Question about Samsung ML-2510 Laser Printer
Paper jammed the paper get's jammed in the printer and when i remove the paper i notice i could dust the printed words off the paper.i also notice the paper is not worm after printing.
  • kervin365 Jun 23, 2008
    thanks for the info guys
  • Anonymous Mar 15, 2014
    printer is on and installed successfully but doesn't take print out noticing paper online error
  • 40 Answers
Your fuser is bad. The fuser is a part that "fuses" the toner with heat and pressure to the paper. You will have to have a new fuser to fix your problem.
Posted on Jun 23, 2008
Hello, I have a HP 3210 Photosmart All-in-One printer. It will copy and print a test page with no problem. It will not print from the computer command. The photo carrier slides freely in and out as if it...
Hello and Welcome to FixYa!
Sir, The problem you are telling is surely be the problem of Paper Jam actually their may be small bit paper jam in side the printerThere are some "micro-sensors" that detect a paper jam. There will be tiny piece of paper, or a lump of dust, inside those sensors, thus "tripping" the sensor and saying you paper jam.
To solve it
Open printer cover and check to make sure no paper or foreign objects obstructing the printer feeder
If you become sure that now really there is no paper, dust or foreign objects then
Turn the printer off, and disconnect the AC power-cable. Open the printer cover & now give the printer a "blow-job" by compressed air.It will clear the printer jam error and your problem will be solved.
I hope you have clear picture in your mind, Don't hesitate to let me know if you have some confusion
Sir, Your Rating as Five Stars for this solution and Words of appreciation as Feedback for me will be really esteemed
Thank You for taking my service
Concerned: Muhammad Uzair Team : FixYa
Nov 28, 2011 | HP Photosmart 3210 Printer
I had a cannon LBP2900 printer. IT has a problem of paper jam. It prints very well in A5 paper but hen i try to print in A4 paper, the paper gets jam. It also makes some cracking sound and i found some...
Without doing a complete disassemble, remove all covers, remove paper tray(s), remove ink cartridges (or laser cartridges...everything that is EASY to remove. Clean your rollers (may be gummed up a bit), remove all dust, dirt, grime, everything. My Canon printers are extremely sensitive to jams. As long as you keep it clean internally, you should have no problems. Take a look at this video about paper jams.
Nov 30, 2017 | Canon LASER SHOT LBP-2900 Printer
I was printing a report and had one page left to go and I noticed that it was out of paper. So I got some paper and put it in the paper slot. The printer fed about 6 sheets in a one time and that caused...
there is still paper stuck in the printer. open up the front of the printer (as if you were changing the ink cartridge) and remove the paper. Then turn the printer off and on. Good luck.
Feb 26, 2011 | Dell 924 All-in-One InkJet Printer
Just copy file..always jam..messagge"papper jam
Causes for paper jams in Printers are given below:
* Dust or debris
* Rotating drum problem
* Toner or fuser complaint
Dust or debris
One of the main causes for paper jams is the presence of dirt, dust, or debris in your toner cartridge. The paper coming into the cartridge would get stuck. So clean your printer regularly. Remove the dust from the printer. Also find out whether any jams occurred in the sensor hole in the upper part of the rotating drum. Do not touch the roller while cleaning. If the oil in your body gets into the roller, the printing media cannot roll over it properly and you can't get rid of the printer problem.
If there is no direct symptom of paper jam and still you cannot do printing properly, find whether it is because of drum problem. If the paper gets into the end gear of the rotating drum and gets stuck there, you cannot access the printing function. Switch off your printer and check the plastic arms of the printer drum. If there is any paper piece jammed in any of the arms, you can't continue printing. Here also cleaning is the best method to solve the problem. While cleaning, check the arms of the rotating drum.
Toner complaint may also cause paper jams. It can be solved only by replacing it. When you switch on the loop back plug in, two flash lights appear; then it indicates paper jam. The oil spillage in toner can cause this problem. If the toner cartridge is not functioning properly, the same problem would be the result. The diodes or transistors in the fuser unit of the printer may get damaged and this can lead to fuser complaints. To solve this problem, you should replace it.
Feb 22, 2011 | Office Equipment & Supplies
I recently aquired a HP psc 2410 all in one printer. Upon start up I got an error msg that the cartridges are jammed, unjam and press ok. Well there doesnt appear to be a jam. The cartridges slide back and...
There is little or no value in older printers.
However the unit has gots its positioning confused.
Try switching off and on printer several time, opening lid for cartridge change to see if it can synch itself again.
Please dont forget to vote if you liked my answer
thanks
Feb 07, 2011 | HP PSC 2410 All-In-One InkJet Printer
When i print my printer slow paper jam please tell me about to clear it
One of the main causes for paper jams is the presence of dirt, dust, or debris in your toner cartridge. The paper coming into the cartridge would get stuck. So clean your printer regularly. Remove the dust from the printer. Also find out whether any jams occurred in the sensor hole in the upper part of the rotating drum. Do not touch the roller while cleaning. If the oil in your body gets into the roller, the printing media cannot roll over it properly and you can't get rid of the printer problem.Hope this helps you.
Thanks
Michel
Jan 31, 2011 | Brother MFC-290C Printer
Paper is constantly jamming on right hand side-as you face printer-it feeds in unevenly as soon as I start to print.
Remove all print paper from the paper tray. check if there are any dust particles or any other substances that might be jamming the paper. That is the only fix.
Dec 20, 2010 | Epson Stylus RX650 All-In-One Printer
I can't get my brother printer to print photos Keeps saying paper jam even though no paper jam
Sep 23, 2010 | Brother MFC-685cw InkJet Printer
I get paper jam notice, remove jam and restart. There is no paper jam,when I try to print only half of picture prints
Make sure there is plenty of room behind the printer, the paper is drawn in the front and sticks all the way out of the back before it starts printing, it will show a jam if it can't get all the way out of the back slot.
Aug 28, 2009 | Canon SELPHY DS810 InkJet Photo Printer
Paper error showing. I pulled out paper jam and none showing, yet cannot get it to print
When the Printing job initiated, the pages will print slowly and we cannot pull the paper from the printer. That will lead to the paper push becomes inactive.
Thnigs to do for rectifify the problem :
01. Please remove the toner / cartridge from the Printer..
02. Please remove the jammed sheets from the roller.
03. If any other opening available in the printer, that also can be opened.
04. Please try to pull out all loose sheets available in the printer.
05. Clean the roller with good cloth and remove all dusts from the printer.
06. Install the papers in the In Tray properly.
07. Reboot the system along with the Printer.
The above points will solve your paper jam problem in the printer.
Have a Nice day
Jul 17, 2009 | Office Equipment & Supplies
Samsung ML-2510 Laser Printer Logo
174 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
