Dell Inspiron 2200 Notebook Logo
Posted on Jun 23, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Toolbar trouble My lower toolbar will not show up. Once I turn the computer on, the toolbar is blocked out...Now i can not see my volume level, signal strength, connection, or battery life. how can I fix this?
Georgia B
Level 3:
Guru:
  • Master 1,342 Answers
  • Posted on Jun 23, 2008
Georgia B
Master
Level 3:
Guru:
Answers
1342
Questions
0
Helped
879442
Points
3834
Move your mouse pointer to the bottom of the screen until it turns into a double sided arrow. Left click and move it up to expose the toolbar.
When i first turn on tv sound is fine . then it will drop down in volume badly .
Many newer types of TVs have what's called "Volume Leveling", which means the TV automatically lowers the volume if a sudden increase in the broadcast signal volume is detected. Check to see If "Volume Leveling" is present on your TV and currently turned "on". Refer to your owners manual for this. It should be in the Audio section in the menu on your TV. Turn the "Volume Leveling" to the "off" position to disable "Volume Leveling".
I am not able to control the recording level on lower right screen. When I click on it nothing happens.
Maybe your laptop has buttons that control the level also, if so press them.
Most laptops have keystrokes that control the volume level. Normally you will have to Press and Hold the FN function key at the lower right portion of your screen and the corresponding key that takes the volume up. Normally the correct key will show the icon of a megaphone with the )))) volume signal.
More importantly make sure you have the Recording checked in the Audio Sound Properties.
Buttkicker Gamer 2 Amplifier won't turn on, light stays orange when it should be green. used to be a struggle sometimes to get it to turn green by using the remote, now it just stays orange all the...
Your Gamer 2 Amp turns on whenever an audio signal is present on the input. The amp can have trouble tuning on if the output of the source (computer sound card, etc.) has been turned down. This can happen easily if you use amplified speakers - if you turn the sound card's volume control down - and then increase the volume at the amplified speaker - the resulting sound is the same; even though the signal has been lowered. The problem is that the output from the sound card isn't sufficient to turn on the Gamer 2 Amp.
Try turning down the external speaker volume, then bump up the sound card volume. You'll probably need to adjust the other inputs individually (Wave, Mic, CD, etc) so that none is too loud or soft. Once the input values have been set, gradually increase the output of the sound card in the control panel application etc. while decreasing the volume on the amplified speaker to maintain a comfortable level. Eventually, you'll find the correct volume level on the sound card output that will wake up the Gamer 2 Amp.
If you're still having trouble, review the manual, here. I hope this helps & good luck!
When I access my routers control panel it shows many users. I want to block them from my signal I have a CD-R King CW-5354, 802.11G I don't know all the techno jargon used in the manual. When I try, my...
scroll to the bottom toolbar (bottom of screen) right click you can select task manager applications also processes you will see whats running on your computer also select users you will see who is using your computer once you see who using select end now
not sure if it will work to block them you could try this
once other parties have access to your connection you will have check your firewall settings click start control panel system and security windows firewall and make sure your firewall is turned on and check the settings so that no unauthorised users can use your internet connection
hope this helps
Cant adjust microphone
Make sure your webcam mic is set as default
XP
Plug in your webcam or headset or mic you wish to use with your webcam
Control Panel (Classic View)
Open 'Sounds and Audio Devices' folder and click on the 'Volume' tab - make sure the speakers are not muted, open 'Speaker volume' and set the sliders toward the upper end.
Open 'Audio' tab - make your preferred mic the default device in the 'Sound recording window'
Open 'Volume' below the window to ensure the mic is not muted
Click 'Apply' and 'OK'
Restart your computer
Configure the webcam / mic to your chat program
VISTA
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
Right click on the volume graph and select 'Show disabled devices' and 'Show disconnected devices'
To set your preferred mic as default - click the mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Plug the webcam and launch the Logitech dashboard ( toolbar )
Open Settings menu ( 2 gear wheel pic )
Adjust mic to suit
I install a gear head web cam but the other person cannot hear me
You do not say what your OS is, if your computer is laptop or desktop or what program you want to chat in
Set up Audio
Laptop x webcam/mic x Vista x Yahoo Messenger
If you have an earlier OS, you may have to access your hardware from the Control Panel.
TEST SPEAKERS
To set required mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click OK
Restart computer
CONFIGURE TO MESSENGER
Open messenger - on top toolbar. Left click ( > ) Messenger > Preferences > Connection - Select 'no proxies' or 'connect direct to the internet' depending on the version of messenger you have
make sure your internet connection and country are correct in the lower two boxes > Apply > OK
Click ( > ) Messenger > Preferences > Calling and Audio
Set mic and speakers to show Default equipment
Run call up assistant to test audio equipment > Apply > OK
Other chat programs are less intensive for audio set up - Skype and MSN can be navigated via the 'Tools' option on the toolbar.
How do u turn the mic. on ?
Set up Audio
If you have an older OS than Vista you may have to access your hardware from the Contol Panel
I have used Yahoo Messenger as an example if you intend to use your mic in WLM or Skype, its a lot easier find 'Tools' and then 'Audio set up'
TEST SPEAKERS
Set required mic as default - click on mic font to highlight and click "Properties"
Restart computer
My microphone isn't working, there's no sound
Sound set up
Laptop x Vista x webcam mic x Yahoo messenger
TEST SPEAKERS
The speaker icon (checked as working) and volume level graph should be visible
Click "Levels" tab and set slider to 100% (adjust to suit later)
Restart computer
2helpful
3answers
Can't turn volume down!
Go into your sound devices from the control panel. You should be able to raise & lower the volume from there as well as putting the volume icon back into your system tray. Hope this helps.
In-computer speakers aren't working.
the speaker would have gone bad.If the external speakers connected are working fine,then the sound card is fine.If the system is still under warranty u should get the speakers replaced.Contact dell tech support for that.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
