Stuck memory card
I stuck my memory stick pro into my computer's card reader without the adapter and now it is stuck. how can I get it out?
  • 426 Answers
Take a credit card and angle the credit card (c.c.) so that when u slide the credit card outward .... the mem chip has a VERY small lip on it thats what you want to try to get the c.c. to catch onto
Posted on Jun 23, 2008
Won t recognize sd card
It seems that the card reader if the computer is not detecting the card. Make sure that the memory card you use is supported.
The multi-in-one card reader on the Aspire One can read and write to Secure Digital card (SD), Secure Digital High Capacity card (SDHC), MultiMediaCard (MMC), Memory Stick (MS), Memory Stick PRO (MS PRO), and xD-Picture Card (xD). Specific models of the Aspire One are also equipped with an SD Expansion slot that can read and write to Secure Digital (SD) and Secure Digital High Capacity card (SDHC) cards.
The multi-in-one card reader on the Aspire One can read and write to miniSD, microSD, Memory Stick Duo,and Memory Stick PRO Duo cards but require the use an adapter. Acer does not provide or support any memory card adapters.
You can try removing the card reader using the device manager and the reinstall it and check the operation. You may also try using the card is different computer and check. Also try using another card in the computer with the issue and check. If the issue is not resolved please revert back with the model number.
Click on the link for the information to Reinstall a Device
http://technet.microsoft.com/en-us/library/cc725782.aspx
Nov 14, 2013 | Acer Aspire Computers & Internet
My Sony Vaio Laptop computer doesn't acknowledge when I insert the Sony Memory Stick Pro duo with the correct adapter in the slot. I used to be able to used this on my laptop; what happened? I can still...
regarding with the issue that you are having with your sony vaio card reader here are some things you can do
- try to perform a system restore and try to restore the computer to a date that the computer is working fine
- try to reinstall the driver for the memory stick pro card reader
- the website for the driver is www.esupport.sony.com
- as far as i understand your issue you are using the card reader port for the memory stick pro
Dec 12, 2010 | Sony 2GB Memory Stick PRO Duo Memory Card
I put memory card into a card reader and it got stuck and now memory card doesnt work
1. You have removed the memory card forcefully from the card reader, that's why it not working!
2. Does the card reader detects your memory card (even if it's not working)?
3. Check your memory card with a digital camera / card adapter!
please rate this advice if it helps...tc! :)
Jan 13, 2010 | Sony 2GB Memory Stick PRO Duo Memory Card
Do you need an adapter 4 a memory stick pro duo in a 5 in 1 read
No, just insert the Memory Card in the 5-in-1 Card Reader slot. The Memory Card will appear on the "My Computer" or "Computer" window. Click on that to open the contents of the Memory Card.
Good Luck!!!!!!
Nov 30, 2009 | Acer Aspire 5610-4648 Notebook
How to use the memory card reader
To access the memory card reader without using the software provided, follow the steps below. If no card is inserted, the green light on the card reader will be on.
Insert a memory card.
• Insert the card with the brand name label facing up.
• If there is an arrow on the card, make sure it points toward the printer.
• If needed, make sure you connect the memory card to the adapter that came with it before inserting it into
the slot.
Wait for the light located to the right of the slots on the printer to come on. The light blinks to indicate the memory
card is being read or is transmitting data.
• The printer recognizes one memory card at a time. If you insert more than one memory card, a message appears
on the display prompting you to remove all memory cards inserted.
• If a USB flash drive is inserted together with the memory card, a message appears on the display prompting you
to choose which memory device to use.
When reading of images is complete, the number of photos found appears on the display. Then you can make your selection and print. these are the types of memory card supported by you printer.
xD-Picture Card
• Secure Digital (SD)
• Secure Digital High Capacity (SDHC)
• Mini Secure Digital (with adapter)
• Micro Secure Digital (with adapter)
• MultiMedia Card (MMC)
• Reduced Size MultiMedia Card (with adapter)
• MultiMedia Card mobile (with adapter)
• Memory Stick (MS)
• Memory Stick PRO
• Memory Stick Duo (with adapter) or Memory Stick Duo PRO (with adapter)
Mar 18, 2009 | Lexmark X5495 All-in-One &USB...
I have a memory Stick PRO Duo 4GB
YEAH, YOU MAY NEED A MEMORY CARD READER to read your memory stick. because some compters have not all type of card slots. the card reader will solve your problem.
Feb 10, 2009 | Sony 4GB Memory Stick PRO Duo Memory Card
Memory stick card reader won't read
have you installed the driver for the 5-in-1 card reader?
check hp for your model.
Jan 23, 2009 | Sony 1GB Memory Stick PRO Duo Memory Card
Stick Micro M2 Memory Card
Don't know the size of the micro with its adapter, but if it is the size of a duo card you should be able to put your micro with adapter into a Pro adapter and this is the memory stick that most card readers accept. Sony has been pretty much backward compatible so I feel this should work. A Pro adapter runs about $10 @ Best Buy.
Jan 12, 2009 | SanDisk 2GB Memory Stick Micro M2 Memory...
Ejecting Memory Stick Pro Duo card out of notebook card reader
Hi, the memory Stick Pro Duo card is (micro), half size as you have noticed you need to buy an SD adapter card. You put your Pro Duo card into the SD card & than put it into your card reader.
Once you see the SD adapter card on the web site you'll understand. You can buy this at a local BestBuy. Most web sites sell the adapter as a combo, you'll get a micro card & adapter.
Click the link below.
http://www.google.com/products?hl=en&q=Stick+Pro+Duo+adapter+only&um=1&ie=UTF-8
Look at SanDisk 2GB Ultra II Memory Stick PRO Duo w/Adapter
& you will understand.
Have more questions? Just ask.
Good Luck & Have a Great Day!
Mar 21, 2008 | Computers & Internet
Just got an ACER Aspire AS5720Z notebook. It has a 5-in-1 card reader. I have a memory Stick Pro Duo card that is extremely small. The manual says the card reader will read it. There is NO eject button...
Computers & Internet Logo
299 people viewed this question
David Payne
David Payne
