Question about Kenmore 74602 Gas Dryer
Dryer will not start
Will not start . the check lint alarm keeps going on. lint filter is clean
  • 943 Answers
Hi thanks for the question remove the venting to the outside clean all lint. remove the back panel on the left on the air duct you will see a small piece of plastic with 2 small blue wires to it thats a thermal fuse. replace it. dirty venting is sometimes the cause, of the failure. thanks the appliance doc
Posted on Oct 02, 2008
Dryer keeps saying check filter - lint screen is clean-dryer won't run
Had the same problem. Filter was clean. Vacuumed out the area under the filter. Still had problem. Unplugged the dryer. Removed the hose vent (back of dryer) and checked the exhaust -- all clean. Plugged the dryer back in and was fine. Still going to check the vent to the outside for lint buildup.
Jan 17, 2011 | LG DLG2524 Gas Dryer
Dryer check filter light keeps blinking and dryer will not start cleaned lint filter and nothing happened display on control board blinks when dryer is turned on and that's about it can you assist dyer...
There is a reminder light to "Check Lint Filter" near the lower right of the cycle knob. It will come on every time the power button is pushed. After cleaning the lint filter, if the "check lint screen" light does not go off, it is likely that the touch pad control will need replacement.
Jan 09, 2011 | LG DLE0442 Electric Dryer
My dryer keeps saying Lint Filter Problems and cutting off however the lint filter is clean. Because of this issue I the dryer will not stay on long enough to actually dry the clothes. It continuously...
try two things. first, run it empty without the lint filter installed. if it gives you the same error message, install the filter, but disconnect the flexible duct connected to the back of the dryer. try it again. if it still wont work, you will have to get it serviced and cleaned out. if it works with the ducting removed from the back, your dryer duct is clogged up. check your yellow pages for dryer duct cleaning. The lint filter error message is just your machines way of saying it is not getting enough air flow. It can be caused by a clogged duct also.
Nov 20, 2010 | Siemens Dryers
Dryer won't start
remove filter then try or with filter out look in side if dirty go to lowes get a lint brush
Apr 21, 2010 | GE 7.0 Cu. Ft. Super Capacity Gas Dryer
Keep replacing thermal fuse
This is going to sound like an owners manual but here goes:
1. Keeping the lint filters clean after each load is every important.
a. if you use dryer sheets (bounce etc) you should clean you lint filter with vinegar about every 90 days. The material from the dryer sheets collects on the lint filter. It will appear clean but will restrict airflow.
2. All air passages must be kept clear:
a. Around the lint filter (look deep and hard) clean with crevice tool
b. At the rear connection of the dryer check the vent ducting for obstructions. It can appear clean yet have a caked build up inside the ducting that restricts airflow.
c. The through the wall vent ducting flapper.
Other than the lint filter the is the leading cause of ducting restrictions. Lint can build up on BOTH sides of the flapper so it keeps it from fully opening or closing and restricts airflow.
Thermistors are there to prevent your dryer from burning down your home. The thermistor is doing its job.
Sorry for sounding like an owners manual / user guide but everything above I see over and over and over..... and over. People say the ducting lint filter and thru the wall vent are clear... Yet I go out there and they pay me to prove them wrong.
Thanks for using FixYa.
Kelly
Mar 20, 2010 | Kenmore 63942 Dryer
Bosch Nexxt 800 series dryer E01 error
My wife has a Bosch Premium dryer that had drying problems. The lint filter would get cleaned but the machine still did not operate correctly, as you explained above. Her machine was made in 2005 and the lint screen, the plastic slotted unit in front of the lint filter was the problem. It gets clogged up with hair/lint that never makes it to the filter. I tried a shop vac to vacuum it but the problem was still there. Get a pistol cleaning kit for a 22 cal gun. Pull the lint filter out & then take the pistol rod and insert it from the drum side into each slot and pull out the tons of lint. Pull the lint off the rod when done and take a flame to burn the rest off as the rod is a brass brush with small wires on it.
Jun 14, 2009 | Bosch Nexxt 500 Plus Dryer
Clean lent filter sign shows and won't let it run. power is on and have manually checked the vent hose, exterior exit. still won't work Clean Lint Filter Indicator Light Flashes but my lint filter is...
check for wires near lint filter casing. these are the lint filter sensors, they could be defective that is why it always indicate a clean lint filter alarm,
Feb 19, 2008 | Dryers
Bosch Axxis WTL 5400 Electric Condensation Dryer...Lint Filter Light
have you checked the vent line it could be stopped up if the line is bent same affect as the lint filter being full
Dec 15, 2007 | Bosch Axxis WTL 5410 Electric Dryer
Front loading dryer
The check filter light is just a reminder light and cannot be reset.  Nothing to worry about.  Just keep the filter clean before each use.
Nov 21, 2007 | LG DLG2524 Gas Dryer
Kenmore 74602 Gas Dryer Logo
79 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
