Question about Sony KP-46WT510 46" Rear Projection HDTV
Problem with my colors on Sony KP-46wt510
My blue color is off on the side of our tv, the center of the screen is fine just bouth the sides of blue are off
  • Sony Master
  • 8,617 Answers
Sounds like the convergence ICs are giving out its a fairly commom problem with all projection TVs. Your model uses two STK392-560 ICs but I would suggest getting a couple of the 4.7 ohm 1/2 watt convergence resistors as most times one or two of them are open as well.You can get new replacement ICs and resistors at the following link and they provide free instalation instructions with pictures so you can do the repair yourself. Here's the link.
http://servicemanuals.vstore.ca/
Posted on Jun 23, 2008
Our Sony KP-46WT510 rear projection screen TV just
Convergence ICs, they are big black ICs will have part# on them if they are STK392-110s use 180s better ICs also CK pico fuses in front and behind ICs
they will look like resistors but will be Yellow or Green 5amps/6amp fuses
Mar 18, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Left side of screen has the color seperated. Sony model #KP-46wt510
take a magnet(speaker magnet) take it near colored region .just wave it near,,, & far when color patch goes take the magnet away. if color patch returns after some days..u have to replace a part inside ur tv called p.t.c
Mar 11, 2010 | Televison & Video
I have a red shadow in 3d on sony KP-46WT510 TV.
Ur convergence is dead.Problems:Are 3D colors,colors misaligns,and colors out of focus.Know how to solders?Must change 2 convergence ICS,and some or all the resistors.Tries Websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300 for parts and labors.
Feb 17, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Yellow and blue on the screen and corners are off center
Your TV may have a bad light engine. There are color LCDs in the engine that may have melted over time. The LCD chips would need to be replaced, or the whole engine would need to be replaced. There was a nation-wide repair for Sonys experiencing this problem, so check around with different TV repair shops in your area.
Feb 04, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
The tv picture looks like should be wachting it whith 3d glasse
This is a very common failure on Projection TV sets. Its called a convergence failure. Here are some common symptoms.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
The other common problem is cloudy lens fluid. After many years the coolant in the blue and green lens will become cloudy and cause the screen to look dull, red/orange, bright white, etc. You may even see halos around objects on the screen.
You can see some example photos and find a solution here on Fixya.
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 15, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Sony projection tv convergence problem
You need to replace the convergance IC's and a pico fuse on the power supply
Sep 03, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Colors appear to be bleeding out to the side.
have you tried the blue convergence adjustment via menu
Aug 25, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
SONY TV MODEL # KP-65WV700 SER.# 9002706
Blue Gun is right side of TV if you look in TV from back side. Part number is as follows..
8-733-663-25 {CRT 07MVC62(B)-L} [KP-65WV700 ONLY]
Mar 13, 2009 | Sony Televison & Video
BLUE TINT ON SCREEN ALL THE TIME, COLOR ADJUSTMENTS FINE
Sounds like a bad blue CRT (picture tube) ITs expensive and difficult to replace. CAll a Sony service center for an estimate. but expect to spend $500-700 to replace it.
michtech
Feb 18, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Blurry on one side of screen. Green and purple shadows
Convergence IC's should be replaced before any alignment is
attempted ....part # STK392-560....You need two......mount
to large heatsink...............T.
Oct 31, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
Sony KP-46WT510 46" Rear Projection HDTV Logo
50 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
