Epson Stylus CX5500 error message even after resetting
Hi. The printer we have now has been converted to CISS and it was working fine until recently when the two red lights started blinking. Our ink supplier emailed us the resetting instructions and it didn't work the first time we tried it. Their technician went here and they were able to reset it on another computer. However, we noticed that the error message that appears each time we print keeps appearing. After a day or two, we couldn't use the printer again. Another expert said that there may be a problem with the hardware itself (e.g. inkpad) but did not give any instructions on how to solve this. I have notified our ink supplier again about this but I am not sure how long it will take them to get here. Our shop is in Cavite. If there is a step-by-step guide that you can give us that we can do ourselves that would be ideal. Thanks!
  • 4 more comments
  • Anonymous Sep 07, 2008
    When we got the printer the printer was fine yet the printer went crazy the two red lights were flashing and the printer did not let us change the ink. Is the ink the problem or the printer its self. The scanner works but it just won't print.We are finding lots of problems as we read another person had the same problem. We tried to print but on the computer screen it said the printer had an error. How can i fix this problem.
  • Anonymous Sep 16, 2008
  • cmos_comp Sep 17, 2008
    I've use the SSC software with my CX5500 several time and try all model on it. but it's not worked. The fact there is no CX5500 model in the list.
    My CX5500 still quiet. No error message specifically. there only X sign on all Ink indocators, and Low Ink status reported by printer on the screen, while all ink indicators show FULL filled. additional information show that wasted ink status is 0 and the date mark of the cartridge is 07/2013. am I have to throw it out to the street?. Is there another solutions?.
  • JONIL888 Jan 05, 2009
    I have the same problem with my CX5500. I have tried that CX5500 specific resetter but the problem still comes back after turning on the printer twice...
    Please can someone there help me with this to reset.
    You may email me at jonilme@yahoo.com
    Please......
  • Anonymous Jan 14, 2009
    Hello, I got the same problem too. I applied the resetter but it still double red lights in my epson cx5500. I seems I have to open it up to clean it. Do you have any service manual for CX5500. or may i ask step by step guide in openning the printer.
    Please email me if you have any service manual or know how to open/disassemble the cx5500 printer: dimput@teamiso.com
    Thanks.
    RDD
  • Anonymous Feb 18, 2009
    my printer cartrigde won't move....
    the 2 red lights are blinking....
    pls help me how to fix it...
I had a similar problem with my CX5500, there seemed to be something blocking the carriage movement. I looked inside to find a child's sock, so to fix this error REMOVE SOCK FROM PRINTER (or any other obsturction like crunched paper perhaps)
Posted on Sep 03, 2009
Try downloading this resetter, just follow the link. SSC Service utility won't work CX5500 is not supported by SSC even with the latest version 4.3
http://www.4shared.com/file/58582916/1fe87f74/Resetter_CX5500.html.
If you did not put out the tube for the ink flow before using the CISS then most probably your ink pad is full. The best solution I can offer for this is you should put out the ink flow tube and just let the ink pad dry up after resetting.
For help in putting out the tuber for ink flow please email me at ngl.mrls@gmail.com. I can send you photos.
Posted on Aug 11, 2008
  • atmGraphX Nov 11, 2009
    This is a followup to my earlier post. To those who emailed me at
    ngl.mrls@gmail.com and was not able to get back to them, sorry.
    Instead you can reach me at angeltmorales@gmail.com. Better yet
    just download the detailed intruction on how to put out the tube of the
    ink flow of the printer just follow the link : http://www.mediafire.com/file/0unnmynjmm... CX5500 tube.pdf
    it is in PDF format, if you need a PDF reader download it at http://get.adobe.com/reader/. Hopes this simplifies everything.
    Problem Solver:
  • 5 Answers
"error: part inside your printer (blah blah blah)" well if you have a printer cx5500 by epson and you are using cis. you might need a resetter program or software available download via internet... if you all ready have one then ok.... follow the instructions.... if it work then ok again.. if you reset your printer multiple time and not actually changing or cleaning your waste ink pad then you have a problem... because if you are reseting no matter how many times if did not replace or cleaned your waste ink pad it will always ask for a reset, just always remember if you reset your printer clean your waste ink pad... how to get the waste ink pad.... you have to dismantle your cx5500 which is pretty tough and if you can't do it don't try to dismantle it.... approach a professional.... or a repairman.... use the internet to find one....
Posted on Jul 20, 2009
Posted on Jun 14, 2009
    Brigadier General:
  • 6,966 Answers
The most help I can offer is a link to a utility program designed to reset most (if not all) parameters of a variety of Epson printer models. You need to determine if said utility program will work with your particular model. This utility is SSC Service Utility for Epson Stylus Printers and may be downloaded from here. Additional information may be viewed here.
Even if your specifi model is not mentioned, often the the utility program works so perhaps you can still download and give it a try.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jun 24, 2008
Guys I have used that SSC Service utility and it worked good for me first thing i did was clean the ink waste pad inside my CS5500 (too messy if you cannot dis assemble dont try!) and after cleaning the wasted i have to let it dry before i assemble it again.... when its all done the assembling takes place another hard thing to do (i Hate disassemble & assemble)... then i used SSC Service utility and walla Ink waste pad was reseted...the last problem i encountered is that my nozzel got clogged!....
For help in putting out the tuber for ink flow just remove the cover in the back of your printer and pull out the hose just put a container...... (this works for me!) ^_~
if you have questions just e-mail it to at rowina_santos@yahoo.com
and i can give you a copy of my said SSC utility..
GM-Nitoy;
Posted on Sep 20, 2008
Try this program it work with my cx5500.the instructions are included in the program....
don't forget to clean the waste ink pad firs before resetting.....
How?
There's an opening at the back of the printer....you will see a tube there......remove the tube and place it in a small container so the ink can flow there....and then you can run the program....
Download adjustment program epson CX5500: http://www.mediafire.com/?apmmjzdzjm0
Posted on Sep 27, 2009
I also have the same problem..i have cleaned and dried the left and right waste pads and after a few tries of trying to get it work...the problem pops again...
can anyone give an insight to this problem?
what other options do i have to make it work?
by the way it also uses the CISS...
thanx in advance!!!
Posted on Jul 13, 2009
2 Suggested Answers
Basti
  • 1447 Answers
SOURCE: Epson Stylus CX5500 error message
actually i dont have one, sorry it took me awhile to reply check this website though and look for the utilty- printer reset utility- and check on the model number it supports:
http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp
Thanks for using fixya!
Posted on Jun 23, 2008
How to reset 73/91 Cartridges for Epson CX5500
SSC utility is used for resetting waste ink counter, not for ink level counter (chip at ink tank). If you wish to reset ink level counter (chip), you must use hardware resetter, or use CISS chip with autoreset function.
Oct 18, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Epson CX5500 with CISS ink supply not printing
Ive replaced all the cartridges on my epson 5500 but still nothing prints. Any help gratefully received
Jun 19, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Problem in my ciss cx5500
click the start button,then control panel,then look for device manager, then look for printer. then look under options. then choose "update driver" then that should work
Jan 13, 2009 | Epson Stylus 2200 InkJet Photo Printer
Error massage not compatible ink cartrage when using ciss supply
Solution?the solution is never to buy an epson printer ever again! i bought mine early last year with the CISS and since then have give me that same red lights problems like .. forever ! the solution is to sort of take off the carttridge and put it back again. u might have to do this a few times before it actually work . and oh yeah , you have to print everday with epson cause otherwise the ink will clog !! mine is already clog, i have to buy the original ink now to unclog it but still it produce lines! Since then i have give up hope and put my epson in the box to end my misery . i;m using Canon Pixma MP142 with CISS and till now no problem !!
Jan 02, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Ssc utility
this may help you
Here is how to reset the waste counter for the Epson R200, R210, R300 and R310 printers.
  • Press and hold “Stop”, “Maintenance”, and “Power” buttons for about 10 seconds. A message will come on the screen saying counter is reset and to turn the printer off. The R200 and others don’t have a screen so just wait until the 10 seconds is up.
  • Turn the printer off, unplug the power cord. Wait about 1 minute and power the printer back up. The counter will be reset. That’s all there is to the reset procedure.
Nov 20, 2008 | Epson Stylus Photo R300 InkJet Printer
Jun 22, 2008 | Epson Stylus 2200 InkJet Photo Printer
Epson Stylus CX5500 resetting; notification of need for servicing keeps popping up
Hi-
Yep chances are there is a problem with the hardware itself. On the computer where you have it connected directly, did you get an error message? if you did then it talks about part at the end of service life then that is the inkpad you are having a problem with, but if there is no error message that popped up on the computer then there might be a problem on the mainboard, call epson so that they can give you a discount if you are going to buy one from them again. you can reach them at 562-276-4382. Thanks for using Fixya!
Jun 21, 2008 | Epson Stylus 2200 InkJet Photo Printer
7,666 people viewed this question
