My western digital 500gb hard disk light is not on. It was working so fine. I'm not able to understand the problem
hi
i have the same unit ..eventually if the unit is not unplugged and plugged in in sequence as i describe here, the power module will be expended.
when disconnecting , you have to unplug AFTER you (via software, S/W) disconnect from the ICON found at the bottom right corner of the computer screen , After disconnecting via s/w, unplug the USB cable, then the power cord.
when reconnecting, plug in the power cord, wait 30 seconds, then plug the USB cable in .
this should alleviate the issue at hand. if the unit does not function, then the power module inside the hard disk drive housing is no longer working
i hope this helps
send me 4 thumbs up please.
