Question about Crosley CAWC529JQ Top Load Washer
Crosley washing machine- conservator model
I just bought a used washing machine and it has several different water level selections. x-small small medium large and x-large. when i try to put it on large or x-large it starts filling but will keep filling but not turn off. the water level only comes up to half of the basket, but it will drain out so it doesn't go past that. what is wrong?
  • 1028 Answers
SOURCE: maytag washer water doesnt stop
raise top or remove front panel(can't remember which) rear corner left small hose attached to connector on tub pull and clean probably plugged up with crud also ck connection on tub
Posted on Dec 13, 2008
  • 47 Answers
SOURCE: Washer did not spin
JERRY,
IT SOUNDS LIKE YOU GOT TAKEN ON THIS WASHER. A NEW WASHER NORMALY WORKS, BUT IN SOME INSTANCES, LIKE YOUR CASE, IT COULD BE THE BELT OR THE MOTOR COUPLING. WHAT I WOULD DO IS CALL THE PLACE WHERE YOU GOT YOUR WASHER FROM AND HAVE THEM TO BRING YOU A NEW REPLACEMENT. THERE HAVE BEEN COMPLAINTS ABOUT WASHING MACHINES NOT WORKING RIGHT WHEN THEY WERE NEW. I HOPE THIS HELPS YOU AND ANYBODY ELSE WHO READS THIS WEBSIT, BECAUSE THERE IS NO SENSE IN THE STORE SELLING A BRAND NEW WASHER WHEN IT ALREADY LEAKS.
RODNEY
Posted on May 14, 2009
  • 50 Answers
SOURCE: Drain hose to crosley washing machine, where?
looking at the rear of the washer, my Crosley drain is on the left, about 4" from the floor and about 6" from the side. You might need to remove the back panel. Probably should anyway, so you can blow the dust/lint out of it
Posted on May 26, 2009
SOURCE: Crosley CW6000 Washing Machine. When my washing
My Crosley Cw6000 wash will not spin the water out, I lift the lid to watch the spin cycle, it spins but the water does not drain..
Posted on Dec 08, 2009
jumptrout51
  • 3361 Answers
SOURCE: Water will fill into my Crosley front loader
Use a putty knife to open the top lid and fold it back. Locate the lid switch. Unplug the washer. Remove the wires from the lid switch. Use a volt meter set for continuity and test the lid switch terminals. If they are open,no reading replace the switch. For a test you can jump the lid switch wires together,set the washer to spin and turn it on. If it spins it confirms a bad lid switch.
Copy and paste this link for a lid switch picture.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-cw5000-%3d%3di1456&PartID=1456
Posted on Jan 05, 2010
Is there a way I can change the settings of Whirlpool Washer Model # CAE2743BQ, because this Machine has a very low level of water. Kindly teach us how to make the water plenty in the washer..
If you do not have owner's manual, try manualslib.com Double check the method for setting water level (load size). There may be an "energy conservation or water conservation" mode.
I would also take the purchase receipt to Home Depot and ask for help. If it is all machines, there may be a factory defect. Hopefully, you are within the factory warranty time.
Apr 01, 2015 | Whirlpool Washing Machines
My speed queen washer wont fill all the way up on extra large setting. How can I adjust the water level switch so that it will fill up to the top? My model is Awn542
This is mentioned in the manual-the federal gov't has required manufacturers to set water levels lower to conserve water. You can fill it more by holding the load size level to reset until it has the amount you want.
Jan 20, 2012 | Speed Queen AWN542 Washer
Clothes are coming out VERY wrinkled! Having
Inadequate water. Water level switch needs adjustment to take more water. Or water level sensor. Refer to the supplier if it is under warranty.
Mar 29, 2010 | Washing Machines
Crosley CW6000 Washing Machine. When my washing machine is in the spin cycle, it shakes severely and the machine on the floor
Sep 02, 2009 | Crosley CW6000 Front Load Washer
Washer did not spin
JERRY,
RODNEY
May 14, 2009 | Crosley CAWS729MQ 3.2 cu. ft. Washer
Washer overflows on any water level selection
check the pressure tube from the tub to the water level switch for a hole or crack in the tube, if none found replace the water level switch
May 27, 2008 | Crosley Washing Machines
LINT STICKS TO MY CLOTHES IN WASHER
linting is caused by a few things
firstly what sort of soap poweder do you use
i recomend good quality powder
do not wash clothes too long as what you are doing is rubbing all the fibres out of them
good quality washing powder only last about 6 minets in water and after that it looses its qualiteseg
the PH changes in the water
you may be using too little soap powder and this also depends on water quality eg too hard or soft water
is the water levels set corectly
do not mix washing
eg towels with jeans as the lint will come off onto jeans
try using delicate wash on different fabric as the adgitation is different on different cycles
try using warm wash and not cold machine is probable ok but wah times are important
good luck
Nov 27, 2007 | Crosley CAWC529JQ Top Load Washer
Crosley caw5923mqd Top Load washer spins but leaves A LOT of water in the clothes
have you checked the pump out of the maachine
the pump may be blocked restricting water flow
if that is ok maybe you need to give the n
machine a hot wash the seals may be draging the spin down
Oct 12, 2007 | Crosley CAWC529JQ Top Load Washer
Crosley CAWC529JQ Top Load Washer Logo
853 people viewed this question
Top Crosley Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Gerry Harvey
Gerry Harvey
Are you a Crosley Washing Machine Expert? Answer questions, earn points and help others
