as those generated by USB cables) can sometimes cause slight distortions to printouts. (b) Move the device away from the source of the electromagnetic fields. (c) Also, it is recommended that you use a USB cable that is less than 3 meters (9.8 feet) long to minimize the effects of these electromagnetic fields.
6. Check the ink cartridges. (a) Make sure the correct ink cartridges are installed and the ink cartridges are not low on ink.
Dec 20, 2017 | HP Officejet 4500 All-in-One -...
How to turn on gps keeps saying gps turned off
GPS SYSTEMS HAVE A TENDENCY TO LOSE CONNECTIVITY TO SATILLITES BECAUSE OF BAD WEATHER, CLOUD COVER, TUNNEL ENTRANCE, BAD OR NO POWER, BATTERY LIFE HAS BEEN EXPENDED, HAZARD OF ELECTROMAGNETIC INTERFERENCE TO GPS SYSTEMS, AND IMPROPER VEHICLE MOUNTING AND HAND HELD POSITION. FREE SOLUTIONS 1. ALWAYS PLACE YOUR GPS DEVICE IN THE UPPERMOST PORTION OF YOUR VEHICLE SO THAT THE GPS SIGNAL MAY EASILY LOCATE YOUR DEVICE EVEN WHEN THE WEATHER IS BAD 2. KEEP YOUR BATTERY CHARGED ONLY WHEN IT NEEDS IT MOST AND AVOID CHARGING OFTEN 3. IF YOU OVERCHARGE YOUR GPS DEVICE, YOU WILL EXPERIENCE BATTERY LEAKAGE, WHICH CAN EAT AWAY AT YOUR CLOTHING, DESTROY YOUR DEVICE IN SECONDS, AND CAUSE DAMAGE TO YOUR VEHICLE SEATS 4. YOUR GPS DEVICE HAS A TENDENCY TO FREEZE BECAUSE OF THE SIM AND MEMORY CHIPS LOCATED WITHIN IT 5. YOU CAN FIX THE FREEZING PROBLEM BY REMOVING THE SIM CHIP AND MEMORY CHIP AND RESTARTING YOUR SYSTEM 6. OTHER FREEZE PROBLEMS OCCUR BECAUSE THE DEVICE IS COLD WHEN IT IS KEPT IN THE VEHICLE AND CHIP CREEK OCCURS WHERE THE DEVICES MICROCHIPS BECOME LOOSE AND TIGHTEND BECAUSE OF WARM AND COLDER AIR FLUCTUATIONS. IT IS BEST TO KEEP THE DEVICE IN A PURSE OR ON A TABLE WHERE IT IS NOT SUBJECT TO CONSTANT TEMP. CHANGE 7. PREVENTION OF ELECTROMAGNETIC INTERFERENCE IS BEST SOLVED BY: interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common
Jan 23, 2011 | Garmin Nuvi 350 Car GPS Receiver
Vauxhall vectera 55 plate cdti 1.9 6 speed not starting engine turning centeral locking working battery strong electrical problem ????
Jan 21, 2011 | GPS
Virus Check
when my F761usa screen turned black just happened I was reading my emails, since then I never can turn on my F761usa, not even get bios reboot. I thought I got deadly virus attacking to kill my notebook. during investigation we found our neighbour invaded our wireless router (we can see Nikky ipod as device name appeared in router, we blocked it then another Nikky phone as device name appeared again), meanwhile we found log files recording naughtyamerica website, we realized our neighbour visited some dangerous websits that's why I kept getting very dirty-emails over past 3 years.
By adjust netgear and notebook parameters setting finally our neighbour can't steal our internet services any more.
Then we spent $10 to convert internal HD as external usb HD and could be accessed by our another HP DV7. I doubt it was virus caused it.
we has att DSL internet services which provides McAfee, we has very old Netgear WGT624 wireless router but can block/data secured and window vista provides network secured setup.
we didn't buy any other virus software but run the free version(advanced systemcare).
Sep 08, 2010 | HP Compaq Presario F730US Notebook
Loss of network connection when computer is at rest
This can be due to the location of the router.
1. If the router is next to a cordless phone this can cause interference to the incoming data signal and cause what is call collision or EMF (electromagnetic flux) which is electromagnetic.
2. Move the router at 25 feet away from any digital devices.
Apr 19, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Bowing top and bottom temporary on cold TV
problem with unit is convergence--i would resolder convergence ics(they start with stk932-......)if that does not work replace them--if you need the exact part numbers email me at djstvrepair@comcast.net
Sep 15, 2009 | Pioneer SD-P50A3-K TV
I share a TV antenna with my neighbour. there are three splitters in the line - one to give an output to a next door bedroom TV, a second gives a signal to their lounge TV with th other leg continuing to...
I suspect there is a Mast Head Amplifier to supply enough signal to split so many ways and the power supply is powered from the power socket supplying the neighbours TV. Switch it off and no/poor signal.
Mar 21, 2017 | Televison & Video
Aquiring Network Connection over and over. RAWR
How many DHCP devices are there on the network?
There should be only one. Try disabling the DHCP in your device, then your neighbours router should issue IP addresses and all will be ok.
Apr 26, 2009 | NetGear WGR614 Wireless Router
Sony FD Trinitron KD-34XBR960 34" TV Logo
75 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
