HOOK UP sATELLITE BOX TO vcr AND pHILLIPS FLAT SCREEN tv
  • Marvillinaz Jun 26, 2008
    Yes, thank you for taking the time, you are most kind!
    Scholar:
  • 167 Answers
Hello. the first thing is to find the in to ant.!! on your vcr.!!! that's where you hook up the out to tv.!!! from the satellitebox.!!! then you hook up the out to to tv .!!! from your vcr.!!! to your flat screen tv .!!! to the in from ant.!! on your flat screen.!!! that should do it for u .!!! let me know if this help's u. GOOD LUCK.!!!
Posted on Jun 23, 2008
  • MICHAEL WALLACE
    MICHAEL WALLACE Jun 26, 2008
    HELLO. .!!! THANK YOU "AM" GLAD I COULD HELP YOU WITH YOUR PROBLEM. !!! AND JUST THINK YOU FIXED IT YOUR SELF.!!! WITH OUT HAVING TO PAY SOME ONE TO DO THIS FOR YOU.!!! AND "AM" SURE YOU WILL REMBER HOW TO DO IT.!!!. IF YOU NEED TO DO IT AGAIN. !!! WELL THANK'S AGAIN.!!! FOR YOU RATING.!!!
Is a freeview box or freesat box required with a new phillips flat screen tv?
No, what a free box does is it can receive certain mostly HD channels and play them on your TV. They are nice and would be a nice addition alongside a new flat screen but no they are not required. All you need to play your cable/satellite is a good ol satellite box and some red white and yellows or antenna cable.
Hope this helped.
Feb 07, 2011 | Philips Televison & Video
Can't find where to hook up tv coax.
As far as I can tell your TV is just a monitor. You would have to buy a separate tuner. I had the same problem with mine and found it was cheaper just to use an old VCR. I hooked up the coax wire up to the VCR and hooked the VCR to my TV with composite cables and changed my channel through the VCR. That will only work now if you're using cable because of the switch to digital. If you're using an antenna you will need a digital tuner.
Aug 08, 2010 | Philips 32FD9954 32 in. HD-Ready Plasma...
Tv has only snowy screen. Used the remote to
What to do if you have an all snowy picture (blue screen or the TV displays unusable signal-no signal or no sync)
1 – If you are using a digital cable box or satellite receiver (make sure it’s on) and be sure your TV is set for either CH3 or CH4 (which ever you usually view it on). If you usually view it through video inputs (video1 or 2 etc.) make sure the appropriate input is selected.
If you still don’t get a signal see if you get picture using the DVD or VCR (if available) if you do than plug the satellite or Dig. Box temporarily into the place of the DVD (unplug DVD) you may have to use some A/V cables (RCA yel./red/wht like the ones on the DVD) to hook to the tv from the sat./dig. box. If you get a signal then the sat./dig box is ok. If not the Sat./dig box is not sending a signal and is either defective or needs to be rebooted (unplug wait 5 min try again).
2 – If you are using standard cable or antenna (source) if possible check that the source is good by connecting to another TV. Otherwise try running the source into a VCR and then out to the TV using video inputs (RCA yel./red/wht like the ones on the DVD) and then selecting the appropriate input. Try seeing if the VCR plays using standard CH3 (or CH4)
If the VCR plays on video input but not when connected to CH3 (CH4) then the tuner of the TV may be defective – see if you can use the VCR to change channel using the VCR remote.
Be sure to vote/rate me if this helped Thanks!
Nov 24, 2009 | Toshiba 32AV502U 31.5 in. LCD HDTV
How do i hookup vcr to tv
The best way to hook up your VCR is to use the AV jacks (Red, White, and yellow). Plug into AV1 or Video 1 on the back of the TV. Then, plug into Red, White, and Yellow output jack on the back of the VCR. After everything is hooked up, turn your TV channel to AV1 or Video 1 to watch from the VCR.
To record, you'll have to plug your cable box or satellite box to the AV inputs ( Red, White, and Yellow) in the back of the VCR. ( The only thing is it wouldn't be in HD )
Nov 04, 2009 | Zenith Z50PX2D 50 in. Plasma HDTV
Blue screen. No audio or video through the cable hook up. RCA model #32V420T
Oct 25, 2009 | RCA 27F534T TV
No signal
Try video input using a dvd - if you are using a digital cable box (or satellite) use the a/v outputs (yel red wht wires)to hook to video in of TV. If you are using standard cable hook the cable through a vcr if available and hook the a/v of the vcr to video in of the tv.
Otherwise is tv(to be used) on Ch3?
The TV tuner may be defective.
If this helped Vote/rate me.
Oct 05, 2009 | Televison & Video
How do I hook up the recorder
Hi....
Take the output of the Satellite box to the "In from antenna" or "in from cable" then out to TV from the VCR to the TV.
TV should either be on 3 or 4 depending on what the satellite box is set for
Feb 18, 2009 | Sansui VRDVD4005 DVD Player/VCR
Setting up DVD/VCR
Depends how you have connected to the TV.
You will need to set your TV to the relevant socket you have connected the DVD/VCR into.
S-Video, Component , composite etc
These will be EXT 1 , EXT 2 or AV 1, AV 2 etc.
Feb 18, 2008 | Philips Magnavox DVD/VCR Dual Player
Televison & Video Logo
Top Televison & Video Experts
