Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Door will only close when held down
Got the Chamberlain Professional garage door opener model 41BD002-2 & have to hold down button to close it until it goes all the way down. Tried moving sensor with orange light & it still won't change. Any other suggestions? I HAVE AN OLDER SEARS CRAFTSMAN GARAGE DOOR OPENER AND I'M HAVING A SIMILAR PROBLEM. THE REMOTE WILL NOT ACTIVATE THE GARAGE DOOR (ALTHOUGH THE LITE COMES ON AND THE OPENER WILL MAKE A CLICK. HOWEVER IF I USE THE WALL MOUNTED OPENER INSIDE THE GARAGE, IT WILL OPEN IF YOU HOLD THE BUTTON IN. WITH ALL OF THIS, ONCE IT IS CLOSED IT WILL OPEN IF YOU PUSH THE BUTTON ON THE WALL. HELP!!!!!
PLEASE AND THANK YOU
  • 2 more comments
  • Anonymous Mar 12, 2014
    The little sensor on plastic screw does not move anymore to the stoppers after the door had a shock trying to close while there was a 3ft piece of wood left on the side of the door. Can we change only this part? It is where the screws for up and down adj. are. It is easily removable with 3 little plug in wires.Thank you.Linda
  • Anonymous Mar 17, 2014
    I have a problem with my Sears garage door opener. The motor wants to continue to cycle when the door has been opened or closed. Also the inside unit that has 2 buttons that you push at the same time to get the door open and closed isn't working right. You used to only have to push them to start the door opening, now you have to push and hold them to get the door to go up or down. This started when my kids tried to force the door open during a power outage. I have tried to adjust the limit switches with little success. Any suggestion would be appreciated!
  • Anonymous Mar 30, 2014
    Garage door will not close or open. The censor light on the left is yellow the one one the right is green. I have tried to find this problem in the Manuel with one luck
  • Anonymous Mar 31, 2014
    trying to install a garage door opener and it only goes up not down
    Scholar:
  • 91 Answers
That normally happens when the sensors aren't aligned. Both sensors have led lights on them the yellow/orange one will stay on all the time the green one will go out if it cant see the other sensor. Possibly theres a wire that's broken or the other sensor is really out of alignment. Check every inch of wiring from the sensor to the opener, remove wire nuts if present and check the connections. The wires that are used are small, solid and can break easily. Also see if there's a staple that's too tight, move the wire abit where it's stapled and look for damage.
Posted on Jun 27, 2008
  • Barry Nov 22, 2011
    I had the same problem and found only the sensor with orange light was on. The green light was off. Found the wire from the green light sensor had a bad contact at the pinch connector on the back of the unit. Removed and reinserted the wires and all is well.
    Master:
  • 966 Answers
Have similar problem. I just checked the wiring and removed some cobwebs and oiled the chain. The handheld worked fine. I still have to put this baby thru some more tests. Will update. Goodluck!
Posted on Jul 03, 2013
Garage door wont go down when wheather is cold
Posted on Jan 04, 2009
Found and repaired broken wire in sensor light circuit. Now works as intended.
My Chamberlain 41A5389-1B 1/2HP door opener will only close via the wall push button when it is held down until door is fully closed. Will not close with remote, when using the remote it will start to...
Have you checked the tracks on both sides? If the door closes when you hold the wall button there may be an obstruction or a bad guide. This could exert enough resistance to make it stop and reverse. Holding the wall button allows it to keep going past the problem.
Apr 28, 2017 | Sears Craftsman LiftMaster Chamberlain...
My garage door opener opens with remote but will not close with remote. will open with wall button but button must be held down until door touches floor to close
Check the door sensors. Make sure they are pointed at one another and the small light on each one is lit and not flickering. Tweak them a bit. If you cannot get both lights to come on you have a bad sensor.
Nov 05, 2010 | Sears Craftsman LiftMaster Chamberlain...
Wall mount button LED is flashing, remotes won't work, door won't close unless the wall mount button is held down until the door is fully closed
Sounds like you have a couple problems. First of all press and hold the button on the wall control that has a lock icon for 3 seconds and release. This should take care of the flashing LED and the remotes will now work. Having to hold the button on the wall control until the door is closed is usually a problem with the door sensors. Make sure they are pointed at one another and the small light on each is lit and not flickering.
Nov 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener
it works but it is annoying: you will have to hold down the button on wired wall unit. hold it until the door closes. also if you have the keypad outside it also works the same way, type code and hold the enter button
Dec 28, 2008 | Sears Craftsman LiftMaster Chamberlain...
sounds like the gear drive is getting worn.
also make sure the track are free of any debris.
Aug 17, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Sears craftsman garage door opener
HOLDING DOWN THE WALL BUTTON OVERRIDES THE SAFETY EYES.
WHEN HOLDING IT DOWN MAKES THE DOOR CLOSE PROPERLY THE PROBLEM IS IN THE SAFETY EYES.
ARE BOTH LEDS ON? - CHECK FOR A LOOSE OR BROKEN WIRE.
ARE THE EYES WIRED CORRECTLY?
ARE THEY AIMED AT EACH OTHER?
Jul 13, 2008 | Sears Craftsman LiftMaster Chamberlain...
if you obstruct the photo eye does the light flash ?
Jun 13, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
1,899 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
