Question about MSI KT4V (MS-6712) Motherboard
I would like to know , the pinout for the front panel connector (Reset, Pon, HDD led. Thank you in advance.
SOURCE:
  • 624 Answers
SOURCE: Blinking Power LED ... no other action
Hi switchblade, Some of this will seem basic or even a rehash of what you?ve already done but please keep an open mind. The one thing I?ve learned over the years is never assume anything especially when things aren?t working like they?re supposed to. -The first thing I would do is to check each screw, card, connector and component you installed to make sure nothings being shorted out or is improperly connected. Common occurrences are screws touching capacitor or other component leads. -Check the power connectors to make sure everything is connected correctly and that all the contacts are still mounted in the plastic connector correctly. -Check the output on your power supply and verify it?s rated for your motherboard. It?s possible that whatever caused them to replace the motherboard could have been caused by a defective power supply or vice versa. -Make sure the motherboard is correctly grounded to the chassis per your instructions. Typically the mounting screws touch a grounding plane on the motherboard and in turn ground that to the chassis. If your using plastic mounting studs that might be a problem. -Verify the power switch is working correctly. -Make this as basic a machine as possible: remove and add in cards (except primary video card), remove all USB components, reduce the size of your memory (RAM) and if you have multiple hard drives remove all except your boot drive. -Try a more basic known good video card, a PCI if you have one. -Again whatever problem caused MSI to warranty replace your motherboard could have damaged your processor or memory. I would have expected a beep code but if you?ve gotten this far without resolving your problem we?re running out of possibilities. -If nothing changes can you tell us some more about the status of the computer or what led up to this? Did you just build it; just install a new part, power problems, anything? Let us know what you turn up and please don?t forget to rate the posting.
Posted on Jan 08, 2007
mastersaintx
  • 928 Answers
SOURCE: Front Panel Connector: JFP1 hookup
You can go to the link below and see the directions for that. Turn to page 2-17
http://www.premioinc.com/pc/manuals/mb/m266/m266.pdf
Posted on Sep 21, 2008
  • 35 Answers
SOURCE: front panel connectors
hey its in manual book which u got wit MB pack
Posted on Sep 21, 2009
  • 26 Answers
SOURCE: how to connect jfp 1
go to www.msi.com.tw for MSI guide , it should show you your motherboards front panel intel connection guide , it should be like this
PSWITCH PLED Open
RESET HDD SPK
Posted on Jun 08, 2010
  • 33 Answers
SOURCE: Problem with the MSI 7050
Sorry, I can't find a color diagram. But check page 2 of the HP support manual, this shows all the jumpers and board connectors. You can download the manual from the link below:
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00358730/c00358730.pdf
Posted on May 20, 2011
Ms-6541 ver 2.1 mobo pin connector
Hello this should be the homepage:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=97106&prodTypeId=12454&prodSeriesId=96284&swLang=13&taskId=135&swEnvOID=1093
The front panel looks like this:
d450e023-b94a-4bba-87c8-871096a37704.gifF_P1 PinOut
17 15 13 11 9 7 5 3 1
18 16 null 12 10 8 6 4 2
SHORT:
HDD led op 1/3
Power led op 2/4
Power Sw op 6/8
Reset Sw op 5/7
Here is also the manual:
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&locale=en_US&docIndexId=179911&taskId=101&prodTypeId=12454&prodSeriesId=316609
The usb connector looks like this:
e3c82873-b0a1-49b3-91f4-548ca5550428.jpgIts basicly just to insert the black connector in it.
Best of luck
Jul 16, 2013 | Computers & Internet
Front panel connections
I don't find the Front Panel header pinout online, nor do I have an MSI MS-5191 in the shop.
I would suggest using one the LED lights with two wires.
(3-wire is a dual color LED)
There are two rows of pins. Usually the Power On switch, Power On LED, and Speaker; are on the same row.
HarDDrive activity LED, and Reset Switch are on the opposite row.
Speaker has 4-pins designated for it. All the others use 2-pins.
(Unless the PWR ON LED is a dual color jobbie)
Touch two pins next to each other, in the same row; with the 2-wire LED.
Start with finding the Power On switch first.
Usually the top row 1st two pins are Power On LED (Light)
Next in line are the 2 pins for the Power On switch.
Bottom row 1st two pins are usually HarDDrive activity LED (light)
Next 2-pins are usually Reset switch.
May not apply to a motherboard old enough to use a Socket 7 processor socket.
There may be 18 to 20-pins.
Bear in mind that many are not used, and probably 4 are for an internal speaker, for hearing BIOS Beep Codes.
May be two separate Front Panel headers.
Once you find the two contact pins in the Front Panel header, for the Power On switch; I would put the Power On switch wires on.
The small pin connector on the wire/s, will keep you from accidentally touching these two pins again, when the computer is on.
Now you have the two pins for the Power On switch, and the computer is running; then keep touching 2-pins at a time with the LED. (Light Emitting Diode)
LED stays on? You have the Power On LED (Light) pins.
LED blinks? HarDDrive activity LED (light) pins.
Computer restarts? Reset switch pins.
Look for abbreviations near the pins in the Front panel header.
PWR, Pwr, Pwr On, Sw, and SW; are just some of the abbreviations for the Power On switch.
HDD LED, and HDD are two for the HarDDrive activity LED. (Light)
(If it states HDD SW it is the Power On switch. Weird old way of marking)
RST, Reset, and RSW, are for the Reset Switch.
(Reset Button)
If you see 4 pins marked with a bracket ( [ -> Turn so it's horizontal), these are for the internal speaker.
Type MSI front panel connector in your search bar, and look at -> images. See if you can find an image of your MSI Front Panel header pinout.
You can bet MSI carried out that Front Panel header pinout, on other MSI motherboards, besides the MS-5191.
The MSI MS-5191 may have been a motherboard made by MSI, especially for a pre-built computer manufacturer, and not listed on their website as an OEM motherboard.
(Original Equipment Manufacturer)
Won't have the Front Panel header pinout, listed on MSI's support website. (Doesn't)
But you can bet there IS an OEM motherboard made by MSI, that the Front Panel header DOES match.
May be different expansion slots, or motherboard chipset, or whatever; but the same Front Panel header pinout.
Regards,
joecoolvette
Jan 05, 2013 | AMD MicroStar MS-5191 Socket 7 mATX...
Power switch
You maybe able to download a motherboard manual from this WEB site and identify the connectors for the front panel.
http://devxstudis.org/int/intel+d865gkd+motherboard+manual.html
Jan 03, 2013 | IBM Computers & Internet
Dell T7400 Front Panel Pinout
The wires should be labeled such as HDD LED, POW LED
On the motherboard you should see corresponding with + and - Colored wires are always the + and black (ground) is the -.
Dec 21, 2012 | Computers & Internet
TRYING TO HOOK UP MU POWER BUTTON NEED TO KNOW
Hi there
The front panel connectors are mainly,
  • harddisk activity connector
  • power switch connector
  • reset switch connector
  • power LED connector
  • speakers connector
  • USB connector
Harddisk activity connector
This normally comes red in colour and is labeled as HDD-LED
Power switch connector
This comes green in colour and is labeled as POWER-SW
Reset switch connector
This usually comes grey in colour and is labeled as RST-SW
Power LED connector
This is usually green in colour and is labled as PWR-LED
Speakers connector
This speaker will give different beep sounds during boot to tell the user if there is any errors. It occupies 4 pins, however only 2 is important for the function. Be sure to connect the red coloured cable to the positive polarity and the black to the negative.
front_panel_connectors.jpg Front panel connectors pins on the motherboard
front_panel.jpg Front panel connectors from the casing
Good luck and thanks for using FixYa!!
May 13, 2009 | eMachines T6420 PC Desktop
IBM Netvista MB 49p1599 Front Panel Pinout
1 pw sw
2 pw sw
3 rst
4 rst
5 - pw led
6+ pw led
7+ hdd led
8 - hdd led
<== left 1. . . . . .8
ATX connector ==> right
Mar 07, 2009 | IBM (49P1599) Motherboard
You can download the complete user manual in English from the manufacturer's website at this link:)
http://support.asus.com/download/download_item_4.aspx?product=1&model=P4B533&SLanguage=en-us&os=17
The front panel connector pinout is on page 2-33, or page 59 in the PDF file. You should have mor ethan enough information to make all the connections you need.
Jan 02, 2009 | ASUS P4B533 Motherboard
New motherboard
You don't say what case you are using. If it is proprietary and the front panel header is all in one connector, you can carefully back the connector pins out of the block using precision screwdrivers. I keep a bunch of two pin connectors from junked machines so I can create individual connector sets when changing motherboards (eg, PWR SW, PWR LED, HDD LED and RESET). This also requires that you know the pinouts of both the old board and the new one so you can get everything connected properly.
Very doubtful you will ever find an adapter to change from one front panel block to another.
The 9-pin connector probably uses a spacer pin between the legs of the PWR LED, while it seems the 6-pin does not have RESET.
Dec 30, 2008 | Asrock P4i65G Motherboard
PC Chips M955G Motherboard Front Panel Pinout
i suggest to find in website..www.Fixya.com
if not found..post it again so that we can suggest another site.
thanks
Jul 25, 2008 | Mercury P4VM800M7 Motherboard
Open Questions:
See all MSI KT4V (MS-6712) Motherboard Questions
MSI KT4V (MS-6712) Motherboard Logo
184 people viewed this question
Top MSI Computers & Internet Experts
Alun Cox
Ekse
Thomas F. Schneider
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
