Question about Frigidaire Dryers
Dryer popped circutbreaker and started on fire inside dryer filled with smoke
  • 525 Answers
How did the fire dept. classify it, and who did they recommend you to contact?
1. An electrical fire....electrician
2, A lint fire....Qualified service technician
3. A clothes fire...Your user's manual
You have experienced a major anomaly and this would require a thorough inspection by a qualified technician with a degree in thermal dynamics, or you could just buy a new dryer.
You need to find out if the fire started, then tripped the breaker, or did the fire start because the breaker failed to trip in time? Regardless, a dryer is usually junk after a fire. The drum would generally have soot in it and rubber or felt seals would have some permanent odor. Internal wiring and other components fail because they are not built to withstand high temperatures.
I am very concerned to know why your breaker did not trip in time to prevent a fire. Please make sure you have an answer to this question before you hookup another dryer, and maybe I will get some sleep. Here's to your safety!
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 23, 2008
My hotpoint tumble dryer almost caught on fire the house was full of smoke can l claim
Only if you can prove that the fire/smoke was caused by a machine defect and not a lack of cleaning the unit out once in awhile.
Jun 20, 2016 | Hotpoint Dryers
My lg dryer 2301 started a lint fire which set off the smoke alarm.
Your vent is clogged somewhere along the way, causing "blowback" into your dryer which builds up lint inside the cabinet and causes fires.
You need to clean out your dryer vent.
Oct 19, 2014 | Dryers
Whirlpool Gold Ultimate Care II Gas Dryer takes to long to dry
sounds like ur t-stat is bad or maybe a thermal fuse. hard to say w-out diagnosing in hands on.
Jul 25, 2013 | Dryers
Dryer smoking up house and threw exhaust vent smells like something burnt
Hello, Well the smell is most likely from lint that is trapped in the dryer burning. The first thing you need to do is check the lint screen just inside the door. Second is to take the vent tube off of the back of the dryer and check to see if it is plugged with lint inside of the dryer. Clean out any you can see, also if the tubing inside of the dryer is most likely plugged with lint and the heating element is catching the lint on fire. If let go without cleaning this will cause a fire! I work for an appliance repair company and have seen dryers catch fire due to them being clogged with lint, you have two options; first is to clean it yourself, second is to have an appliance repair technician come to your home and clean it. The second is easier and safer but the first is cheaper but very labor intensive. I hope that answered your question and helped. Good luck!
Dec 09, 2010 | Kenmore Elite HE4 Electric Dryer
As describe earlier, my dryer started smoking, and maing a burning smell from behind the drum. There is no evidence of lint buildup in the exhaust, and the dryer still starts smelling as if it is on fire...
i just had this problem. Did you notice the lint buildup under the lint drawer? Well, there is no way to recover that lint, it is not accessible by the consumer. So the lint bits get sucked in to the out take which actually pulls across the hot element. The "solution" is to replace the element and the parts surrounding. It is very expensive, and does not resolve the issue. The lint will continue to be drawn across to that area and build up and become a fire hazard. I am about to try Bosch for a solution, but that is what they have told me for now. Eventually this make/model of dryer will burn someone's house down. I am very glad I was home when the smoke detector went off. I will have to get a new dryer.
Aug 04, 2010 | Bosch Nexxt WTMC3321US Electric Dryer
Dryer won't turn on after circuit breaker kicked out and the light bulb inside the dryer shattered.
Im going out on a limb here and say ... the breaker popped - your light exploded ... it will not start. You took a big surge hit and probably smoked the timer.
Unplug the machine - remove the back or the top to gain access to the wiring. With your volt/ohm meter start checking contunity particularly with the timer. The timer is only a switch, you know this right? When you are satisfied with your contunity checks, plug it in and scheck for voltages.
Good luck
Oct 12, 2009 | Whirlpool ET8CHEXSQ Dryer
When drying the dryer seems to smoke and coils get red. how can i fix that problem?
Check your cycling thermostat. Sounds like it's cycling on the high limit rather then the thermostat. While inside the unit, clean the lint out of the whole thing. Smoke is not a good thing. Where there is smoke, fire isn't far behind. Good luck!
Please rate solution.
Jun 15, 2009 | Whirlpool WED8300S Dryer
Dryersmells smokey/hot.
Lint buildup inside the unit can cause all kinds of problems. Have it taken apart for a good cleaning and inspection. A dryer fire is no fun.
Apr 07, 2009 | Bosch Nexxt WTMC 3300 Electric Dryer
Dryers Logo
96 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
