Question about Whirlpool LER5636P Electric Dryer
Whirlpool Electric Dryer Model LER8858EQ1 TYPE NO. 180-0
When dryer is operating and the door is opened while dryer is in drying cycle the heating element remain will remain on, when the timer is in the off position the element is off.
Could this problem be caused by the HI Limit Thermostat? If so how can it be checked?
The 196 degree thermal fuse was open.
  • prg105 Jun 23, 2008
    Checked heating element and it appeared as if over time the heating element wire had vibrated and was touching the element frame and causing a short. After adjusting the coil, the short was gone. None of the insulators were broken.
    Thanks for the help, it put me in the right area to correct problem.
  • prg105 Jun 24, 2008
    It appears that vibration of dryer caused a coil of the element to come in contact with the frame the coil is mounted on causing a short. Adjusted the spacing of the coil the element works OK and dryer does not heat when door is opened during the timer cycle.
    Thanks for all the help you point me in the right direction.
  • 525 Answers
Based on the information that you provided, if you open the door in mid-cycle and the motor shuts off, but the element stays on, this will stop the air flow through the dryer and the element. The element temperature will rise drastically because it is not being cooled. Subsequently, to prevent a fire, the thermal fuse will open, shutting the element, and in some cases the motor, down.
A heating element gets its power from the timer, through the cycling thermostat(s),and to 1 side of the element.
When the motor starts, power is passed through the centrifugal switch in the motor, through the hi-limit thermostat and the thermal fuse to the other side of the element.
There is no ground wiring involved in the heat side of the dryer.
1. An element can stay on because it has broken and fell against the metal tube where it picks up a ground. Solution is to replace the element.
2. The centrifugal switch mounted on or in the motor can fail to open when the motor stops and allow current to flow through it
until the points in the timer open up, breaking the circuit.
Below is a link that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 23, 2008
  • David Emmel
    David Emmel Jun 24, 2008
    Thank you for your very generous rating! You may have an element failure in the near future, as once they short out against the frame, the molecular structure changes and the element usually burns through at that spot, rather quickly sometimes.
    Good luck,
    Dave E.(Illeagle)
Our Maytag Centennial Electric dryer is not cycling in auto dry mode but will in timer mode. Any thoughts?
There is a sensor that the clothes have to touch when the drum spins. This sensor measures how wet the clothes are. If you don't have enough of a load in the dryer then the sensor wont detect the dryness. Or it could be a bad sensor or connection or main board.
Nov 02, 2015 | Maytag Centennial 7.0 Cu. Ft. Super...
My dryer is running hot but doesn't dry the
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
Aug 05, 2011 | Whirlpool Electric Dryer Heating Element...
My dryer is producing heat but is not drying, i am drying the same size load i usually do on the same cycle. the lent is cleaned out, and the oustide vent is blowing hot air. why are my clothes not getting...
make sure that all the seals are ok, door,front and back drum seal, blower housing seal(inside dryer). also consider that depending on washer type if you overload or have a worn drive belt in washer it will take twice the time to dry. also make sure that the dryer drum tumble. open door,press door switch and start dryer to see if drum turn. lastly disconnect vent pipe behind dryer and dry a load. if it dry ok then you have a partial blockage. you can also have a weak heating element.
Feb 11, 2011 | Whirlpool WED5300S Electric Dryer
Dryer spinning but not drying!
if it runs with the door open the door switch could be defective,otherwise check your heating element high limit/cycling thermostat switch,then the thermal fuse on the side of the vent housing.and also check the power input for 240 volts a.c. if its an electrically heated element,if inside the terminal strip any terminals burn or break off the element can't heat/if its a gas dryer,check the thermal fuse,the high limit thermostat,the radiant sensor on the burner tube or the gas boost and secondary coils on the gas inlet valve,they get weak or open and close off the gas supply
May 13, 2010 | Whirlpool LER4634J Electric Dryer
Dryer heats up but clothes won't dry
Sounds like to me, that you need to check the vent going outside from the dryer. I had the same problem, and found a birds nest in the dryer vent on the outside of my house restricing air flow. If that doesn't fix the problem, look into a new heating element and or thermostats for the dryers. The old ones could just not be getting hot enough anymore. Good luck.
Apr 08, 2008 | Whirlpool LER5636P Electric Dryer
E-2 error code on whirlpool duet dryer
“E2” flashes if the thermistor has shorted.
The thermistor monitors the exhaust temperature
and cycles the high-limit thermostat on
and off to maintain the desired temperature.
1. Turn the dryer off but keep the electrical
supply connected.
2. Make sure that the dryer is empty and that
the lint screen is clean.
3. Close the dryer door.
4. Select Heavy Duty, Timed Dry, More Time
or Less Time, End of Cycle Signal (Louder)
and Start.
5. If error codes E1 or E2 flash on the display
after 1 minute and the dryer turns off,
the thermistor, or the wire harness, is either
shorted or open. Check the wire connections
at the thermistor or the machine
control electronics board. If wiring checks
okay, replace the thermistor.
6. If the dryer seems to operate normally, remove
the exhaust vent and start the dryer.
7. Select the desired temperature cycle to be
tested, and select 20 minutes of Timed Dry
heat using the More Time or Less Time
Feb 25, 2008 | Whirlpool GEW9250 Electric Dryer
Whirlpool dryer - element heats, then shuts off quickly
Sounds like you have a stopped up vent on your home, when the vent gets stopped up the dryer can't circulate the air properly in the dryer and causes it to get to hot which causes the high limit thermostat to kill power to the element. If you need more help with this visit the link below:
Appliance Repair Guides
Mar 18, 2017 | Whirlpool Dryers
Whirlpool LER5636P Electric Dryer Logo
317 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
