Question about Whirlpool Duet GHW9150P Front Load Washer
Once machine is turned on DL code flashes and alarms. Doesn't allow machine to initiate cycle.
    Problem Solver:
  • 12 Answers
Try everything else, like reseating the connectors, then look here:
http://adsisecurity.com/KenmoreWasher.htm
Posted on Nov 20, 2011
  • 413 Answers
DL is a 'Door Lock' error code.
A Door Lock Error occurs if the door cannot be locked. The Central Control Unit (CCU) will try to activate the lock 6 times before displaying the error.
Potential Causes
• Door Lock Mechanism has failed
• Wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
• Central Control Unit (CCU) has failed.
Posted on Jun 23, 2008
I trried to start washer and a code dl came up
dl means there is a problem with the automatic door locking mechanism that engages before the wash cycle is started
Jul 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Flashing a code f dl and won't start the wash cycle? any suggestions?
(800) 659-7026 call this # there was a recall they will fix it free
Apr 29, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My washer won't finish the cycle and is flashing F-2, it also at one point flashed DL, we did finally unplug it several times and got the door unlocked. Thanks
The control unit on these machines is very weak ( cheap). I have similar problems and I continually need to jiggle the plugs that go into the control unit
Jun 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Fdl code message
>"dL" indicates Door Lock Failure: dL flashes if the following conditions occur:
Door lid is not closed completely due to interference.
Wash media buildup is preventing the lock bolt from extending.
Machine/motor control detects open door lid switch when attempting to lock.
Machine/motor control cannot determine if door lock is in a locked state.
Check for lock interference with lid or lock bezel
Jan 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Flashing codes
you have a communication problem between your door lock and your ccu board. Are you hearing a click click click before it fails? If so this is a relay inside your ccu board. Replace the board this will solve your problem
Jan 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The motor does not engage in at all
The F 11 code is a water fill code. Check the water to make sure both lines are on. If their on then turn off take hoses off the water inlet valves in the back and check the screens. If your screens are clean then you probably have a water inlet valve problem. Are you able to open the door to get your clothes out? If not I can tell you how to get it open.
Jan 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error "F DL" cycle won't start
F DL is a door lock failure. The door is not locking so the machine will not start.
Jan 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet HT
its a door lock error a door lock error occurs if the door cannot be locked it will try to lock 6 times before displaying the error
Mar 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
LIGHTS ON WON'T TURN ON DL CODE
http://www.fixya.com/support/t364216-whirlpool_duet_ht_ghw9400pl0
see this fix
Jan 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
1,224 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
