My technics se hd 51 amp seems to have stopped working. I have a barely audible sound when turned up to full vol. Any suggestions...can I d.i.y. this job ? many many thanks. Technics SE-HD1 Stereo amplifier as part of receiver, cd and tape component system. Haven't used it for a while. Everything seems to be working ok, but no sound coming out of the speakers. Get sound out of headphone jack ok.
  • William Somerset Jul 13, 2008
    Excellent solution. Turned out to be bad contacts on speaker unit. Connections appeared to be in firm contact, but had to be flexed, pushed and prodded to make work. Got signal from head phone jack and proved amp was working. Connected small pc speaker to output contact and got signal. Therefore had to be speaker or speaker contact. Have also had considerable problems with various components, cd, tape deck, and tuner acting in erratic fashion. Turned out caused by seemingly good ribbon cable contacts not working due to corrosion or dust, which is not visually apparent. Strong contact cleaner would be good solution, but not readily available in England.
  • 682 Answers
Please bring a good contact cleaner from radio shack near you and apply the spray over the socket of the headphone(the place where you put your headphone jack)take headphone jack out and apply spray in and insert the jack in and out many times.-also check your system setup and confirm that all speaker are on- no mute button pressed-no cable is disconnected.
Posted on Jul 13, 2008
  • mohamed eltoni
    mohamed eltoni Jul 14, 2008
    always at your service.
  • Krzysztof Pawlak
    Krzysztof Pawlak Feb 25, 2014
    THANKS MOHAMED YOU ARE GREAT!!!! THANKS!!!!
Technics SC-CH530 Barely audible CD player
Have you tried cleaning the unit, there are discs to do that, 4 years is a long time?
Dec 26, 2017 | Technics Audio Players & Recorders
Monitor buzz
its poor insulation on your power supply
Aug 27, 2012 | Music
Amplifier powers up. low humming, and music is barely heard at full volume.
The main amplifer ICs have taken a dump. Time to go shopping!
Nov 15, 2011 | Audio Players & Recorders
VSX504S volume has become very soft
soft meaning - barely audible? in that case either u have a defective loudspeaker or a defective audio power amp section. I suspect the latter, so what i suggest is - get it checked. U could try opening it up urself and mess with it if u plan to buy a new one :-)
Mar 11, 2010 | Pioneer Audio Players & Recorders
Technics SL-1700 Turntable that is barely audible
Have you have tried it on a different amp, if not do so - which if it solves you have a faulty phono pre-amp in that amp- if not I would suspect that inside the deck is a faulty pre-amp. Or is the cartridge faulty?
Sep 05, 2009 | Audio Players & Recorders
Low Sound
First of all what model your keyboard? Posible couse of audible sound is came from the volume control. Replace the volume control or contact an authorize service center on your location.
Jun 08, 2008 | Yamaha Full-Size Keyboard
First, turn down the volume on the reciever. Next make sure that "tape monitor" has not been selected. If that doesn't do it, it will be time for a shop visit...accordianman
May 12, 2008 | Audio Players & Recorders
Technics SUV500 Amplifier
check volume balance between right and left-then change inter connection between sound source and amplifier with new cabel(i prefer gold plated type connectors)(see radio shack).
after that if the problem excit your fault in output transistors or output stereo ic depend on circuit design.
Feb 17, 2008 | Technics SUV500 2-Channel Amplifier
ASUS P5B-MX MoBo Very low sound output.
inthe realteck sound system there u need to adjust the settings in the software set the settings to 2 channel
Oct 24, 2007 | Gigabyte GA-945GM-S2 Motherboard
970 people viewed this question
 Grubhead
Grubhead
