Question about Whirlpool AD40USR Dehumidifier
Humidifier does nto turn on.
Dehumidifier does not turn on.
    Novelist:
  • 121 Answers
It sounds like the Dehumidifier has a problem somewhere on the circuit board. You could try and find a local humidifier repair shop in your area otherwise it may be cheaper to purchase a new replacement instead of having it fixed. Good luck.
Tech - 101
Posted on Jun 24, 2008
Our Friedrich D50C humidifier is six years old. Worked great until a week ago it seems to turn on- then an unordinary noise occurs and moisture is not pulled out.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Sep 04, 2011 | Friedrich D50C Dehumidifier
When my dehumidifier is on, it says there is 90 humidity. I come back an hour later, it is still running and no water in the bucket.
If there's no water in the reservoir, first make sure that water is getting to the humidifier. The humidifier must have a good stream of water available to it. If there's water in the water line but the reservoir doesn't fill, replace the float mechanism inside the humidifier.
Take care.
Jul 29, 2010 | Haier 45-Pint Dehumidifier
Humidifier is icing up during operation
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
vbn
May 20, 2010 | LG LHD45EL Dehumidifier
Humidifier just not working!
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
May 04, 2010 | Goldstar DH304 Dehumidifier
Start up instruction for dehumidifier
A dehumidifier does not need water in the tank.It takes humidity out of the air and the moisture goes into the bucket. A humidifier has to have water in the tank.Note ,a humidifier puts moisture in the air, and a dehumidifier takes the moisture takes moisture out of the air.
Feb 16, 2010 | Kenmore 54501 Dehumidifier
It turns on but won't start,do I need to fill tank w/water?
If it's on humidifier, It has to have water. Dehumidify, no
Nov 19, 2009 | Haier HDN655E 65 Pint Dehumidifier...
My de humidifier won't turn on
My dehumidifier just stopped running. Plug it in and nothing happens.
Sep 23, 2009 | Haier HD656E Dehumidifier
Adjusting dehumidifier on furnace
This model furnace does not come with a built in humidifier. Humidifiers are normally an optional add on. If you have a by-pass type humidifier it is none adjustable. Water level is normally float controlled and operation is control by blower circuit. When ever the blower runs the humidifier operates when in the heating mode.
Jan 24, 2008 | Dehumidifiers
Maytag M7DH45B2A freezing problem
Is this a humidifier or dehumidifier?
Nov 15, 2007 | Maytag M7DH45B2A Dehumidifier
Humidifier Runs but no water collected
Are you talking about a dehumidifier or a humidifier. If you are talking about a dehumidifier, it works by blowing air across a cooling coil causing condensation and the water will drip and pool. The cooling is caused by a compressor working like refrigerator, but using the effect to dehumidify. To check if the cooling coil is working there will be a metal can like in it with tubes in and out. One of the tubes should be warm(input) and the other tube should be cold, if not your compressor is not working. If freezing up, low freon. Check to see if the compressor shuts off very quickly, that would be too much freon. This is not user servicable. Now a humidifier works several different ways. One way is a fan with cloth belts rolling through water using evaporation to humidify. Another way is for a circular fan like on a motor to turn. It has a hollow piece into the water. It picks up water and then through centrifugal force aerates. One way is for a sonic humidifier. All the types have a problem with eventual calcification or mineral build up in the water handling paths. Lime-away or Concentrated Lemon Juice will dissolve this. The lemon juice is the most fun. It will turn your toilet bowl white and also remove rust stains from laundry...
May 01, 2007 | Maytag M7DH65B2A Dehumidifier
Whirlpool AD40USR Dehumidifier Logo
181 people viewed this question
Top Whirlpool Dehumidifiers Experts
Bill Long
Mike
Mike Squire
Are you a Whirlpool Dehumidifier Expert? Answer questions, earn points and help others
