Question about Goldstar DH504EL Dehumidifier
Dehumidifier Goldstar dehumidifier Model # DH404EY5, S/N 503TAHQ03297 Fan will run and I assume the compressor is trying to run and the breaker trips. I dissassembled back of unit and compressor is very warm. Does this mean the compressor is bad, is there something else that needs replacing? or what. Pleasen respond to jpeabody@ecasd.k12.wi.us Thank you, do you know what kind of warranty. It is 2.5 years old.
SOURCE: trips the circuit breaker on start up
I would try to find an outlet on another circuit to see if maybe the problem is definately your dehumidifier, if it trips again then you know it is...If not then call an electrician..
Posted on Apr 27, 2008
  • 210 Answers
SOURCE: dehumidifier freezing up, is it the de-icer control? can it be replaced ?
Could be the tempurature of the room you have it in. Make sure it is not operating in a room below 65 degrees F or 18 C
Sgt 48
Posted on Jun 02, 2008
22yooper
  • 828 Answers
SOURCE: GHD30 dehumidifier completely dead
If any machine is completely electrically dead it is a sign that there is no electrical voltage getting through to operate it. Using an electric meter it is a relatively easy task to find the point of differential voltages which would indicate where the open circuit is located. The blue green fluid found is from copper oxide and is not necessarily indicative of a refrigerant leak. Oil present would be an indicator of a refrigerant leak.
Posted on Nov 17, 2008
  • 4 Answers
SOURCE: Goldstar DH304 Dehumidifier
Take cover off. First check the fuse on the circuit board. If it's blown replace it. That should get the motor running, the motor might be or is going out. If the motor is bad you'll have to replace the motor. If the fuse is good and the motor is good, unhook the wires on circuit board that go to the humidity control switch. If the unit comes on with the humidity control switch unhooked, you'll have to replace the humidity control switch. Sears has them for about $11.50. Hope this helps.
Posted on Jul 11, 2009
  • 10865 Answers
SOURCE: Goldstar dehumidifier keeps tripping the
your problem may be within your dehumidifier or it may be within the circuit breaker itself. I just replaced a faulty breaker this morning for a customer.
plug the dehumidifier into another plug which you are sure is working and also sure is not on the circuit you have been using. [turn that breaker off and you will know what it controls
if the problem is the breaker, replace it. if the problem is the dehumidifier look for a poor connection, a bare wire touching the frame of the dehumidifier, a fryed wire, etc. good luck.
Posted on Sep 09, 2009
When dehumidifier is turned on the circuit breaker trips. everytime the dehumidifier is started model LHD65EBL
Hi, Compressor is bad... tripping the breaker...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Sep 06, 2011 | LG LHD459EL Dehumidifier
Fan runs and the compressor tries to kick on and there is a low grinding sound and then it goes off and the fan continues to run. The cycle repeats itself and the compressor never engages. It is not...
heatman101
Sep 03, 2011 | Goldstar DH504EL Dehumidifier
When I plug it in and turn it on it trips the breaker. I have tried other outlets but it does the same thing.
Hi, The compressor is locked up and is bad... that is what trips the breaker...
heatman101
Jul 31, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
Have a Goldstar Dehumidifier GHD30. Approximately 2 years old refurbished. The fan will run on the lowest setting but the compressor does not start. When I turn the dial to a higher setting the breaker...
doesn't sound good sounds , the compressor is bad .. you might want to check if it has a gfic. i could be bad, i would cut it out and try it without before i replaced a gfic
Jul 25, 2011 | LG DH30 GoldStar Dehumidifier
Dehumidifier keeps blowing circuit
The compressor is bad...
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Jun 12, 2010 | Goldstar DH304 Dehumidifier
I have a Goldstar Dehumidifier DH504ELY7 that doesn't pull moisture out of the room. the fan runs and I think I hear the compressor come on but the air coming out the back is cold and the bucket doesn't...
There are many reasons why a dehumidifier will not work or collect water.
heatman101
Jun 11, 2010 | Goldstar DH504EL Dehumidifier
Trips the circuit breaker on start up
Oct 17, 2007 | Goldstar DH504EL Dehumidifier
Dehumidifier tripping the breaker
be very careful - with the unit unplugged - try shorting the capacitor with an insulated screwdriver. if you get a healthy spark - the cap is probably ok. if you don't replace the cap. the cap is used in the motor's start winding.
Aug 21, 2007 | Maytag M7DH45B2A Dehumidifier
Goldstar DH504EL Dehumidifier Logo
130 people viewed this question
Top Goldstar Dehumidifiers Experts
Gil Shultz
Michael Youngman
Michael Youngman
Jerry Greenberg
Jerry Greenberg
Are you a Goldstar Dehumidifier Expert? Answer questions, earn points and help others
