Home | Bissell | 7901-1 ProHeat Scotchgard Upright Wet... | No Water
Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum
Problem for Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum
No Water
By gourmetgadge on Jun 23, 2008
My Bissell rug shampooer does not eject water or saop whan I pull the saop trigger on the handle. I checked both filters and they are clean. Then, I removed the container that sucks up the water and pulled the saop trigger, water barely came out of the tubes. I tried to clean the rug in our family room and the rug was not wet when I finished, no water coming out to clean the rug. HELP HELP HELP!!! I live in Colorado is there a Bissell repair shop near Denver, HELP!!!
Thanks
Dominick
email kwdomsue@q.com
Solution #1
posted on Jul 13, 2008
Not Rated)
reddevil6
Rank: Guru
Rating: 88%, 1757 votes
Does water squirt out of the hose nozzle, if it does, then check the heater inside the handle asm. Make sure that where the tubes hook up to it are not clogged. If water doesn't squirt, check for the seal at the bottom of the tank, it needs to be on the tank, not in the hole, this is for the soap bottle also, there is a seal on the bottom of it as well. The flow indictor cap is leaking air or maybe is too tight. If you had the top cover off, make sure that the tubes are routed right so as not to get pinched when the cover is put back on, the smart mix knob should be in the water setting and that the piston is on the bottom of the smart mix knob. Pump is bad. Try running a mix of vinegar and water to see if that unclogs the lines. Is the top cover and the base tight together in the back, sometimes the top breaks loose and it will raise up and it can't spray, just re-fasten it down.
Bissel's Number is: 1-800-237-7691, they can tell you were to get service in your area.
Was this helpful?
Yes
No
Popular Solutions for Bissell 7901-1 ProHeat
Questions and Unsolved Problems for Bissell 7901-1 ProHeat
Do you recommend Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum?
Answer
Answer
7901 series carpet cleaner sprays but does not **** the water back up. Got it appart right now and... (More)
Answer
Bissell Proheat Plus Model 7901-P won't spray out cleaning solution, but does **** up liquids. What... (More)
Answer
it will not **** the water back up but it the suction is working on the base part below the water... (More)
Answer
it'swork in reverse. The roller spins when it's upright and stop when yo relaease the foot tab. How... (More)
Answer
7901 problem with no spray, pull trigger, but nothing comes out...pull out the bladder container,... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Bissell 7901-1 ProHeat...:
Top Vacuum Experts
Rank: Guru Guru
Solutions: 663
Experience: im jack of all trades but a master of none! and being an old f*rt you get to learn a fair old bit
Ask Me
Find more Vacuum Experts
Top Vacuum Repair
(502) 348-4900
Authorized Dyson and Miele Service center. Work...
VACUUM SOLUTIONS
(877) 822-8227
When you browse our large selection by vacuum...
Vacuum Cleaner Shop
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
