Question about SanDisk Sansa e260 MP3 Player
Reset sandisk clip to english
Tried to update firmware changed language
  • Shadie Tcb
    Shadie Tcb Sep 01, 2008
    how do i change mp3 player from chinese back to english
How does one change the language on the e260 from any of the other languages it comes up in back to ENGLISH??? Some dolt said fixing would be easy to do with minor persistence. If that was the case I would have been done with it 3 hours ago. On this unit persistence is NOT the answer
chet
Posted on Sep 21, 2008
  • 981 Answers
Learn Thai or whatever, and this time get the right menu. The menu's in the same place.... This is something you can fix with minor persistence of course; otherwise at least drop a picture of your screen in your query, and you might be able to skip the perfectly cool emergent language lessons.
Posted on Jun 23, 2008
Sir i could change language in english.please guide me . email address;
just tap ur settings tab and go to regional settings and look for language settings select hard reset and select english or else try and update ur firmware and take the english firmware or if u r unsure log on to www.sonyerricsson-support-software-x1-update service and follow the instructions its very simple and if asked select english to be ur language was this useful to u
with warm regards- bonefirediv
Mar 25, 2011 | Sony Ericsson XPERIA X1 Smartphone
Just bought scan disk clip+ but is not in english and do not know language or how to change to english?
You should select Settings from the Main Menu then select language. If your player is set to a totally unknown language for you try it that way that you listen to the sequential of the possibilities using the manual which is here:
http://www.sandisk.com/media/327475/CLIP+_UM_0809_ENG+090309.pdf
gylacz
Mar 21, 2011 | SanDisk Sansa Clip MP3 Player
The menu is in a foreign language, which I can't read. How do I return it to English?
Turn on your clip
Go to settings (the eq symbol)
scroll to system settings
scroll to lanquage
Change to english
If you are unable to decipher the current foreign lanquage enough to find these menu options
Update the firmware again and you will be presented with the choice during the update process
Jan 27, 2011 | SanDisk Sansa Clip MP3 Player
The display language was changed from English to Chinese/Japanese
Here si the link to the user manual that will help you with the "flying blind" method of changing the language:
http://www.sandisk.com/assets/File/Downloads/user-guides/clip-usermanual.pdf
-Tha Mp3 Doctor
Feb 28, 2009 | SanDisk Sansa Clip MP3 Player
Foreign language on player, cannot install firmware update.
I was able to locate a tutorial on the Sandisk knowledge database that allowed me to reset the unit back to English.
Thank you.
Feb 12, 2009 | SanDisk Sansa Clip MP3 Player
I can't read the menu to change my player back to english.I need help to navigate through the menu to find settings. pLease help!
Use the following manual to help you "fly blind" and change the language back (or do an English firmware upgrade from Sandisk's website):
http://www.sandisk.com/sansa/assets/English/products/Clip/Clip_userguide_en.pdf
-Tha Mp3 Doctor
Dec 25, 2008 | SanDisk Sansa Clip MP3 Player
How do I change the language
You can go one of three ways. From the music/headphones icon, press down 3x (to get to settings); right 1x (to enter settings); down to the fourth option/line (observe the scroll bar to make sure you count from the very top) right 1x (to enter the languages menu). You will find your own language in plain text. It should work unless your setup is different or I miscounted somewhere. If that doesn't work, try updating the firmware. By doing that, it will ask you which language you would like to use on your Clip. If either of those do not work, plug your Clip into the computer. Then go to my computer under the start menu, find your mp3 player under the list (should be under 'devices with removable storage', or something to that effect). Right click on the mp3 player icon, and click "format". Go with the format it suggests, then reinstall the firmware from there. It will be like starting from square one.
Nov 15, 2008 | SanDisk Sansa Clip MP3 Player
Sansa clip needs to be in english
Get the full user's manual from Sandisk's website, and go down the various menus the exact # of times indicated by the manual. Or, upgrade the firmware - the firm upgrade is in English.
Sep 05, 2008 | SanDisk Sansa Clip MP3 Player
Language setting
Re-run the firmware upgrade from the Sansa website - as long as you pick the English firmware upgrade, it will have the effect of resetting your player.
Language in zen
To reset the language displayed on a ZEN player to English, change the language back to English or run Cleanup from the player.
For detailed instructions on how to access the Recovery Mode of a MP3 player, please see Recovery Mode: What to Do and How to Access.
If the player is a flash based player, such as a ZEN Nano, ZEN Nano Plus or MuVo, the language can be reset by manually changing the language or updating the firmware. To manually change the language:
  1. Press the scroll wheel to access the main menu.
  2. Scroll to the Settings option (the icon looks like a gear).
  3. Scroll to the Language option (the icon looks like a pearson speaking).
For detailed instructions on how to update the firmware of a MP3 player, please see Updating the Firmware on a Creative MP3 Player.
Dec 05, 2007 | Creative Labs ZEN V Plus MP3 Player
SanDisk Sansa e260 MP3 Player Logo
94 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
