The wireless keeps saying disabled.. it wont connect and it cant find the available networks.. there is no problem with the network cos it works fine on the ohter computers/laptops in the house and generally whereever i go it wont pick up the wireless networks.. i tried to enable it but it wont work.. when i turn the switch on the bluetooth turns on but not the wireless.. i tried to even reinstall the drives again but it still didnt work.. i even followed the instruction in the trouble shooting section and that still did nothing.. i got a few IT friends to try and figure out what is wrong with it.. one said either the switch doesnt work properly or basically hardware problem with the wireless.. the laptop is HP dv2000 range, special edition..
    Scholar:
  • 141 Answers
Hi sayeh,
I don't know if some of your IT friends had check the Wireless Zero COnfiguration,lets check it out.
start>run> type in services.msc
scroll down to Wireless Zero Configuration
check the status,
right click on it and click either start/restart
hope it helps
Posted on Jun 23, 2008
I have the samsung t528g and i cant get on the internet or facebook or email. or wifi... It says servie not available or it will look like it is connecting for like 2 seconds and then say disconnectin
I had a similar problem, my mobile network was disabled. I went to Settings >wireless &networks >mobile network>data enabled make sure it's checked.
Jan 05, 2013 | straighttalk.com
My ds lite cant connect to my netgear WGR614because it says its security settings are not supported by the ds
Hi eporre1,
If you're receiving that error message we need to access the Wireless Settings Page of your Router to change some settings. Keep in mind that if we change the settings of your wireless connection other machine that is connected to the network will be disconnected due to the new settings, so take note of the settings that we will be changing.
To access your router you need to use a computer that is connected to it. Open a Browser then type 192.168.0.1 or http://routerlogin.net. The Default username is admin and the password is password. Password is case sensitive.
Go to the Wireless Settings Page try changing the encryprion to WEP 64bit and generate a Network Key. Remember the network key so that if you have laptops that are connected and will lose the connection that is the password that you need to input. If WEP 64bit wont work try WEP 128bit or WPA you can also disable the Security however you network can be access by others.
Now that we already know the setting of the router then its now time to connect the Dsi to the network.
1. Go to Nintendo Wi-Fi Connection Settings of the Game
2. Search for an Access Point (SSID)
3. Select your Network (SSID), If you have an open network, just click "OK" and it should work just fine! If it's a Red Padlock, it'll prompt you for a Password or Network Key. This is the reson why we access the router.
4. Test the Connection. If you have questions put a comment here.
Rate me if this helps so I can hep others. Thanks for using Fixya.
Feb 04, 2011 | NetGear WGR614 Wireless Router
I want to use my d-link router with my new acer laptop but cant connect to the router. Windows says it is a router connection problem. It can locate the router just wont allow me to connect.
1.In Control Panel, click Network and Internet Connections, and then click Network Connections.
2.Right-click the Wireless Network Connection, and then click Properties.
3.On the Wireless Networks tab click Add.
4.In the Wireless network properties dialog box, enter the SSID "(Name of the connection) ex. dlink1234" you configured for your wireless gateway
5.Fill in the rest of the fields, including the necessary authentication and encryption information based on the configuration of your wireless gateway. (WPA-TSK, WPA2-TSK, WPA-AES and WPA2-AES)
6.Click OK and your home network will be added to the list of preferred networks.
if you have a firewall in your laptop try to disable it. example Eset Security antivirus Firewall. Disable the Firewall.
Aug 25, 2010 | D-Link (DI-784) Wireless Router
Cant get wireless router to work on laptop
First, try to connect your laptop hardwired to the router, if it works fine, its just the wireless configuration. Make sure you are using the correct wireless network key to connect to your wireless network. Go to the Control Panel > Network Connections > Right-click Wireless Network Connection > Properties > Wireless Networks Tab and delete all the names listed under Preferred Networks box. Click Ok. Right-click on Wireless Network Connection again > View Available Wireless Network > Choose your own network and click Connect. If it asks you to type the network key, type in your WEP or Wireless Network Key and press connect. That should do it.
Oct 06, 2009 | Computers & Internet
Wifi disable
If you can see the available Wifi signals in your area then the wireless is turned on and working fine. you need an encryption key and to configure it or have it auto detect to connect to them.
Unless they are open connections with no encryption/security.
Do you have your own wireless network or are you trying to get on some one elses?
You will need your encryption to get on.
Select you connection from the list, click connect and it should prompt for a key code. enter it and it should do the rest.
Feb 03, 2009 | IPC -400
I need to turn my wirless internetnet option on and cant for my IBM thinkpad thanks
mostly the button is found on the left float side of your laptop 'IBM'. with two icons of a computer. please make sure that the button is on the side of the icon that shows a computer with weaves. so that your able to check the wireless access points you have in your range.
Wireless Connection:
Start > Control Panel > network connection>
Show network connections. If there is an X on wireless connection then connection is disabling and if no X then connection is enable.
make sure its enabled.
Right click on wireless network connection and click view available wireless networks.
You should see a list of available wireless networks
Then select the wireless network that you need to work on and click connect.
An icon in the lower right hand corner of your laptop should eventually appear stating that you are connected.
Then this will show you your wireless connection.
Excellent you connect to your wireless network.
Dec 15, 2008 | IBM ThinkPad T40 2373 Notebook
D-Link Airplus G DWL-G510 dose not start up
0) You must log as Administrator to enable your device
1) Check if the adapter has been installed
(My computer-->>Right click --Properties--->>Hardware--->>Device Manager---->>Network
2) You have to set the wireless connection
To set one do this:
Connecting XP
Click your Start Button
Select and click Control Panel
Select Network Connections
Select Wireless Network Connections
Right click
Select View Available Wireless Networks
5. Highlight the network you want to connect to
Click Advanced
6. Select the wireless network tab
7. Highlight the network in the available networks window
9. Click configure
9. IN the Properties Window
Double check the SSID (network name)
Enter the WEP KEY provided to you by the office
Click OK
Nov 12, 2008 | D-Link AirPlus G DWL-G510 802.11g/b...
Wireless router, laptop problems
Try to delete all the prefered networks. Right-Click Wireless Network Connection, View Available Wireless Networks. Click on Change the Order of Prefered Networks. Remove all prefered networks there and click OK. Now try to View the available wireless networks again, reconnect to your own wireless network and see if it connects fine. Post your feedback.
Jul 12, 2008 | Linksys Wireless-G WRT54G Router
My laptop cant find the card
is your card connected proper if so l would say its faulty now
Mar 03, 2008 | Intel PRO/Wireless 2100 MiniPCI 802.11b
Computers & Internet Logo
105 people viewed this question
David Payne
David Payne
