Question about Parsons QuickVerse 2005 Expanded Edition (11149)
QV ver6 (Win 95/98/NT) compatible with Vista?
QV Ver.6 goes thru installation, but then when trying to launch the program, it complains about "QVEDIT.OCX is not a registered component, make sure loaded into program directory"
Is Ver.6 compatible with Windows Vista OS?
  • 4 more comments
  • mag77 Jul 23, 2008
    Is Ver.6 compatible with Windows Vista OS? I have the same problem, tried reinstalling, didn't help. is there any help out there?
  • olurotimiade Aug 25, 2008
  • Anonymous Sep 06, 2008
    NO "QVEDIT.OCX"
  • TOMMYJOHN Sep 06, 2008
    WILL NOT START SAYS QVEDIT.OCX IS NOT REG.
  • rhogan11 Oct 13, 2008
    My Quickverse installs, but when I try to open it there is an alert that says QVEDIT.OCX not registered. I am running Windows Vista.
  • Anonymous Jan 14, 2009
    I have a simalar problem with a Clue/Cluedo PC game from a KFC promo that is only compatible with Windows 95/98 and i can't install it onto my Vista Home Basic. I was able to make my Vista compatible with XP programs but i can't do it with this game... It might even be that its a dodgy game i don't know... help would be great if possible =)
If you right click on the shortcut and go to the Compatibility tab you can check the Run this program as an Administrator option. This worked for me.
Posted on Oct 21, 2008
I need help... posted by lduaineallen@yahoo.com on November 21, 2008 QV Ver.6 goes thru installation, but then when trying to launch the program, it complains about "QVEDIT.OCX is not a registered component, make sure loaded into program directory" Is Ver.6 compatible with Windows Vista OS? CAN YOU HELP ME, PLEASE?
Posted on Nov 21, 2008
I have a PC with motherboard MSI MS 6702, I cant find the Ethernet controller driver for it ! Thanks for help
I got drivers for you. The first link is for win vista32 and vista64 drivers.
2nd link is for XP32, win 2000, win 95,98, NT and all other pre vista versions.
If you need drivers for other OS, PM me.
Link1: http://www.ziddu.com/download/15101799/Realtek_Gigabit_NIC_Vista.zip.html Link2: http://www.ziddu.com/download/15101800/Realtek_Gigabit_LAN_MB.zip.html
May 24, 2011 | Computers & Internet
Window ce ver6
no you cant do that, you must download yahoo messenger and skype version of Windows Ce ver.6 , and you must update framework you windows ce in http://www.microsoft.com/windowsmobile/download
May 02, 2010 | Computers & Internet
CineDashMediaConsole.volume not working.
Cinedash FIX for Windows 7
This works to fix the CineDash Media Console!
I had the same problem with my Aspire 8920G
Now it works fine.
Getting the CineDash Media Console and Launch Buttons working
If you have problems with either the CineDash Media Console or Launch buttons then you will be happy to hear that the solution for fixing these is easy!
The first thing that you will need to do is install the “Launch Manager” which can be downloaded off the Acer website. Go to http://www.acer.com and click the service support, then driver download. Go to your model. Download the Launch Manager on the acer site. The filename should be “Kilimanjaro_v2.0.00_Vistax32×64_XPx32×64.zip” the version of Launch Manager under the Windows Vista operating system .This will get the Email, Web and Empowering Technology buttons working with their default settings. If you need to change what the buttons do, you can launch the application named “Launch Manager” in the start menu.
Uninstall any previous version of Launch Manager
The solution to my problem was to get the Launch Manager to run in compatibility mode for Windows Vista Service Pack 2.
Unzip. Explore the new folder and right-click Setup.exe.
To do this go to the Launch Manager Install directory (C:\Program Files\Launch Manager ), right-click on “setup.exe”, select the “troubleshoot compatibility” tab, check the “Troubleshoot program” check box and then click “The program worked in earlier versions of Windows but won’t install or run now”. Then select “Windows Vista Service Pack 2”. Then click “Start” program. Now everything should work properly! It will install. But don’t reboot yet!
Now locate and explore the freshly installed folder in your program files directory – (probably C:\Program Files (x86)\Launch Manager or C:\Program Files\Launch Manager depending on if you are running 64-bit or 32-bit)
right-click on “LManager.exe”, select the “troubleshoot compatibility” tab, check the “Troubleshoot program” check box and then click “The program worked in earlier versions of Windows but won’t install or run now”. Then select “Windows Vista Service Pack 2”. Then click “Start” program. Now everything should work properly! It will install.
Reboot and enjoy properly synced volume, and fully functioning buttons.
Feb 16, 2010 | Acer Aspire 6920 Notebook PC
Just bought an new Windows Vista machine. Have
You must set this program to install and run in "Compatibility Mode" for windows 95.
Right click on the installer setup exe and choose run in compatibility mode and check for Win '95. Do the same for the main EXE of the program too, also make sure you run BOTH as "Administrator"
Jan 28, 2010 | Microsoft Windows Vista Business Edition...
When i try to run an app i get the message not a
1. It's the main problem with Vista! It don't support applications / softwares which are 16-bit (Only 32-bit applications are supported!).
2. It hardly support any application older than Windows XP (which runs on Windows 95/98/NT/Me)!
3. Try to download the updated version of your applications from internet which are Windows Vista compatible.
4. Then install these updated versions.
tell me if it don't works...tc! :)
Jan 06, 2010 | Toshiba Satellite A305-S6859 Notebook
Will not let me see videos on Youtube becaause of flash player not installed When i installed it it said You need a newer version of windows.
What version of Window do you have ?
Win 98, Win 98se, Windows 2000 don't have newer program written for them. Most programs only support XP / Vista. If you have flash Ver. 6 and YouTube requires Ver. 8 or above. You're out of luck. I've had to dump all my Win98/ Win 2000 PC because of that problem in my school. Web is all Flash/ Shockwave anymore.
Jul 14, 2009 | Computers & Internet
Reason 4 launch problem!! please help!!
If it worked fine in Win XP you could run the program in compatibility mode. Right-click on the icon and go to properties. Then click on compatibility. Then in the drop down box click Windows XP (Service Pack 2)
Jul 06, 2009 | Propellerhead Reason 4.0 - Windows and Mac...
Quicken 2009 premier Installation
a bit fuzzy here in your statements
you have win xp installed and the quicken program runs there perfectly
is that correct ?
now on another pc you have win vista and quicken is not running there
is that correct?
or do you have both win xp and vista operating systems on the one laptop and are trying to get quicken to work on both on the one laptop
maybe the problem is that quicken version you have works well win win xp as it is compatible with that OS but is not compatible with win vista in which case you need to go to the quicken properties tab , click on compatibility tab and tick the box and high light window vista and apply the change or get a download upgrade vesion from quicken web site
Jul 18, 2017 | Computers & Internet
Where can I download the Picture Motion Browser software Ver 1.1 for Win XP MCE
What ever version of picture motion browser you have in PC, you can upgrade it by ver.3.0.05 at Sony Support for Vista.
If you require ver.1, (for Win XP) contact Sony on above page and place order for ver.1 CD.
For details, check Sony News page.
Oct 20, 2008 | Sony Handycam HDR-UX1 DVD Camcorder
OPERATING SYSTEM
Hi
as i interpret your question, you are asking for some examples of Operating Sytems? if thats so, here are some:
MS Windows
ver. 3.11, Win95, Win98, WinME, WinXP, Win Vista
Win NT, Win2000 Pro, Win2000 Server, Win 2003 Server
Linux OS, several "flavors" like Ubuntu, Red Hat, Mandrake, Bayanihan Linux (from DOST-UP)
Sun Solaris, Unix Operating System, BeOS
Apple MacOS, OSX, OS 9
almost forgot, DOS, MS DOS and PC DOS
Mar 01, 2008 | Computers & Internet
Computers & Internet Logo
644 people viewed this question
Top Parsons Computers & Internet Experts
Neil
Level 1 Expert
tdk1988
Are you a Parsons Computer and Internet Expert? Answer questions, earn points and help others
