Question about Samsung Televison & Video
Samsung HLS5087WX/XAA goes to red/green stripes then red then black about 3 times & then shuts off
  • bhleas Jun 25, 2008
    The power button may blink twice when turned on but then stays off.
    Guru:
  • 1,894 Answers
Does the power light blink in any regular way?
it may help us to decode what the problem is..
Posted on Jun 23, 2008
  • dewan nafees ahmed Jun 23, 2008
    Just replace the convergence amp board part# BP95-00142E
    (about $80) It includes both convergence IC's and associated components (Five connectors,one screw,easy access)
    dont forget to accept MY solution if u go by it.
    feel free for asking any doubts u have.
    thank u for ur cooperation.
    good luck for getting fixed soon
Samsung HLS5087WX/XAA DPL shuts down after 30 - 60 seconds, 3 blinking lights
I beleive from what you have told me that most likely it is just a lamp issue, there are a lot of so called original equipment lamps and counterfit lamps on the market that will barely give you 1000 hours run time. When it comes to Television lamps cheeper is not better. Make certain to buy an original Samsung lamp, you should get about 3500 to 4000 hours from it. If you need further assistance or have questions please reply to continue.
Jul 27, 2012 | Samsung Televison & Video
Black screen, blinking led
actually, unless the control board is identical(which it isn't) that would be a bit of a stretch.. Let's see..can you let me know what is the model number of your set?
Feb 24, 2008 | Televison & Video
Need connection details for Blaupunkt Bamberg SQR 05
It should follow the usual practice:
White and white with black stripe- Left front.
Gray and gray with white stripe Right front.
Blue goes to the power antenna lead
Yellow is the data store and should connect to a point that is always hot from the Battery "+" and not interupted by the ignition switch It should have a 3 amp fuse.
Red is the main power and should be wired to a point that foes get interupted by ignition switch- such as existing radio It should be protected by 8 amp fuse.
Black is ground (-)
Orange is dimable illumination- wire to a dash light
The black wire with an 1/8 jack end is for portable devices to plug into.
Green and green with black stripe Left rear speaker
Violet and violet with black stripe is right rear speaker.
Alternately you can opt for the red and white RCA terminated leads to plug into another amp's input for rear speakers,
Mar 30, 2012 | Blaupunkt Car Audio & Video
The brake light on the dash wont go off brakes are good rotors are good not the emergency brake. i have a 98 durango
check the brake fluid level and check the park brake switch it may be stuck on or out of adjustment
Apr 16, 2010 | 1998 Dodge Durango
Speaker wire colors
1991 Ford Explorer XLT Radio and Speaker Wire Colors
Pulled out the stock radio and found two plugs on the back of it. One plug had 7 wires (Power, Dimmer, Amp etc.) and one had 8 (Speakers).
7 wire plug (I could see these wires immediately from the plug):
Car Radio Battery Constant 12v+ wire = Light Green w/ Yellow Stripe
Car Radio Ground Wire = Black
Car Radio Accessory Switched 12v+ wire = Yellow w/ Black Stripe
Car Radio Dimmer Wire = Light Blue w/ Red Stripe
Car Radio Illumination Wire = Orange w/ Black Stripe
?? Don't know ?? Red Wire (No power to wire Constant or Accessory)
Car Radio Amp Wire = Blue
8 Wire Plug (Wires were wrapped in a grey outer sleeve, had to cut sleeve to get to wires.):
Right Front:
White w/ Green Stripe (+)
Brown (no stripe) (-)
Right Rear:
Purple w/ White Stripe (+)
Light Blue (no stripe) (-)
Left Front:
Light Green (no stripe) (+)
White w/ Orange Stripe (-)
Left Rear:
Light Blue w/ Black Stripe (+)
Yellow (no stripe) (-)
Speaker Wires (found at the individual speakers in the doors)
Right Front:
Green w/ Orange Stripe (-)
Right Rear:
Orange w/ Red Stripe (+)
Black w/ White Stripe (-)
Left Front:
Orange w/ Green Stripe (+)
Blue w/ White Stripe (-)
Left Rear:
Red w/ Green Stripe (+)
Red w/ Blue Stripe (-)
Aug 10, 2009 | 1991 Ford Tempo 4 Door
Samsung lns4095dx/xaa after 30min the screen goes
The first place to start is with the Main bd. The second cause would be the T-con bd. Have a trained Samsung tech troubleshoot to find out and repair the set.
Jul 05, 2009 | Samsung LN32A550 32 in. LCD TV
My wife bought a kenwood z828/uf4. there are wires in the back but none of them are labeled. can anybody help me
red - 12v ignition
yellow - memory 12v cont.battery
orange - illumination
black - ground
white- front right speaker +
white/black stripe - front right speaker -
gray - front left speaker +
gray/black stripe - front left speaker -
violet - rear right speaker +
violet/black stripe - rear right speaker -
green - rear left speaker +
green/black stripe - rear left speaker -
blue - remote, amp
blue/white stripe - power antenna
if you don't have a blue/white strip wire than the solid blue wire goes to power antenna, amp and remote...........
hope this helped you
Feb 26, 2009 | Kenwood Car Audio & Video
3 prong dryer to 4 prong
green is ground, white is netural. red and black are L1 and L2
or in other words on the dryer there is a 3 screw holder red and black go on the outer ones white goes in the middle and green goes to the cabinet of the dryer
Oct 31, 2008 | Frigidaire FEQ332E Electric Dryer
I have a honda civic 1992 and i buy a sony car stero i have problem with de wiring like red goes with red black goes with black but de others color from my honda civic are difent can i have an ide
Battery
White/Yellow Stripe
or White/Blue Stripe
Accessory Yellow/Red Stripe Ground Black Illumination Red Dimmer Red/Black Stripe Power Antenna Yellow/White Stripe Left Front Speaker (+) Blue/Green Stripe Left Front Speaker (-) Gray/Black Stripe Right Front Speaker (+) Red/Green Stripe Right Front Speaker (-) Brown/Black Stripe Left Rear Speaker (+) Blue/Yellow Stripe Left Rear Speaker (-) Gray/White Stripe Right Rear Speaker (+) Red/Yellow Stripe Right Rear Speaker (-) Brown/White Stripe
Oct 19, 2008 | Pie Hon03 F/Mm Car Stereo Wiring Harness...
Wiring a new radio in 1991 ford explorer
Right Front:
Right Rear:
Left Front:
Left Rear:
Right Front:
Right Rear:
Left Front:
Left Rear:
Hope this helps. I spent hours looking for the correct color key and this one works for my '91 Explorer.
Feb 08, 2008 | JVC KD-G230 CD Player
Televison & Video Logo
223 people viewed this question
Henry  Thomas
Henry Thomas
