I installed nero 8 on my xp pc as a trial, i uninstalled the program via add/remove programs - the problem i have now is my pc wont shut down completely and wont reboot, when rebooting or shutting down it displays "saving your settings" dialog then "windows is shutting down" dialog then remains on a blue screen and nothing else, i have to manually switch the power off. any help on fixing this problem will be appreciated
  • 2 more comments
  • pcdown Jun 23, 2008
    hi johnyu
    pc boots up fine, it just wont shut down completely!
    i select start/shut down/restart it goes through the normal shut down or restart sequence as follows -
    saving your setting
    once that last dialog dissapears it just reamins on a blank blue screen, the pc is still running
    hi johnyu
    i booted into safe mode, i then selected restart and the pc restarted like it used to, i then booted into safe mode again and then selected shut down and the pc shut down nicely.
  • james yu
    james yu May 11, 2010
    Hi PCDown,
    What operating system are you using? Is your system updated via Windows Update because as i read some threads, Microsoft has a fix on it.
  • james yu
    Hi Pcdown;
    when you say bluescreen, do you mean blue screen of death? does it have some information on it?
    so basically your pc won't boot up now right?
    Scholar:
  • 141 Answers
Hi PC;
try booting up in safe mode then shutdown from there, see if you still hang on the blank blue screen.
to go to safe mode, tap F8 when your pc is booting up.
get back to me for feedback. :)
Posted on Jun 23, 2008
  • james yu
    james yu Jun 23, 2008
    Hi PCdown,
    so there was a application in your pc that was not shutdown properly, can you browse your pc and see if you have some software that you use on boot up? most likely some of it are also the ones that would stay behind on shutdown,
    so before you shutdown, look at your taskbar and choose a software there that you would like to manually end the task with and see if you can shutdown properly. hope you can find that piece of software thats been bugging you.hehehehe...
  • james yu
    woooops...an application i mean that was not shutting down properly.
Cannot delete avira antivirus,when i erase in my folder.
You have to delete your antivirus from Add or Remove Programs Section (Start->Control Panel->Add or Remove Programs-> Search for Avira and click on the right button (Remove). Just erasing your folder will not completely delete your Antivirus.
I hope I helped you
May 20, 2011 | Microsoft Windows 7 Home Premium 64BIT...
I have to remove windows 7 transformation pack from windows xp i have uninstalled it but still it is not removed i also used add or remove programs for this
Good but after uninstalled by using add or remove programs, please ensure that you have to restart your PC to effect the uninstallation properly.
Mar 01, 2011 | Microsoft Windows XP Home Edition
I'm trying to install Norton 360. It says it's detected the old 60 day trial, and removes it, then asks for a restart. When it boots back up, it says the same thing again, and I've restarted 7 times now....
Go to Control Panel > add/remove programs and uninstall Norton 360 from there.
After uninstall is complete then proceed with restart and then install the new version.
In case you are unable to remove the software via add/remove programs then reinstall the old expired version (this will repair the old installation). Restart then uninstall via the method given above i.e. through add/remove programs.
This software is a problem when uninstalling..you are not alone.
Sep 28, 2009 | Symantec Norton 360 Full Version for PC...
I down loaded the trial version of Nero 8. and I want to put my old version Nero 7 back on. I cannot uninstall the trial version it keeps aborting half way through it and I do not want to reformat my hard...
I . asked a friend of mine who is a PC Guru and he has a programme for removing it. But and it is a big But!, you have to use the pro gramme first. once you have tried to un-install it yourself it does not work. In the end I had to wipe the Hard Drive and reload windows. Nero Very naughty and I was not a very happy chappy. Previous experience I,d already made a back up of my program mes but it was still time consuming.
Nov 03, 2008 | Computers & Internet
I am trying to uninstall nero 7, I keep getting a message saying shellmanager missing or corrupt. I want to install nero 8 but I am unable to until I resolve this problem
Try uninstalling by clicking Start, Control Panel, Add or Removed Programs, select Nero 7, then click Remove, maybe that can solve your problem.
Oct 24, 2008 | Computers & Internet
Nero error code
First of all if you have the Nero 7 setup file, try installing it once and uninstall from control panel -> Add Remove Programs, after that try installing Nero 8, if this doesn't solve the problem you can proceed with Microsoft Windows Installer Cleanup Utility, download that from microsoft website, Install it and Run it, then select all the entries of Nero from the list you get and click on Remove. Then try to Install Nero 8, it should work fine.
Jun 03, 2008 | Ahead Software Nero 6.6 (600901) for PC
Nero 8
U may try a complete uninstall before going into the reg. Use the control panel - add/remove program to remove the program. Reboot. Goto Microsoft updates and make sure you are up-to-date, then reinstall the nero program.
May 28, 2008 | Microsoft Windows XP Professional
Error Message: Direct CD; This driver will be disabled. Contact Manufacture ( Roxio )for an update that is compatable with this version of Windows. (XP home edition )
If you dont need the direct cd function or the roxio program which is outdated I recommend you uninstall it and then after install the newest version or another software like
nero
www.nero.com
Apr 29, 2008 | Computers & Internet
Computers & Internet Logo
94 people viewed this question
David Payne
David Payne
