Question about Amana Washing Machines
My washer will noe stop filling up after going into the wash cycle. I have to turn the water off.
  • 413 Answers
The water inlet valve has stuck on. The valve will have to be replaced.
Posted on Jun 23, 2008
Cold water won't stop before rinse cycle
if it fails to stop running only at the rinse part of the cycle it is probably in the timer as the solenoid valve has to cut the water off when the washer fills for the wash cycle too. fills for wash cycle and cuts off water, washes and drains, refills for rinse cycle and water just keeps running? does this every time you run it? that's in the timer. bad solenoid (water inlet valve) would keep running even on wash fill up. hope this helps.
Feb 25, 2014 | LG WM2688H Front Load Washer
Hi...my washer goes through cycles and then stops at "light" . It won't go through rinse and spin. Help
Make sure your cold water tape is turned on and the screen in the water valve is not plugged up, it may be trying to fill with cold water and cant get any, try filling the washer with cold water on a "wash" cycle to confirm it it fills with "cold" then just the rince cycle ion the timer may be faulty and would need to be replaced
Aug 25, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
When my washer goes to fill on the rise cycle It just trinkels. I have to turn back to wash fill & then go back again
Your cold water valve is stopped up with sediment. Turn off the cold water. Unscrew the hose from the cold water side on the washer. Clean out the sediment screen in the washer water valve.
Nov 01, 2009 | GE Washing Machines
Kenmore washer won't stop filling during initial wash cycle
I had the same problem too on one of my washers (not kenmore) it didn't complete cycle because someone turned off the hot water valve. soo i turned on the hot water and it worked fine. keep in mind that mine wasn't a kenmore. hope this helps some...
Oct 08, 2009 | Kenmore 24032\24036 Top Load Washer
My maytag neptune washer stop washing with 10 minutes left to go.
If your machine is a FAV6800AWW or FAV9800AWW the (upside down u and f) may be a “NF” for no fill error. The washer has tried to fill the machine with water and has sensed a water fill issue. The control board has shut the wash cycle down with an “NF” error to the display because of excess time to complete the water fill portion of the wash cycle.
Will the machine complete the cycle with Hot water only or Cold water only? I would do a Quick Wash cycle just to test with an empty wash basket.
Regardless of the above test and assuming you have good water pressure for both Hot and Cold supplies to the washer I would do the following. Close the water source valves to the washer and remove the Hot and Cold hose connections at the back of the machine and check for clogged inlet screens. If the water inlet screens are free of restrictions I would go into Service Mode and turn on the Hot and Cold water valves on one at a time and make sure the tub will fill with about 2 inches of water in about 3 minutes in service mode. Check both Hot and Cold inlet valves individually see page 16 of the SM Board Output Test, enter service mode and do the function test for both Hot and Cold Water Valve’s. If the inlet screens are clean and you have water fill restrictions in service mode we may need to look at replacing the water inlet valve assembly. You can turn on the drain pump in service mode to empty the tub or just start a wash cycle and the machine will empty the tub.
The Service Manual for reference. Sears Parts Direct for reference.
May 11, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Cold water will not stop filling during rinse
while the unit is filling in the warm cycle. reach behind and shut off the hot water tap.I bet the water flow stops filling, if so, you would need to change the inlet valve on the machine. You see, in warm, if the cold is not filling, you still hear the hot filling and the unit will advance. The rinse cycles are mostly "cold" only. if the valve is not opening it will not allow it to advance from the rinse section on the board.
Feb 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
23 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
