Question about Whirlpool Duet GHW9150P Front Load Washer
Washing machine i am getting f21 error on my washer can you help it also says sd
  • 413 Answers
Make sure you are using HE soap, regular soap will produce sudsing issues in front loading machines.
F21 indicates a clogged pump or a long drain. Since you are also getting a SD error indicating a sudsing issue, the water level switch (pressure switch) may have failed. If you would like to make sure the pump is not clogged, you can clean/inspect the pump filter;
  • Remove the bottom access panel (three screws along the bottom).
  • There you will find access to the pump clean-out. (Large,white screw cap)
  • BE PREPARED TO CATCH SOME WATER.
  • CAREFULLY AND SLOWLY unscrew the pump clean-out, catching and discarding the water.
  • When the water flow finally stops, completely remove the clean-out filter.
  • Inspect the clean-out filter, the drain hose from the tub as well as inside the pump impeller for any additional debris
Posted on Jun 23, 2008
2 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: Washed a rug. Error code F21 came up when washer
"F21" is a Long Drain error code. This indicates that you have an obstruction in the drainage system. In most cases, this means you probably have a clog in the drain pump. The following link explains:
http://www.fixya.com/support/r1484065-f21_error_code_whirlpool_duet_kenmore
Rugs are notorious for losing fiber and holding loads of dirt. You may have something getting caught in the pump impeller and slowing it down. Included is a follow-on link that explains how to check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris can commonly clog in this area as well causing the drain cycle to fail.
If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced.
NOTE: The "SUDS" error can also commonly occur with the F21 error code as this is usually generated when air is sensed in the drainage system.
Posted on Oct 15, 2009
I have a maytag 5000 series washer. We are getting an f21 error code. I unscrewed the white drain filter and cleared it. There was little in it. I keep getting the f21 error though. Can you help?
Search Results
    whirpool f21 error code - YouTube
    ? 3:04
    https://www.youtube.com/watch?v=b24PVv-ORqg
    Jul 1, 2012 - Uploaded by davidmontabon
    whirpool f21 error code. ... Maytag , Whirlpool Washer Repair - Drain pump error, no drain - F9E1- MHWE201YW00 - Duration: 4:29.
    My maytag 5000 series steam washer stopped and said Sud ...
    www.fixya.com/support/t8682656-maytag_5000_series_steam
    Mar 17, 2011 - my maytag 5000 series steam washer stopped and said Sud and now says ... Clicking this will make more experts see the question and we will .... I bought aMaytag 3000 seris in 2008 and I am getting these messages: F21 ... Maytag 5000 Series washer F21 error code was flashing and door will not open.
    Whirlpool/Kenmore/Maytag & more-F02/F21 & Sd error codes
    fixedappliance.blogspot.com/.../whirlpoolkenmoremaytag-more-f02f21-...
Feb 09, 2016 | Maytag Washing Machines
F21 is flashing,... what is this
If the drain time exceeds 8 minutes the water valves turn off.
NOTES:After 4 minutes the "Sd" error will be displayed, then
4 minutes later the "F/21" error code will be displayed. Press
PAUSE/CANCEL two times to clear the display.
F21 washer drain time exceeded
Possible Causes/Procedure
1. Check the drain hose and make sure it is not plugged or
kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure
the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Feb 04, 2011 | Whirlpool Duet GHW9150P Front Load Washer
What does F21 mean on the digital screen?
Hi
Error F21 means F21 error means that the drain time has exceeded 8 minutes; this will turn off the water valves. Error code SD means LONG DRAIN. This error appears when the drain time exceeds 8 minutes and the water valves turn off. After 4 minutes the "Sd" error will be displayed, and then 4 minutes later the F21 error code will be displayed. Press PAUSE/CANCEL two times to clear the display. Please Check the drain hose and make sure it is not plugged or kinked. If the drain hose if fine then unplug the washer and check the electrical connections at the pump and make sure the pump is running. Check the drain pump filter for foreign objects. To access the drain pump and filter remove the front kick panel and trace the drain hose to the bottom of the washer, drain pump would be located there. If you are not able to access it, then replace the back panel as well. Plug in washer or reconnect power. If the issue is still not resolved then you would need to replace the drain pump.
Hope this helps... Please post back if you need more information.
Daniel
Jan 01, 2011 | Kenmore Elite 45986 Front Load Washer
Keeps on coding F21 - we have adjusted the hose several times but still seems to be giving us problems
Hi
Daniel
Jan 01, 2011 | Kenmore HE2 Plus Front Load Washer
F21 on Whirlpool front load duet washer
"F21" is a Long Drain error code. The following link explains:
In most cases this is simply caused by a clogged drain pump and all that is required is a good cleaning. Read through the instructions provided in the link on how to do this. Make sure the washer is unplugged while servicing any of the internal components.
If the problem persists, you may have a drain pump that is malfunctioning or is damaged. The manufacturer recommends replacing the pump if this is the case.
Let me know if you have any questions. I hope this helps you.
Jun 12, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
F21 error code on a Kenmore HE2 front load washer
Unscrew the pump, there is probably objects in the pump, I get that error every month or so, I find coins in my pump all the time, if too much stuff gets in there the code F21 or sometimes SD comes up.
Jul 24, 2008 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
97 people viewed this question
Dan Webster
Dan Webster
Sal De
